3 Replies Latest reply on Feb 18, 2009 1:56 AM by alex485947
    Error with dynamic content
    alex485947
      Hi!
      I have several movieclips. One is aligned to top, on is to bottom, one is to up left corner and so on.
      When I use:
      ___________________________________
      Stage.scaleMode = "noScale";
      Stage.align = "TL";
      onResize = function ()
      ttl._x = 0;
      ttl._y = 0;
      ttc._x = (Stage.width - ttc._width) / 2;
      ttc._y = 0;
      ttr._x = Stage.width - ttr._width;
      ttr._y = 0;
      ccl._x = 0;
      ccl._y = (Stage.height - ccl._height) / 2;
      ccl2._x = 0;
      ccl2._y = (Stage.height - ccl._height) / 2;
      ccc._x = (Stage.width - ccc._width) / 2;
      ccc._y = (Stage.height - ccc._height) / 2;
      ccc2._x = (Stage.width - ccc2._width) / 2;
      ccc2._y = (Stage.height - ccc2._height) / 2;
      ccr._x = Stage.width - ccr._width;
      ccr._y = (Stage.height - ccr._height) / 2;
      bbl._x = 0;
      bbl._y = Stage.height - bbl._height;
      bbc._x = (Stage.width - bbc._width) / 2;
      bbc._y = Stage.height - bbc._height;
      bbr._x = Stage.width - bbr._width;
      bbr._y = Stage.height - bbr._height;
      Stage.addListener(this);
      onResize();
      Than moviclip bbc (with scrolling) is shown at different playces with the different screen resolution.
      If I leave a little amount of text (so that it has the size less than moviclip) than it goes ok.
      I attach two files: http://www.alex-pro.net/index_test_0.rar
      I am appriciate for any help.
        • 1. Re: Error with dynamic content
          ricekingusa
          could you specify your problem, if this is a problem. And 11 movie clips (that really don't have meaningful names) doesn't help
          • 2. Error with dynamic content
            ricekingusa Level 1
            things you might need to consider;
            you probably meant ccl2 in your math.
            The stage 0,0 is in the top left of the screen.
            You also need to be aware where the reference point of you movie clips are.
            if you edit your movie clip, its reference point is where the '+' is.
            This should be the reason why your pictures are not aligned properly.
            • 3. Re: Error with dynamic content
              alex485947 Level 1
              Thank you for answer.
              Actually I dont have a problem with the movies if there is no scrolling or loading pictures in it.
              I have a problem if I put scrolling text in some of moviclips. In this example I put scrollin text in "bbc". And after this moviclip "bbc" appears in different places with the different screen resolution.
              If I dont put scrolling text there, everything is completely ok.
              Dont know how to fix this.
