4 Replies Latest reply on Jul 2, 2015 8:53 AM by michelr31372089
    spreadsheet to text layer script?
    dcsimages
      Does anyone know of a script that will create a new photoshop file, copy a row of text from a spreadsheet, csv or delimited text from another doc, paste into a text layer, save and close, go to the next row of text and repeat until the end?
        • 1. Re: spreadsheet to text layer script?
          Chuck Uebele Adobe Community Professional & MVP
          It can be made, but I don't know of any existing scripts. Most scripts are custom for the user, which is what you want. So finding a preexisting script will be difficult if not impossible.
          • 2. Re: spreadsheet to text layer script?
            michelr31372089 Level 2
            Excuse my poor English. You create in the folder where your script is a text file in which there are 4 lines. For instance :
            Line 1
            Line 2
            Line 3
            Line 4
            The following script reads each line, creates a new doc, add a text layer above the background, writes inside the content of the line and saves the document (psd format) in the folder where the script is.
            // MAC Finder ou WINDOWS Explorer
            #target photoshop
            app.bringToFront();
            main();
            function main()
                var currentPath = (new File($.fileName)).path+"/";
                var fileTextName = currentPath+"lines.txt";
                var read_file = File(fileTextName);
                var line = "";
                var artLayerRef="";
                var psd_Options="";
                var newFile="";
                // Opens the text file lines.txt that exists in the script folder
                read_file.open('r');
                while(!read_file.eof)
                    line=read_file.readln();
                    // Creates a new Photoshop document
                    app.documents.add();
                    newFile = app.activeDocument;
                    // Creates a new text art layer
                    artLayerRef = newFile.artLayers.add();
                    artLayerRef.kind = LayerKind.TEXT;
                    artLayerRef.textItem.contents = line;
                    // Saves PSD options
                    psd_Options  = new PhotoshopSaveOptions(); // [PhotoshopSaveOptions]
                    psd_Options.layers  = true; // preserves layers
                    psd_Options.embedColorProfile = true; // preserves profile
                    psd_Options.annotations = true; // preserves notes
                    psd_Options.alphaChannels = true; // preserves alpha channels
                    psd_Options.spotColors = true; // preserves inks
                    // Save the new document
                    newFile.saveAs( File(currentPath + '/' + line + ".psd" ), psd_Options, true );
                    newFile.close(SaveOptions.DONOTSAVECHANGES);
                read_file.close();
            • 3. Re: spreadsheet to text layer script?
              dcsimages Level 1
              Thanks Michael
              Works perfectly.
              It's such an uncomplicated script that I wonder why something similar isn't already included with the other preset scripts.
              • 4. Re: spreadsheet to text layer script?
                Hope it will help. Best regards.
