1 Reply Latest reply on Jul 3, 2015 7:56 PM by ssprengel
    Camera Raw 9.1 will not read Canon 7D Mark II files properly
    silberpfil
      With the update to the CC2015 Versions all my Canon 7D Mark II can not be read properly anymore. The 5D Mark II files are opened properly.
      All pictures look like this when the integration process into Lightroom or the import via camera raw is started.
      What can I do?
        • 1. Re: Camera Raw 9.1 will not read Canon 7D Mark II files properly
          ssprengel Adobe Community Professional & MVP
          The raw data appears to be corrupted.  Usually this is a hardware problem, the camera, the card, the cable, the reader, the computer hard-disk, the computer-memory, are all possibilities.
          Try transferring the photos, again, using a different method (OS vs Adobe software) and see if the corruption is different.  If so then the transfer or computer components are likely iffy.  If the corruption is identical on another copy of the files transferred later, then the images are likely corrupted on the card, already, which is either the card or the camera.
