6 Replies Latest reply on Jul 1, 2015 8:50 AM by wfzen
    formatting when reading content from XML
    wfzen Level 1
      I have content read from XML. the problem is the space between lines are too big that it does not fit the text field. How can I control the space between bullet points? I can use either CS6 or CC.
        • 1. Re: formatting when reading content from XML
          you should be parsing the xml to display to users, not displaying the raw xml in a textfield.
          • 2. Re: formatting when reading content from XML
            wfzen Level 1
            thank you, kglad. Can you show me an example of the right way? I don't quite understand what you mean by parsing the xml to display to users? Does it always need to go through a dynamic text field?
            Thanks.
            • 3. Re: formatting when reading content from XML
              no, there are a number of ways to present the loaded datat including in textfields, datagrids, comboboxes etc.  but i've never seen the raw xml displayed in a textfield.
              i can feature that being helpful during development if you can't use a trace function, but otherwise can't envision any other time that would be beneficial.
              how you display the data and what you display is a design decision.
              paste a sample of the raw xml here and explain what you want to display to the user.
              • 4. Re: formatting when reading content from XML
                wfzen Level 1
                I'm using the XML games here: Search Results
                I have question text similar to this inside question tag:
                <question1>
                You are quoting a homeowner”≥ policy in Texas. The Customer has disclosed the following information:
                - Built 1960
                - Heat- Electric- Installed in 1991
                - Roof- Asphalt shingles- Installed in 2005
                - Plumbing- Copper- Original- Good condition
                - Electrical- Circuit breakers- Copper wires- Partial replacement 1998
                Based on this, ...
                </question1>
                Each new line has a big space between lines that it spans too long vertically. I'd like to control it so bullet points has no space between them.
                • 5. Re: formatting when reading content from XML
                  so you probably just need to strip blank lines:
                  function stripF(s:String):String{
                  var sep:String = '*$%';
                  while(s.indexOf(sep)>-1){
                  sep += '%*&'
                  var a:Array=s.split('\n').join(sep).split('\r').join(sep).split(sep);
                  for(var i:int=a.length-1;i>=0;i--){
                  if(a[i]==''){
                  a.splice(i,1);
                  return a.join('\n');
                  • 6. Re: formatting when reading content from XML
                    wfzen Level 1
                    Thank you again for the script. I later found if the text is in TLF text, then there is no extra blank lines between text lines. For now, it solves my problem even though I have to stay with Flash CS6.
