Hi GlennWa and welcome to our community
1.) If I create a template and apply it to my topics, in theory,
everything between my HEAD tags is supposed to get added into my
topics, correct?
This is actually incorrect. What happens with a template is
that you can associate a header or footer that will be
inserted
into the affected topics. Templates are also used as a
starting off point. More information by
clicking
here.
2.) I apply a footer to all my topics, and these footers need to
contain links to the NEXT and PREVIOUS documents. (i.e. click on
"Next" to go to the next document, and click on "Prev" to go to the
Previous document.) Is there some way in RoboHelp to help with
putting in all the links? Is there some generic code I can place
inside each of the "Next" and "Prev" instances so I do not have to
manually insert all these links? Can't RoboHelp recognize the
'sequence' of documents?
This sounds like you are describing a browse sequence. Browse
sequeces are specially defined sequences you may create using
RoboHelp HTML. You may want to investigate the RoboHelp HTML help
file and look the browse sequence information over.
In any electronically distributed help file, there is really
no "sequence" of documents per se. It's never linear as in a
printed book. Only a collection of topics presented in any order
you choose to use.
Hopefully this helps... Rick
