5 Replies Latest reply on Jun 30, 2015 2:20 PM by alexw6348634
    Toggle set to "ON" by default
    alexw6348634 Level 1
      vvv
      vvv
      Hi! I'm following DBarranca 's information for using a toggle, I'm in CEP 5.2/4.0.0(switching between them on CC2014)- I JUST want to set the toggle to "ON" by default. I'm curious as to how I would do it, I couldn't find anything in the minimized css that worked. As you can see, I got the disabled to work in the text field, but did not get enabled or on or anything to work in the toggle.
      The topcoat-switch/topcoat-switch__input is what I'm wanting to be set to "ON" by default.
      Thanks!
      Here's the code, the syntax highlighter in here will NOT work.
      [HTML] Toggle enable Extensions - Pastebin.com
