5 Replies Latest reply on Jul 4, 2015 11:31 AM by K.Daube
    Script OK in FM12/13, not in FM10/11
    K.Daube Level 2
      Dear friends and experts,
      I can run without problems any of my installed FMs (6 ... 13). The last installed was FM 13 aka 2015.
      In all FMs since version 10 I can run scripts - but have no clue which ESTK they are using.
      On drive C I find ExtendScript Toolkit CS4, ...CS5 and ...CS6. They have been installed with the various FMs
      When testing my script (developing in FM12) in FM 10 or 11 I get an error on line 11: undefined is not an object
      Which cure might be necessary to run the script also in older FMs?
      function CreateBibDoc () {
      // ----------------------------------------------- create new doc from template and fill it
      // returns created doc in function
        giLvlTrace += 1; ZTrace ("CreateBibDoc");
        var j, uniqueCitations= [], nUnique, nItems, insText, newDoc, pgf, textloc, j;
        var writeFile = GetDocPath () + gsCollectFile;
      // create array of unique citations and place them in the doc
        uniqueCitations = SortUnique (gasFndCitations);
        nUnique= uniqueCitations.length;
      // createa new file
        newDoc = OpenTemplate ();             // FM-10/11 error FM-12/13 OK
        pgf = newDoc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;  // get first pgf in flow
        for (j = 0; j < nUnique; j += 1) {
          textLoc = new TextLoc (pgf, 0);
          insText = uniqueCitations[j];
          newDoc.AddText (textLoc, "[["+insText+"]]"+ "\x08" + "{"+insText+"}"); // \t inserts a NL...
         if (j < nUnique -1){
          pgf = newDoc.NewSeriesPgf(pgf);               // add a paragraph
        giLvlTrace -= 1;
        return newDoc;
      } // --- end CreateBibDoc
      function OpenTemplate () {
      // ----------------------------------------------- Open template file
      // return the Open file in the function
        giLvlTrace += 1; ZTrace ("OpenTemplate");
        var tplDir, tplFile, openParams, openReturnParams, oFile;
        tplDir = GetScriptPath ();
        tplFile = tplDir + "\\" + gsTemplate;
      //  oFile = SimpleOpen (tplFile, true); // Opens the dir of the active document
        openParams = GetTplParams ();
        openReturnParams =  new PropVals();
        oFile = Open (tplFile, openParams, openReturnParams);
        giLvlTrace -= 1;
        return oFile;
      } // --- end OpenTemplate
        • 1. Re: Script OK in FM12/13, not in FM10/11
          rombanks Level 1
          Hi Klaus,
          I usually get this error when trying to run a script while it's open in ESTK and "Extendscript Toolkit CSx" is by mistake selected as the target application instead of FM.
          HTH,
          Roman
          • 2. Re: Script OK in FM12/13, not in FM10/11
            frameexpert Level 4
            Regarding Roman's response, you can add this to the top of your scripts to force the ExtendScript Toolkit to use the FrameMaker engine.
            #target framemaker
            -Rick
            • 3. Re: Script OK in FM12/13, not in FM10/11
              rombanks Level 1
              Hi Rick,
              BTW, for some reason, when a script is open in ESTK, this line does not change the target app to FM, as if ESTK ignores it.
              Best regards,
              Roman
              • 4. Re: Script OK in FM12/13, not in FM10/11
                K.Daube Level 2
                Rick, Roman: Thank You for answers. However...
                The #target instruction has no influence in my environment. As stated in various posts I can not run scripts from the ESTK. ESTK reports a "missing link".
                For example in FM-11 I get this error when first opening ESK with File > Scripts > New Script…, then opening the script in ESTK and run it.
                I get the same error when trying to do so with FM-12 or FM-13:FM13-ESTK6-target-error.png
                Hence I have the script open in my editor (EditPad Pro 7), save it. Then in FM I open the script catalgoue, refresh and run the script.
                IMHO the current problem is in the FM-10/11 engine. But I do not undestand the connection between FM ($HOME\ExtendScript.DLL) and C:\Program Files (x86)\Adobe\Adobe Utilities - CS6\ExtendScript Toolkit CS6 (which reports ESTK version 3.8.0.12).
                On my wife's mini-PC (small screen, slow)   with only 1 FM version installed, I can run scripts with ESTK . But I need to test in various FM versions ...
                Probably this ESTK version is to high for FM-10/11 (for the current problem) and I must find means to test with the lower versions (CS5: 3.5.1.59; CS4: 3.0.0.41). Unfortunately I have no success with virtual machines - they are awfully slow on my machine (ThinkPad T400 with docked peripherals). So my test environment may not be clean enough.
                • 5. Re: Script OK in FM12/13, not in FM10/11
                  K.Daube Level 2
                  I have found the source of the problem:
                  In OpenTemplate I open an FM12 file - there is no adeaquate error-handling for this
                  • Having changed the script-ini file to read a MIF-12 file instead, everything is OK
                  • However this creates a lot of error entries in the console log of FM-10 which will annoy the user.
                  • Hence I have to provide individual files (versions FM10 ... FMcurrent)
                  • Better yet, i provide an FM10 version of the template file. This does not create open error thanks to GetTplParams which sets (among others)
                  • j = GetPropIndex(params, Constants.FS_FileIsOldVersion);
                      params[j].propVal.ival = Constants.FV_DoOK;
                  So my problem is solved! Thanks for listening!
