4 Replies Latest reply on Sep 25, 2009 2:51 AM by SayMama
    Flash/Stratus and NAT traversal
    gerard.burnside
      I am creating a new topic because I did not want to keep hijacking the previous thread where I started a discussion on Stratus' ways to traverse NAT and hostile network environments:
      In TURN draft-08 it says (par.2.1) that TCP or TLS can be used to to carry the TURN messages between the client and the server; does the Flash client implement the possibility to use TCP or TLS transport to the TURN server? If yes how do we configure it to do so? If no is there a plan to implement this in the future (I'd be happy to help if you went open-source)?
      Unfortunately in most enterprise networks the NAT proxy will completely block out all UDP traffic, making rtmfp useless from within these networks; this is to me a big disadvantage when compared to google's videochat which is able to traverse such proxies (using TLS to their own TURN servers).
      Another issue I found with Flash 10 clients, is that they will only try to contact the stratus server from a single port, which does not work on many company-owned laptops where internal firewalls block most ports for UDP. Once again, google's videochat circumvents this by trying a set of local port numbers until it finds one that is not blocked.
      Is there any plan to implement such a behaviour in flash10?
      Thanks for any input, I appreciate the great improvements that rtmfp brings, I'm just a bit frustrated that we cannot make it go a little step further.
        • 1. Re: Flash/Stratus and NAT traversal
          gerard.burnside Level 1
          In short, I guess I'm basically asking for an ICE (STUN2+TURN) implementation that performs:
          1) Several STUN binding requests on a range of local ports (to bypass local firewalls),
          2) fallback on TLS or TCP for TURN relay in case no UDP packet reached its destination.
          3) Of course it would make people's life easier if the STUN2/TURN server was implemented at the stratus level, but that is not mandatory.
          I'm afraid that implementing the above is the only way to make rtmfp available to all users both from the corporate and the home worlds.
          • 2. Re: Flash/Stratus and NAT traversal
            matthewk4
            In order to provide the major advantages RTMFP has over RTMP (partially-reliable delivery, flow prioritization, advanced congestion control, IP address mobility, etc.) we must use UDP for client-server communication. Peer-to-peer communication must also use UDP, because almost all machines are now behind NAT devices and establishing TCP peer-to-peer connections works much less often than UDP peer-to-peer connections.
            The TURN proxy support was added for those enterprises that wish to open up Flash Player's ability to send/receive UDP without opening up UDP for all client applications.
            If you wish to build an application that uses a media relay that you (as the developer) provide for relaying media over TCP, we already have that support in the form of RTMP and RTMPT and using FMS as the media relay. That performs much better than trying to tunnel a protocol with its own congestion control and retransmission, like RTMFP, over a TCP channel.
            • 3. Re: Flash/Stratus and NAT traversal
              I was already in the process of implementing a fallback on rtmp/rtmpt, but what I have experienced so far is that rtmpt from corporate networks was not good enough in terms of latency to use for VOIP communications; sometimes it was ok for a little while, but most often it was just not good enough.
              Google's videochat on the contrary obtains good results with H264-SVC over TLS to bypass UDP-blocking proxies, so I guess I was hoping that Adobe would go in the same direction...
              Also what google is able to do with its TCP connection to a server, is to enable P2P trafffic within a corporate network although UDP is blocked between the enterprise and Internet.
              The current Adobe implementation cannot provide that, unless each company installs its own TURN server (but without auth it is going to be difficult to convince the IT departments).
              • 4. Re: Flash/Stratus and NAT traversal
                SayMama
                Hi Gerard
                We are currently building our own Google like plugin for the very reasons you mentioned in this post. I would be interested in getting your views on it, kavan@saymama.com if you are interested.
                Regards
                Kavan
