Hi everyone, I'm using CP7 and have my quiz results slide set up so the learner can retake the quiz, review the questions, or continue. Sometimes when I reach this slide it only stays for 30 seconds and then automatically moves to the next slide. Other times, it pauses until I click one of the buttons.
I tried using the on-enter action of "pause" but then it requires me to double-click the Continue button (but not the others). I tried adding an invisible shape to the slide with an action to pause, but it's still just advancing.
Any ideas on why it might be doing this?
Did you change anything on the score slide, especially about the embedded objects (who have no separate timeline)? Normal behavior of the score side is that it pauses at 1.5secs, which is visible on the timeline. Can you check the pause? I don't see any reason why that pause should be unlocked after 30 secs, never had this behavior. That is why I'm asking about changes.
No, it's still showing to pause after 1.5 seconds. Nothing has been changed, or even added, to the slide.
It's not the very last slide in the deck. Could that be part of it? I have one slide after this one.
I always recommend not to have it as the last slide, so that the results can be transferred to the LMS. One slide should be OK. What are the actions set up for the Continue button (in the Quiz Preferences)? In these two posts I tried to explain the design of quiz/score slides:
The settings are set to:
Pass/Fail settings are:
Do you think it's advancing because it's set to optional?
