4 Replies Latest reply on Jul 5, 2015 7:53 AM by Obi-wan Kenobi
    TextWrangler, AppleScript and Grep search
    Obi-wan Kenobi Level 5
      Hi all,
      Not really an AppleScript scripter, I would need to automatize (with [AS], no [JS]) grep searches in TextWragler to clean XML files.
      My beginning is:
      tell application "TextWrangler"
        set result to find "aaa" searching in text window 1 options {search mode:grep}
        if (found of result) then
        set text of (found object of result) to grep substitution of "xxx"
        end if
        set result to find "bbb" searching in text window 1 options {search mode:grep}
        set text of (found object of result) to grep substitution of "yyy"
        end if
        set result to find "ccc" searching in text window 1 options {search mode:grep}
        set text of (found object of result) to grep substitution of "zzz"
        end if
      end tell
      That doesn't work. I get an error message:
      … when I execute the following script:
      Thanks in advance!
        • 1. Re: TextWrangler, AppleScript and Grep search
          … That seems to work better:
            tell document of text window 1
            find "aaa" options {search mode:grep}
            end if
            find "bbb" options {search mode:grep}
            end if
            end tell
          end tell
          … Now I would need to make it work in batch!  Thanks!
          • 2. Re: TextWrangler, AppleScript and Grep search
            … I'm going on:
                repeat with i in every line of document of text window 1
                 end if
                end repeat
                 end if
                end repeat
                 find "ccc" options {search mode:grep}
                 end if
                end repeat
              end tell
            end tell
            … But I have to launch the script x times!
            • 3. Re: TextWrangler, AppleScript and Grep search
              greenrookie Level 2
              Obi-wan, try this.
                  tell text 1 of text window 1
                      replace "aaa" using "xxx" options {search mode:grep, starting at top:true}
                      replace "bbb" using "yyy" options {search mode:grep, starting at top:true}
                      replace "ccc" using "zzz" options {search mode:grep, starting at top:true}
                  end tell
              end tell
              Greenrookie
              • 4. Re: TextWrangler, AppleScript and Grep search
                Hi greenrookie,
                So simple and so clever!
                It works fine! Thanks a lot!    Now I can add all the grep find-replace(s) as I want.
