15 Replies Latest reply on Jul 28, 2017 6:50 AM by Silly-V
    Java Script to Save ai to PDF with password...
    gregg11863082 Level 1
      Hi folks.  My goal is to have a script carry out the following functions:
      1. grab the active document name
      2.  save as a PDF using the active doc name with password lock in the same directory the *.ai file is located
      I have started fiddling with some code but I don't know what I'm doing...newbie.
      Here is the code I'm currently using.
      var curDoc = app.activeDocument;
      var destFolder, sourceFolder, files, fileType, sourceDoc, targetFile, pdfSaveOpts;
      //var destName = "~/Desktop/Testpassword1.pdf";
      var destName = targetFile
      saveFileToPDF(destName);
      //sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator files you want to convert to PDF', '~' );
      //saveFileToPDF(destName);
      if ( sourceFolder != null )
          //files = new Array();
          //fileType = '*.ai';
          //fileType = prompt( 'Select type of Illustrator files to you want to process. Eg: *.ai', ' ' );
          // Get all files matching the pattern
          //files = sourceFolder.getFiles( fileType );
          if ( files.length > 0 )
              // Get the destination to save the files
              destFolder = Folder.selectDialog( 'Select the folder where you want to save the converted PDF files.', '~' );
              for ( i = 0; i < files.length; i++ )
                  sourceDoc = app.open(files[i]); // returns the document object
                  // Call function getNewName to get the name and file to save the pdf
                  targetFile = getNewName();
                  // Call function getPDFOptions get the PDFSaveOptions for the files
                  //pdfSaveOpts = getPDFOptions( );
                  // Save as pdf
                  sourceDoc.saveAs( targetFile, pdfSaveOpts );
                  sourceDoc.close();
              alert( 'Saved' + destFolder );
          else
              alert( 'No matching files found' );
       function getNewName()
          var ext, docName, newName, saveInFile, docName;
          docName = sourceDoc.name;
          ext = '.pdf'; // new extension for pdf file
          newName = "";
          for ( var i = 0 ; docName[i] != "." ; i++ )
              newName += docName[i];
          newName += ext; // full pdf name of the file
          // Create a file object to save the pdf
          saveInFile = new File( destFolder + '/' + newName );
          return saveInFile;
      function saveFileToPDF (dest) {
      var doc = app.activeDocument;
      if ( app.documents.length > 0 ) {
      var saveName = new File ( dest );
      saveOpts = new PDFSaveOptions();
      saveOpts.compatibility = PDFCompatibility.ACROBAT5;
      saveOpts.generateThumbnails = true;
      saveOpts.optimization = true;
      saveOpts.preserveEditability = true;
      saveOpts.bleedOffsetRect = [2,2,2,2];
      saveOpts.trimMarks = true;
      //=======================  COMPRESSION ===========================
      saveOpts.colorCompression = CompressionQuality.JPEGMAXIMUM;
      saveOpts.colorDownsamplingMethod = DownsampleMethod.BICUBICDOWNSAMPLE;
      saveOpts.colorDownsampling = 300;
      saveOpts.colorDownsamplingImageThreshold = 450;
      saveOpts.grayscaleCompression = CompressionQuality.JPEGMAXIMUM;
      saveOpts.grayscaleDownsamplingMethod = DownsampleMethod.BICUBICDOWNSAMPLE;
      saveOpts.grayscaleDownsampling = 300;
      saveOpts.grayscaleDownsamplingImageThreshold = 450;
      saveOpts.monochromeCompression = MonochromeCompression.CCIT4;
      saveOpts.monochromeDownsamplingMethod = DownsampleMethod.BICUBICDOWNSAMPLE;
      saveOpts.monochromeDownsampling = 1200;
      saveOpts.monochromeDownsamplingImageThreshold = 1800;
      //====================  END OF COMPRESSION =======================
      saveOpts.colorConversionID = ColorConversion.COLORCONVERSIONREPURPOSE;
      saveOpts.colorDestinationID = ColorDestination.COLORDESTINATIONWORKINGCMYK;
      saveOpts.requirePermissionPassword = true;
      saveOpts.permissionPassword = "pink";
      saveOpts.pDFAllowPrinting = PDFPrintAllowedEnum.PRINT128LOWRESOLUTION;
      doc.saveAs( saveName, saveOpts );
        • 2. Re: Java Script to Save ai to PDF with password...
          Qwertyfly... Level 4
          This needs a lot of work.
          too many errors with the code to list.
          it needs to be re written from scratch.
          give this a bash.
          //          Save as LOCKED pdf
          //          Qwertyfly
          //          03/07/2015
          //          Version 1.0
          //          Set your password here
          var pass = 'pink';
          if ( app.documents.length > 0 ) {       //make sure we have a file open to work with
              if ( doc.fullName.toString().substr(doc.fullName.toString().lastIndexOf('.')) == ".ai" ){       //Make sure your working with an ai file
                  var myFile = new File(doc.fullName.toString().substr(0,doc.fullName.toString().lastIndexOf('.')) + ".pdf");
                  var saveOpts;
                  setSaveOptions();
                  saveFileToPDF(myFile);
              }else{alert("Active Document is not an '.ai' file")}
          }else{alert("No Document Open")}
          function saveFileToPDF(myFile){
              var originalInteractionLevel = userInteractionLevel;        //save the current user interaction level
              userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;      //Set user interaction level to suppress alerts
              doc.saveAs(myFile,saveOpts);        //Save File
              userInteractionLevel = originalInteractionLevel;        //Set user interaction level back to original settings
          function setSaveOptions(){
              //  Setup Save Options
              saveOpts.permissionPassword = pass;
          • 3. Re: Java Script to Save ai to PDF with password...
            Excellent.  Thank you Qwertyfly!
            • 4. Re: Java Script to Save ai to PDF with password...
              glad I could help you out.
              • 5. Re: Java Script to Save ai to PDF with password...
                Ah, one little thing keeps bugging me.  The code executes as it should.  However, I'm having trouble getting the proper compression down using CompressionQuality.AUTOMATICJPEGLOW with downsampling at 200.  The pdf size is still too big even after I set the quality to 200.  What am I missing?
                sample code for compression below:
                saveOpts.colorCompression = CompressionQuality.AUTOMATICJPEGLOW;
                saveOpts.colorDownsampling = 200;
                saveOpts.colorDownsamplingImageThreshold = 300;
                saveOpts.grayscaleCompression = CompressionQuality.AUTOMATICJPEGLOW;
                saveOpts.grayscaleDownsampling = 200;
                saveOpts.grayscaleDownsamplingImageThreshold = 300;
                saveOpts.monochromeDownsampling = 200;
                saveOpts.monochromeDownsamplingImageThreshold = 300;
                • 6. Re: Java Script to Save ai to PDF with password...
                  I'm not sure what you mean by too big.
                  doing a few tests. if I save manually entering the settings above, then save with the script also using the settings above I only get a difference of a few KB.
                  could be my test files.
                  not sure, but does it downsample images if preseveEditability = true?
                  set that to false and the file will be smaller.
                  but will lose editability. not an issue if you still have the .ai.
                  • 7. Re: Java Script to Save ai to PDF with password...
                    I got it down now.  I set the downsampling to 100 on all three sections and that did the trick.  Thanks anyway Qwerty.
                    • 8. Re: Java Script to Save ai to PDF with password...
                      hope you get good use from it
                      • 9. Re: Java Script to Save ai to PDF with password...
                        TerryMunger
                        Well done!!! Thanks!
                        Is it possible to open the encrypted PDF with JavaScript?
                        I've seen Illustrator JavaScript Reference, but I can't find any thing about opening encrypted PDF.
                        • 10. Re: Java Script to Save ai to PDF with password...
                          I responded to you Q on How to open the encrypted PDF with JavaScript?
                          without outside help from something like AHK I don't think this is possible.
                          • 11. Re: Java Script to Save ai to PDF with password...
                            Autobestickeren.com
                            Nice script!  But I have a problem when I change the word pink to my own password. It gives a syntax error 8; -> var pass = 'mypass';
                            What am I doing wrong?
                            • 12. Re: Java Script to Save ai to PDF with password...
                              Silly-V Adobe Community Professional
                              Can you make a screenshot of the error?
                              • 14. Re: Java Script to Save ai to PDF with password...
                                Autobestickeren.com Level 1
                                Aaah forget it, it's already working!
                                • 15. Re: Java Script to Save ai to PDF with password...
                                  It's because you had pretty quotes instead of basic quotes (') - yours are curly and slanted, but computer code only likes the blocky vertical ones.
