I know there is an understanding that needs to be in place before accomplishing slow motion in Premiere Pro. I have clips that play in slow motion on the iPhone 6 just fine but when I open them in Premiere Pro 2015 CC they play as normal videos without slo motion. Can someone help me understand how to import and then get these clips to play properly in Premiere Pro?
TIA,
Ken
1. Try importing them as always
2. Select the clip at the project window / right click / modify / interpret footage
3. select your working frame rate (i.e 25fps)( instead of the file's frame rate )
4. drag the clip back to the sequence
hope this helps...
hope this helps...
Thank You so much Thanos_Kamaretsos. This is an amazing insight to me and I need to contemplate what is really happening here but I can see that the footage is shot at 240 frames per second and then played at that same recorded speed is going to be just a very high frame rate but at normal speed. When I changed it to 29.97 fps then it played back at roughly one tenth of the recorded speed so much slower than it was recorded and at still a very smooth motion. I am very grateful for your reply.
Thanks much Thanasis!!
Kevin
You re very welcome....!
On Wed, Jul 1, 2015 at 7:46 AM, Kevin-Monahan <forums_noreply@adobe.com>
hi,
I have a similar problem. I have footage which is almost all in slow motion (50fps), my sequence is set to 25fps and it will be exported as 25fps. So if I put the 50fps clips into the 25fps timeline I get the same length of the timeline as when I put that 50fps footage into a 50fps timeline. Is this normal? On both timelines the clips don`t play in slow motion.
I always thought the only thing I need to do while editing slow motion footage is to put it into a timeline with lower fps, so 50fps clips into 25fps timeline. Is this the official workflow for working with slow motion clips, to change the fps to lower rate, in my case 25fps, per interpret footage? If it is so, so how can I know after that which clips were in slow motion and which are in real time if they both in 25fps now? Of course I don`t want to change their names, because I have to deliver them later to color grading. This workflow seems no to be the most efficient. Or am I missing something?
Super helpful, thank you!
