Fantastic, thanks a lot,
My next step,
I need to read a different XML document with the following
code:
<!--- Read the file and convert it to an XML document
object --->
<cfif IsDefined ("URL.Target") and URL.Target NEQ "">
<cffile action="read" file="C:\Documents and
Settings\Administrator\Application
Data\pbx\#URL.Action#\#URL.Target#" variable="myxml">
<cfset mydoc = XmlParse(myxml)>
<cfset emp = mydoc.row.XmlChildren>
<cfset size = ArrayLen(emp)>
<cfset myquery = QueryNew(#MyList#)>
<cfset temp = QueryAddRow(myquery)>
<cfloop index="i" from = "1" to = "1">
<cfset temp = QuerySetCell(myquery, "admin",
#mydoc.row.admin.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "anonymous",
#mydoc.row.anonymous.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "auth_adr",
#mydoc.row.auth_adr.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "barge",
#mydoc.row.barge.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "block_cid",
#mydoc.row.block_cid.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "call_redial",
#mydoc.row.call_redial.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "call_return",
#mydoc.row.call_return.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "cfa",
#mydoc.row.cfa.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "cfb",
#mydoc.row.cfb.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "cfn",
#mydoc.row.cfn.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "cfn_timeout",
#mydoc.row.cfn_timeout.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "dial_plan",
#mydoc.row.dial_plan.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "display_name",
#mydoc.row.display_name.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "dnd",
#mydoc.row.dnd.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "email_address",
#mydoc.row.email_address.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "email_cdr",
#mydoc.row.email_cdr.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "email_missed",
#mydoc.row.email_missed.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "email_vmail",
#mydoc.row.email_vmail.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "fax",
#mydoc.row.fax.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "has_name",
#mydoc.row.has_name.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "listen",
#mydoc.row.listen.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "log_register",
#mydoc.row.log_register.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mac",
#mydoc.row.mac.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mailbox_access",
#mydoc.row.mailbox_access.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mb_enable",
#mydoc.row.mb_enable.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mb_pin",
#mydoc.row.mb_pin.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mb_size",
#mydoc.row.mb_size.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mb_timeout",
#mydoc.row.mb_timeout.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "mwi",
#mydoc.row.mwi.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "name_use",
#mydoc.row.name_use.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "password",
#mydoc.row.password.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "reading",
#mydoc.row.reading.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "teach",
#mydoc.row.teach.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "ua_type",
#mydoc.row.ua_type.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "vm_indicator",
#mydoc.row.vm_indicator.XmlText#, #i#)>
<cfset temp = QuerySetCell(myquery, "wavname",
#mydoc.row.wavname.XmlText#, #i#)>
</cfloop>
</cfif>
#MyList# variable is giving me waht I should be reading from
the following file, this is working so fare, bu8t I need to fin a
way to make all
to something like
<cfset temp = QuerySetCell(myquery, "#MyList#",
#mydoc.row.#MyList#.XmlText#, #i#)>
where each element from MyList become a temp varable.
The idea is that I have a XML file used has a template for
generating various XML document and then read all the documents
created based on that template.
so many thanks!
