11 Replies Latest reply on Jul 6, 2015 2:28 PM by kglad
    Flash Canvas zoom and pan problem
    pedrom48110900
      I'm trying to make an interactive map with zoom and pan capabilities. The demo is in this url: test_zoom
      The zoom is made with the scroll wheel of the mouse, and the pan with click and drag.
      My problem is that I only want the photo (movie clip with instance name "map_mc") in the middle to zoom and pan, but all the objects move at the same time...
      I'm using the following script:
      canvas.addEventListener("mousewheel", MouseWheelHandler, false);
      canvas.addEventListener("DOMMouseScroll", MouseWheelHandler, false);
      var zoom;
      function MouseWheelHandler(ezoom) {
        if (Math.max(-1, Math.min(1, (ezoom.wheelDelta || -ezoom.detail))) > 0)
        zoom = 1.1;
        else
        zoom = 1 / 1.1;
        var local = stage.globalToLocal(stage.mouseX, stage.mouseY);
        stage.regX = local.x;
        stage.regY = local.y;
        stage.x = stage.mouseX;
        stage.y = stage.mouseY;
        stage.scaleX = stage.scaleY *= zoom;
        stage.update();
      stage.addEventListener("stagemousedown", function (emove) {
        var offset = {
        x: stage.x - emove.stageX,
        y: stage.y - emove.stageY
        stage.addEventListener("stagemousemove", function (ev) {
        stage.x = ev.stageX + offset.x;
        stage.y = ev.stageY + offset.y;
        stage.update();
        stage.addEventListener("stagemouseup", function () {
        stage.removeAllEventListeners("stagemousemove");
      I need urgent help with this script so that I move and zoom only the movie clip "map_mc".
      Thank you
        • 1. Re: Flash Canvas zoom and pan problem
          if you only want map_mc to move why are you assigning new x and y properties to the stage??
          • 2. Re: Flash Canvas zoom and pan problem
            pedrom48110900 Level 1
            Hello. Thank you for your reply.
            I'm new to flash and javascript and so I found a script in another example and tried to apply it in my project...
            What would be the changes I need to do?
            Thank you.
            • 3. Re: Flash Canvas zoom and pan problem
              try:
              var zoom;
                zoom = 1.1;
                else
                zoom = 1 / 1.1;
                stage.update();
                var offset = {
              map_mc.x = ev.stageX + offset.x;
              map_mc.y = ev.stageY + offset.y;
                stage.update();
              • 4. Re: Flash Canvas zoom and pan problem
                hello.
                it doesn't work... now the mouse scroll still works (although it continues to affect all the objects), and the click/drag doesn't work...
                I've placed the .fla file in a zip file on this url: http://www.buar.pt/madalena/test/test_zoom.zip
                • 5. Re: Flash Canvas zoom and pan problem
                  i don't download and correct files unless i'm hired.
                  free help i only offer via the adobe forums.
                  do you want to scale everything or just map_mc?
                  • 6. Re: Flash Canvas zoom and pan problem
                    ok. please accept my apologies for that.
                    regarding the project, I really just want to scale and drag the "map_mc" movie clip
                    thank you
                    • 7. Re: Flash Canvas zoom and pan problem
                      use:
                      var zoom;
                        zoom = 1.1;
                        else
                        zoom = 1 / 1.1;
                      map_mc.x = stage.mouseX;
                        map_mc.y = stage.mouseY;
                        map_mc.scaleX = map_mc.scaleY *= zoom;
                        stage.update();
                        var offset = {
                        x:  emove.stageX,
                        y: emove.stageY
                      map_mc.x = ev.stageX- offset.x;
                      map_mc.y = ev.stageY -offset.y;
                        stage.update();
                      • 8. Re: Flash Canvas zoom and pan problem
                        Sorry... Nothing moves... I tried also with "this.map_mc", but nothing happens, no drag and no zoom, the objects just stand still.
                        I appreciate your efforts. Sorry again.
                        • 9. Re: Flash Canvas zoom and pan problem
                          use:
                          var tl = this;
                          var zoom;
                            if (Math.max(-1, Math.min(1, (ezoom.wheelDelta || -ezoom.detail))) > 0){
                              zoom = 1.1;
                            } else {
                              zoom = 1 / 1.1;
                              tl.map_mc.x = stage.mouseX;
                              tl.map_mc.y = stage.mouseY;
                              tl.map_mc.scaleX = tl.map_mc.scaleY *= zoom;
                          stage.addEventListener("stagemousedown", downF);
                          function downF(e) {
                              tl.offset = {x:e.stageX, y:e.stageY, map_mcX:tl.map_mc.x, map_mcY:tl.map_mc.y};
                              stage.addEventListener("stagemousemove", stagemoveF);
                              stage.addEventListener("stagemouseup", stageupF);
                          function stageupF(e) {
                          function stagemoveF(e) {
                              tl.map_mc.x = tl.offset.map_mcX+e.stageX-tl.offset.x;
                              tl.map_mc.y = tl.offset.map_mcY+e.stageY-tl.offset.y;
                          • 10. Re: Flash Canvas zoom and pan problem
                            That's it! Great! You're a life saver!
                            test_zoom
                            • 11. Re: Flash Canvas zoom and pan problem
                              you're welcome.
