Hello All,
I want to publish grayscale stream, I convert stream in grayscale using filters, but I was not able to publish, can you help me some ?
Thank you
Where/how are you applying the filters? Normally, you would need to perform this on the stream before sending it off to AMS. Applying filters to a video object preview on the stage, for instance, will not modify the actual stream data.
You can subscribe a incomign stream, modify the data and republcish the stream...A handy tool in this is ffmpeg.
hparmar‌ I dont want used ffmap, it is possible inside flex/AS3 only?
@Josep_Labrecque I have RED5 stream, I want convert this stream in Gray scale befour publish and save that stream. so how it is possible?
