0 Replies Latest reply on Dec 28, 2006 9:52 AM by maher_kilani
    secure-amf problem
    maher_kilani
      i am able to connect through unsecure amf but i get the following error when trying to connect through secure amf.
      [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Security.Error error Error #2048: Security sandbox violation: http://192.168.0.53:8080/i4sale/views/i4sale.swf cannot load data from https://192.168.0.53:8443/i4sale/messagebroker/amfsecure."]
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()
      at mx.rpc::Responder/fault()
      at mx.rpc::AsyncRequest/fault()
      at mx.messaging::ChannelSet/::faultPendingSends()
      at mx.messaging::ChannelSet/channelFaultHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.messaging.channels::NetConnectionChannel/::defaultErrorHandler()
      at mx.messaging.channels::NetConnectionChannel/::securityErrorHandler()
      My services config looks as follows:
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
      <services>
      <service-include file-path="remoting-config.xml" />
      <service-include file-path="proxy-config.xml" />
      <service-include file-path="messaging-config.xml" />
      <service-include file-path="data-management-config.xml" />
      </services>
      <security>
      <login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
      <!-- Uncomment the correct app server
      <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
      <login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/>
      <login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
      <security-constraint id="basic-read-access">
      <auth-method>Basic</auth-method>
      <roles>
      <role>guests</role>
      <role>accountants</role>
      <role>employees</role>
      <role>managers</role>
      </roles>
      </security-constraint>
      </security>
      <channels>
      <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
      <endpoint uri=" http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
      <properties>
      <polling-enabled>false</polling-enabled>
      </properties>
      </channel-definition>
      <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
      <endpoint uri="https://{server.name}:8443/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
      <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
      <endpoint uri=" http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
      <properties>
      <polling-enabled>true</polling-enabled>
      <polling-interval-seconds>8</polling-interval-seconds>
      </properties>
      <channel-definition id="my-rtmp" class="mx.messaging.channels.RTMPChannel">
      <endpoint uri="rtmp://{server.name}:2038" class="flex.messaging.endpoints.RTMPEndpoint"/>
      <properties>
      <idle-timeout-minutes>20</idle-timeout-minutes>
      <client-to-server-maxbps>100K</client-to-server-maxbps>
      <server-to-client-maxbps>100K</server-to-client-maxbps>
      <!-- for deployment on WebSphere, must be mapped to a WorkManager available in the web application's jndi context.
      <websphere-workmanager-jndi-name>java:comp/env/wm/MessagingWorkManager</websphere-workman ager-jndi-name>
      </properties>
      <channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
      <endpoint uri=" http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
      <channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
      <endpoint uri="https://{server.name}:8443/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
      </channels>
      <logging>
      <target class="flex.messaging.log.ConsoleTarget" level="Error">
      <properties>
      <prefix>[Flex] </prefix>
      <includeDate>false</includeDate>
      <includeTime>false</includeTime>
      <includeLevel>false</includeLevel>
      <includeCategory>false</includeCategory>
      </properties>
      <filters>
      <pattern>Endpoint.*</pattern>
      <pattern>Service.*</pattern>
      <pattern>Configuration</pattern>
      </filters>
      </target>
      </logging>
      <system>
      <redeploy>
      <enabled>true</enabled>
      <watch-interval>20</watch-interval>
      <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
      <watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
      <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
      <watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
      <watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
      <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
      </redeploy>
      </system>
      <factories>
      <factory id="springFactory" class="com.cme.factories.SpringFactory"/>
      </factories>
      </services-config>
      please help, thank you.
