I currently own a copy of CS3, and I have tried this both ways- using the physical disc, and downloading from the Adobe website. I get to the second part of installation, and my computer will not recognize the "Content" disc, or the "bundle DVD". As far as I can see, this only contains html and pdf files. I have gone through all of the folders on this particular download/disc. I have tried to hit "OK" to continue on my installer because I have either inserted the disc, or pulled it up on my download. It will not allow me to move forward. I have attached several screen shots so you better understand my situation. Keep in mind I am running a clean version of Yosemite. It was on my machine at purchase. What do I need to do to move forward? Why will my computer not recognize this content as installable?
Hello Sarah,
Please refer the given link for download help : Download CS3 products
You can also refer : Unable to download CS3 Design Standard
Hope it helps.
Regards
Anushri Attre
Hello Sarah,
Hope it helps.
Regards
Anushri Attre
I have followed all of the steps, and everything is up to date on my system. What I am asking is what I need to do for my system to recognize this "bundle DVD". It is the second physical disc that says "Content". As I posted previously, it seems as though it is only text files, essentially. I need to know if I am failing to see something beyond this, and how I can continue with my installation.
The link you sent me for another forum post does not relate to my situation. I am not getting an error message, my system simply will not recognize the second disc so I cannot continue with installing either from your website or from my discs.
You can install full suite from the above given download link. But if you are unable to continue installation with the web link also, please specify what issue do you face?
You can also refer : https://helpx.adobe.com/creative-suite/release-note/creative-suite-3-design-premium.html#main_Instal...
https://helpx.adobe.com/creative-suite/kb/troubleshoot-installation-problems-creative-suite-5.html
Yosemite sometimes has problems, often related to "default" permissions needing to be changed
-one person's solution https://forums.adobe.com/thread/1689788
-and a Java update https://forums.adobe.com/thread/1507936
-update may break things https://forums.adobe.com/thread/1772260
