3 Replies Latest reply on Jun 30, 2015 9:55 AM by rob day
    Convert this CS4 to CS5 Script
    Foxy Ford
      Can anyone help to this script?
      I´ts a Caption Script for Indesign CS4. So I need to convert it to CS5 and create a new script to Credit Photo.
      I need a Script Caption and another Script Credit.
      if (app.selection.length == 1 || app.selection [0] .constructor.name! = "Retângulo")
        Saída ();
      var MyPicture = app.selection [0];
      var = gb myPicture.geometricBounds;
      // Adicionar uma moldura para a matriz da imagem, que é uma Página
      var myCaption myPicture.parent.textFrames.add = ();
      // Posição eo tamanho da legenda definido
      myCaption.geometricBounds = [gb [2], gb [1], AR [2] 14, gb [3]];
      // Aplicar estilo de objeto para a rubrica - nós assumir que é presente
      myCaption.applyObjectStyle (app.activeDocument.objectStyles.item ("caput"));
      // Adicionar conteúdo espaço reservado
      myCaption.contents = "Caption";
      // Grupo a imagem ea legenda
      myPicture.parent.groups.add ([MyPicture, myCaption]);
        • 1. Re: Convert this CS4 to CS5 Script
          This line seems like it would create a problem in any version:
          There's a reference to an array AR that isn't in the script.
          I would think it would be something like this:
          myCaption.geometricBounds = [gb [3], gb [1], gb [3] + 14, gb [4]];
          gb [3] is the bottom y coordinate of the picture box
          gb [1] is the left x of the picture box
          gb [3] + some amount gives the caption's depth. It would be ruler units so keep in mind 14 could be inches
          gb [4] is the right x of the picture box
          The script also expects an object style named caput to be in the doc.
          • 2. Re: Convert this CS4 to CS5 Script
            Foxy Ford Level 1
            I will try this afternoon!
            Will be this line to Credit Image or to Caption Image?
            • 3. Re: Convert this CS4 to CS5 Script
              Is there more to the script than what you posted?
              Looking more closely there are other problems
              should be:
              var gb=myPicture.geometricBounds;
              should be with add parameters:
              var myCaption=myPicture.parent.textFrames.add();
              I don't think this is a version problem—you might ask over in the scripting forum.
