1 Reply Latest reply on Jun 28, 2015 8:55 AM by trshaner
    Lightroom CC 2015 - Slideshow using Export JPEG always puts last slide Caption on all slides. I need help or is it a bug?
    bruceglover@optusnet
      Hi There,  I have made quite a few PDF Slideshows and have no problems with PDF Slideshows at all.  However if I use Export JPEG the slides come out fine but with the caption off the last slide on absolutely all slides.  Where with the Export PDF it uses the correct captions on each slide.  I have changed nothing except changing to Export JPEG.
      I have tried shutting Lightroom and reopening it, I then shut down the PC and restarted it and then deleted the Caption placemarker and then re set a new Caption placemarker but nothing changed.  I always have the last slide's caption on all slides.
      I hope someone can suggest a work around or a fix?
      I am using a high end PC meaning, less than a year old, Core i7 - 3930 CPU @ 3.20 Ghz, 16GB RAM, 64bit Windows 7, NVidia GeForce GTX670 GPU etc.
