1 2 Previous Next 52 Replies Latest reply on Dec 12, 2018 5:41 PM by JaredCreel Branched to a new discussion.
    Audio Hardware Changes in Premiere Pro CC2015
    JaredCreel Level 1
      There seem to have been some big changes in the Audio Hardware preferences in the jump from CC 2014 to CC 2015.
      I am using Premiere on a MacPro. In CC 2014, under Audio Hardware, there is an ASIO Hardware section where I was able to set the Adobe Desktop Audio to "System Default Input/Output." This was perfect because if I changed my system output from headphones to line out, Premiere would follow suit.
      In CC 2015, that option has disappeared. There is a  Device Class dropdown, but the only option I'm given is "CoreAudio." In the default input and output options below there is no option to respect the system's input/output. Therefore, even if I have changed my system output to be line out, Premiere continues to just use the headphone output.
      Is it possible to get that old functionality in CC 2015? Am I just missing it somewhere? In the help documents for 2015, it seems to suggest ASIO hardware options are only available for Windows and CoreAudio only for Mac. Why is this the case? It was available in 2014. I would appreciate any insight or help in this matter.
      Screen Shot 2015-07-02 at 9.15.51 AM.pngScreen Shot 2015-07-02 at 9.16.26 AM.png
        • 1. Re: Audio Hardware Changes in Premiere Pro CC2015
          Vinay Dwivedi Adobe Employee
          Hi Jared,
          Please check the below link and check if it helps.
          Adobe Premiere Pro Help | Preferences
          //Vinay
          • 2. Re: Audio Hardware Changes in Premiere Pro CC2015
            JaredCreel Level 1
            Hi Vinay,
            I have indeed read that document. I mentioned in my original post that it seems to suggest ASIO hardware options are only available for Windows and CoreAudio only for Mac, though in CC 2014 I have settings for ASIO hardware that allows me to do what I need. I'm wondering where that option has gone (for Mac users I suppose) and if there is any way to get Premiere CC 2015 to handle the default input/output as it did in 2014.
            Jared
            • 3. Re: Audio Hardware Changes in Premiere Pro CC2015
              Hi jared,
              On CC 2014 it shows ASIO hardware so you might be using some ASIO supported hardware (recording device). An equivalent to ASIO on Mac OS X is CoreAudio, which was designed with low latency in mind and is the default driver on MAC.
              You can understand it in the same way as Premiere Pro is detecting that recording device as it is plugged in but MAC core Audio is communication with the same device using ASIO. This might be the case if Device fails to register as a core audio device and take a other way rount to communicate with the core audio (In your case you can say it is ASIO).
              ASIO wasn't meant to be used for playback purposes either way, it's meant for recording where you want to be able to set a low latency.
              In CC 2015, The complete audio stucture is Enhanced and it looks similar like Audiotion Preferences and gives you many recording and playback features (Hardware Backed) to set Master clock and set the Output and input device perfectly with desired sample rate.
              So, for now you cannot set your Desktop Audio to Default input/output as they both are now configured separeately in CC 2015.
              Hope this helps.
              //Vinay
              • 4. Re: Audio Hardware Changes in Premiere Pro CC2015
                kyle@jump
                I too am frustrated by this change.  I would change my system default several times a day to hear differences in mix between headphones and monitors, to spare other editors from hearing me work or to specifically share progress with others.  I have Quicksilver installed with a script to switch my system audio preference with the press of a single button, however that is now useless.
                For what reason can you not allow a default system audio option when CoreAudio is what the OS uses?
                This is an irritating step backwards.
                • 5. Re: Audio Hardware Changes in Premiere Pro CC2015
                  Hi Kyle,
                  Have you installed the latest update 9.0.1 for Premiere Pro CC 2015?
                  If not please try to update and check if the issue persists.
                  //Vinay
                  • 6. Re: Audio Hardware Changes in Premiere Pro CC2015
                    JaredCreel Level 1
                    Vinay,
                    I have updated to 9.0.1, and there is absolutely no change when it comes to the audio functionality.
                    Kyle and I share an identical dilemma. I have an Automator script that changes the system audio preference via keyboard shortcut. Like Kyle, switching between headphones so the entire office doesn't have to hear me editing and monitors to share progress with others is pretty common. In fact, I rolled back to CC 2014 entirely just because of this inconvenience.
                    Regardless of the reasons for "enhancing" the audio structure, having Premiere's audio output follow the system's default should be a feature, just as it had been for years through 2014. At the very least, just an option to return to CC 2014's audio functionality.
                    • 7. Re: Audio Hardware Changes in Premiere Pro CC2015
                      Hi Jared,
                      I can totally understand the issue that you are facing.
                      Is it possible to give some more information about the Scripts (Is it a Apple script used to control system volume) that you use to toggle playback/recording devices.
                      As you are aware that there are some significant changes made to Premiere Pro CC 2015 audio hardware preferences to make it more advanced and provide more controls.
                      This script is limited to Premiere Pro or can work with Audition as well. If yes, can you check if you get issues in Audition as well.
                      //Vinay
                      • 8. Re: Audio Hardware Changes in Premiere Pro CC2015
                        kyle@jump Level 1
                        Hi Vinay,
                        I have installed the latest update, but the options appear the same within Premiere under "Audio Hardware".
                        The script that I run contains the following commands.  I use QuickSilver to execute the command from a single keyboard button.  It is basically opening Mac OS system preferences, opening Sound, opening Output tab, and choosing either Headphones or Line Out.
                        tell application "System Preferences"
                          activate
                          set current pane to pane "com.apple.preference.sound"
                        end tell
                        tell application "System Events"
                          tell application process "System Preferences"
                          tell tab group 1 of window "Sound"
                          click radio button "Output"
                          if (selected of row 2 of table 1 of scroll area 1) then
                          set selected of row 1 of table 1 of scroll area 1 to true
                          set deviceselected to "Headphones"
                          else
                          set selected of row 2 of table 1 of scroll area 1 to true
                          set deviceselected to "Line Out"
                          end if
                          end tell
                          end tell
                        end tell
                        tell application "System Preferences" to quit
                        • 9. Re: Audio Hardware Changes in Premiere Pro CC2015
                          Hi Kyle,
                          Thanks for the information let me check the script on my machine and will let you know.
                          Also, please provide the screenshot of the audio hardware prefernces with the devices reflected ib the drop down for input/output and the devices connected to the machine for playback/recording
                          //Vinay
                          • 10. Re: Audio Hardware Changes in Premiere Pro CC2015
                            vjdiangelo
                            I am having the exact same issue and am also very frustrated that this past functionality has disappeared.  Having the ability to switch quickly between headphones and desktop speakers is very valuable when offices are in close proximity.  I had tried just switching the output within Premiere Pro, but by doing that I lose the ability to easily control the volume level.  Please fix this ASAP!
                            Vic
                            • 11. Re: Audio Hardware Changes in Premiere Pro CC2015
                              Jump Simulation Level 1
                              Indeed this is frustrating.  What I find amusing is that After Effects traditionally did not have the "System default" as an audio hardware option.  However, in CC 2015 After Effects now has this feature, yet it was stripped out of Premiere (where it is arguably more useful).
                              Adobe, please correct this.  Premiere will let you manually choose any of the system output options, so clearly it's not a limitation of excluding certain outputs.
                              • 12. Re: Audio Hardware Changes in Premiere Pro CC2015
                                vjdiangelo Level 1
                                Ha!  I hadn't noticed it there.  The other problem I'm now realizing is that since I determined I could just use the System Volume control with my powered Alesis Speakers I removed any kind of external volume control.  This new update now means that I can't control my desktop audio except with the audio mixer within Premiere!
                                This NEEDS to be fixed!  Adobe, please help!
                                • 13. Re: Audio Hardware Changes in Premiere Pro CC2015
                                  Nick_HE Level 1
                                  vjdiangelo is right, this is a ridiculous change.
                                  In our suites, we frequently switch between Headphones (when editing privately) and Line Out (when reviewing edits together). This used to be as simple as option-clicking the speaker icon in the OSX menu bar, and selecting the desired output (Premiere would obey, as it was set to System Default).
                                  Now we have to dig through preference panes every time we want to switch [edit: if we want to control volume, we also have to change the system's audio device]
                                  Am I missing something? Why wouldn't you want an option to obey the system-specified output device preference?
                                  • 14. Re: Audio Hardware Changes in Premiere Pro CC2015
                                    brendyeah Level 1
                                    Also looking for resolution here. I've always used an option-click on the system audio icon to switch from headphones to speakers for the very same reasons. This is a major step backwards for those who work in an area where they use both headphones and speakers regularly.
                                    • 15. Re: Audio Hardware Changes in Premiere Pro CC2015
                                      aland81090138
                                      I'm just chiming in to say that this annoying change happens on PC as well. It's a move for the worse in my workflow. Please address this soon Adobe.
                                      • 16. Re: Audio Hardware Changes in Premiere Pro CC2015
                                        octaviow99262779
                                        I found this forum because I am experiencing the exact same frustration. I just finished a session with a producer abbd had to repeatedly apologize for getting up and setting the audio levels manually since I have no control over levels when audio is mapped to line out; the only option for playing audio through my monitors.
                                        And going into preferences every time I want to toggle between headphones and speakers is a huge time waster. Please fix.
                                        Octavio
                                        PS For those on OSX who do not want to fuss with automator and scripts to toggle between headphones and speakers, you can option-click on the volume control (make sure you have selected 'show volume in menu bar' under audio preferences) and a drop down menu with all the available audio inputs and outputs will appear for.
                                        • 17. Re: Audio Hardware Changes in Premiere Pro CC2015
                                          bmac_14
                                          Is there an answer to this or is it just going to be ignored?  It's been 2 1/2 months since this thread was started and I haven't seen any type of solution or even a reasonable answer to why this changed.  I too am having to deal with this issue.  It is something that worked well and became "broken" when updated with no real reason why.  The fact that the option is in After Effects tells me that it should be possible.
                                          • 18. Re: Audio Hardware Changes in Premiere Pro CC2015
                                            Kevin-Monahan Adobe Employee
                                            Hello BMac,
                                            What you and everyone on this thread needs to do is to file a bug or the team will simply not know your frustration. I could mention the issue, but nothing does the job of a call to action better than a bug staring them in the face. I know it is frustrating, but really, the only way to move the needle on this one. Please file bugs here.
                                            EDIT: Appears there is a bug logged from our end but it would be great if you still filed a bug report so that all your suggestions will be included in the fix.
                                            BTW, the change was brought about in 9.0. As I understand it, some of the core software code was migrated from Audition to Premiere Pro.
                                            Kevin
                                            • 19. Re: Audio Hardware Changes in Premiere Pro CC2015
                                              Verite3923 Level 1
                                              Not to be rude, buts that's why we are here. We are explaining our problems right here on your forum. I don't understand how this isn't making it further down the line. It's not a bug, It's a missing feature that was there and now isn't. I have to apologize to clients daily because there is no option to mirror the system audio output. My mac is mow battling Premiere over the audio output. I'll be editing on headphones, switch over to the internet and now my audio is playing out of the mac pro, switch mac to headphones, and then I go back to Premiere and now my Premiere output is messed up again.
                                              It's unbelievably frustrating, and I'm sorry to say this but without one word back about trying to fix this, it makes us less likely to fill out any bug report because it doesn't seem like its doing any good.
                                              Heath
                                              • 20. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                derrick-fvco
                                                Just tacking on to what others have said - this is extremely annoying to have to go through several menus just to change the audio output. Can you explain why this is no longer tied to the system audio? I change from my headphones/speakers daily and it is the most cumbersome process to have to dig through menus and remember which output is which when switching between apps. For other people in this forum, the only thing I can think of as a temporary work around is an A/B Switch - Amazon.com : Sescom SES-IPOD-AB iPod Stereo Audio MP3 FLAC WMA Player A/B Switch 3.5mm (1/8) : Electronics
                                                • 21. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                  roberts92449685
                                                  Add me to the list.  Switching between headphones and speakers is such a common practice for editors that I find it hard to believe it could get past an Adobe update.  ADOBE, PLEASE FIX!!!
                                                  • 22. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                    carlh99561386
                                                    Add me too. This is beyond a joke.
                                                    • 23. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                      Please file a bug, Carl. There is no better way to voice a complaint.
                                                      Kevin
                                                      • 24. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                        Sorry, there is no list. We compile issues via bug reports. Please file one.
                                                        Kevin
                                                        • 25. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                          Hi Derrick,
                                                          Did you file a bug yet? Please do so.
                                                          Kevin
                                                          • 26. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                            octaviow99262779 Level 1
                                                            I filed both a feature request (one click audio switching) and a bug report (no audio playback control when audio mapped to line out) with link outs to this forum thread included.
                                                            O
                                                            • 27. Re: Audio Hardware Changes in Premiere Pro CC2015
                                                              stuartm73511210
                                                              I'd like to add my voice to this issue, and yes, I did file a feature request (I see this a new feature, not necessarily a bug). There really needs to be a "system default" option in the audio hardware settings (for both input and output really, but in this case, for output) that monitors the settings in OS X to determine which source to use as output. As others have already stated, I too use my headphones while assembling and editing before sharing with others for feedback when I switch to my external speakers so others can hear the audio. Since I'm new to using Premiere Pro for such a large project, this is the first time I've really had to deal with this issue and while I can work around it by switching settings in both OS X and Premiere Pro, I really shouldn't have to.
                                                              • 28. Re: Audio Hardware Changes in Premiere Pro CC2015
        bmac_14 Level 1
        So how long before a bug is actually fixed.  Especially a bug that doesn't really seem like a bug.  As has been noted, this featured existed before 9.0 in Premiere, and actually exists now in After Effects.  Telling people to continue to file bug reports is useless if it takes this long to fix.  Its been 8 months since the original post and about 6 months since you first asked about bug reports being filed.  That seems like a long time for a feature that we inexplicably removed from a previous version and still exists in another piece of software.
        • 29. Re: Audio Hardware Changes in Premiere Pro CC2015
        Verite3923 Level 1
        It's not a bug.. I don't understand how that's not getting across. It's a feature that was there, and is now not there. Plain and simple. I wish you guys were more honest and just say you won't bring back this feature.
        • 30. Re: Audio Hardware Changes in Premiere Pro CC2015
        vanessap5526110 Level 1
        Hey Folks,
        Not sure if this is helpful, but I've been having a similar issue with the volume controls & outputs not auto-detecting when I switch.
        I work on a Mac & the following seems to be working so far: Open 3 menus simultaneously: 1) on the Mac, system Preferences > Audio, 2) Premiere Pro CC > Preferences >Audio Hardware & 3) the Settings screen under the Audio Hardware menu.  It takes some fiddling with the setting combos, but so far it works - see below:
        : Screen Shot 2016-03-03 at 12.53.06 PM.png
        3 people found this helpful
        • 31. Re: Audio Hardware Changes in Premiere Pro CC2015
        Hi Verite,
        I am sorry you're still experiencing this issue that was brought about by a significant change in our audio hardware panel. The issue is logged from our side and we're working on a fix. Thanks for your patience.
        Kevin
        • 32. Re: Audio Hardware Changes in Premiere Pro CC2015
        bmac_14 Level 1
        Not to take anything away from what you've posted, as I'm sure it might be helpful to someone, this isn't helpful in solving the current issue in this thread.  In fact, it points to the actual problem.  If you wanted to change from those headphones to speakers, you'd switch your mac to line out and then have to do the same in the Adobe window.  It's a constant back and forth between multiple windows.  It's also a step back from the way it was in CC2014 (pre-9.0).
        The old way, there was an option that said, "system default input/output".  When that was selected, it would mirror your mac.  Thus when you switch from headphones to speakers on the mac, it automatically does it in Premiere.  In fact, After Effects still has the option as seen in my screenshot.  The fact that one of the Adobe staff marked this post as helpful as well as insisting it is a bug does not instill confidence that Adobe will ever in fact put back a feature that they removed for some odd reason.
        • 33. Re: Audio Hardware Changes in Premiere Pro CC2015
        Hi BMac,
        We had a major change in audio hardware settings. Sorry about that. I can't say when it will be fixed. That said, I'll be sure that this post is added to the bug and I'll try and get some clarity from the team as to when a fix might be expected.
        Kevin
        • 34. Re: Audio Hardware Changes in Premiere Pro CC2015
        Hi BMac,
        If it helps, I just added a link to this thread on the bug. I'm also tracking the issue.
        If there are workarounds, they could be marked as "Helpful." Don't intend to mislead you. Sorry.
        Kevin
        • 35. Re: Audio Hardware Changes in Premiere Pro CC2015
        Verite3923 Level 1
        I appreciate it. Your earlier replies made it seem like you were ignoring those of us that were pointing out that it's not a bug.
        • 36. Re: Audio Hardware Changes in Premiere Pro CC2015
        chrisjomo
        Just read this thread to find out how to get premier's audio to follow the system default and cant believe thats not an option. Such a pain to switch back and forth from headphones to speakers. Cant believe the solution is to buy a $35 A/B audio switch. Not impressed.
        • 37. Re: Audio Hardware Changes in Premiere Pro CC2015
        liamtwhite Level 1
        It's been a year now since this problem appeared and there doesn't seem to be any solution in sight.
        Is there anyone we can call to talk about the issue? Clearly the bug reports don't seem to be working.
        The most important thing I want to know as a consumer and professional user is if this issue is something that Adobe is even interested in fixing.
        • 38. Re: Audio Hardware Changes in Premiere Pro CC2015
        liamtwhite Level 1
        Just logged a feature request, but I'm not holding my breath.
        • 39. Re: Audio Hardware Changes in Premiere Pro CC2015
        Hi liamwhite,
        I added this thread to the bug. Please everyone, file bug reports or feature requests.
        Kevin
        1 2 Previous Next
