4 Replies Latest reply on Jul 7, 2015 11:06 PM by c.pfaffenbichler
    Brush Roundness + Angle
    polpla
      I am working on a custom HTML panel for controlling brush parameters to improve my workflow.
      By using the ScriptListener I was able to get a simple script to change the size of the brush dynamically.
      Unfortunately, ScriptListener does not update the script output when I change the brush roundness or the angle.
      Does anybody know the right parameters? I have been trying to figure them out with the documentation but all I got was a headache.
      Here is the js for rotation (what I am looking for is the equivalent for both roundness and angle):
      function setBrushSize(size) {
        var idSet = charIDToTypeID( "setd" );
        var idNull = charIDToTypeID( "null" );
        var idBrush = charIDToTypeID( "Brsh" );
        var idOrdinal = charIDToTypeID( "Ordn" );
        var idTarget = charIDToTypeID( "Trgt" );
        var idTo = charIDToTypeID( "T   " );
        var idBrushSize = stringIDToTypeID( "masterDiameter" );
        var idPixels = charIDToTypeID( "#Pxl" );
        var desc1 = new ActionDescriptor();
        var desc2 = new ActionDescriptor();
        var ref1 = new ActionReference();
        ref1.putEnumerated( idBrush, idOrdinal, idTarget );
        desc1.putReference( idNull, ref1 );
        desc2.putUnitDouble( idBrushSize, idPixels, size );
        desc1.putObject( idTo, idBrush, desc2 );
        executeAction( idSet, desc1, DialogModes.NO );
      Thanks in advance!
      Pol
        • 1. Re: Brush Roundness + Angle
          polpla Level 1
          Ok, after some more research I found the name of the parameter that I believe would change the angle of the brush: "brushPoseAngle".
          I found the name here:
          http://ps-scripts.cvs.sourceforge.net/viewvc/ps-scripts/xtools/xlib/PSConstants.js?revisio n=1.18
          Using this reference I try to create a function that would modify the brush angle, but I still have had no luck.
          Here is my failed attempt:
          function setBrushRotation(deg) {
            var idWhat = charIDToTypeID( "What" );
            var idBrushAngle = stringIDToTypeID( "brushPoseAngle" );
            var idAngle = charIDToTypeID( "#Ang" );
            desc2.putUnitDouble( idBrushAngles, idAngle, deg );
            desc1.putObject( idWhat, idBrush, desc2 );
          It is basically the one that I have working with brush size but this time replacing the new variable plus changing the units to angle instead of pixels.
          Any feedback welcome!
          Pol
          • 2. Re: Brush Roundness + Angle
            c.pfaffenbichler Level 9
            I think Mike Hale posted this code a while back, but it only applies to default round brush-tips, not sampled ones, erodible etc.
            #target photoshop
              function setBrushFeatures(Diameter,Hardness,Angle,Roundness,Spacing,Flipy,Flipx) {
              var ref = new ActionReference();
              ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
              var appDesc = executeActionGet(ref);
              var toolDesc = appDesc.getObjectValue(stringIDToTypeID('currentToolOptions'));
              var brushDesc = toolDesc.getObjectValue(stringIDToTypeID('brush'));
              if( brushDesc.hasKey(stringIDToTypeID('sampledData'))){
                  var SampleData = brushDesc.getString(stringIDToTypeID('sampledData'));
                var Name = brushDesc.getString(stringIDToTypeID('name'))
                  Hardness = undefined;
              }else{
                    if (Hardness == undefined) Hardness = brushDesc.getDouble(stringIDToTypeID('hardness'));
              if (Diameter == undefined) Diameter = brushDesc.getDouble(stringIDToTypeID('diameter'));
              if (Angle == undefined ) Angle = brushDesc.getDouble(stringIDToTypeID('angle'));
              if (Roundness  == undefined) Roundness = brushDesc.getDouble(stringIDToTypeID('roundness'));
              if (Spacing == undefined) Spacing = brushDesc.getDouble(stringIDToTypeID('spacing'));
              if (Flipy == undefined) Flipy = brushDesc.getBoolean(stringIDToTypeID('flipY'));
              if (Flipx == undefined) Flipx = brushDesc.getBoolean(stringIDToTypeID('flipX'));
              var SampleIntr = brushDesc.getBoolean(charIDToTypeID('Intr'));
                var desc = new ActionDescriptor();
                    ref.putEnumerated( charIDToTypeID( "Brsh" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                desc.putReference( charIDToTypeID( "null" ), ref );
              desc1.putDouble(stringIDToTypeID('diameter'), Diameter);
              if(Hardness != undefined) desc1.putDouble(stringIDToTypeID('hardness'), Hardness);
              desc1.putDouble(stringIDToTypeID('angle'), Angle);
              desc1.putDouble(stringIDToTypeID('roundness'), Roundness);
              desc1.putDouble(stringIDToTypeID('spacing'), Spacing);
              desc1.putBoolean(stringIDToTypeID('flipY'), Flipy);
              desc1.putBoolean(stringIDToTypeID('flipX'), Flipx);
              desc1.putString(stringIDToTypeID('sampledData'), SampleData);
              desc1.putString(stringIDToTypeID('name'), Name);
              desc1.putBoolean(charIDToTypeID('Intr'), SampleIntr);
                var desc5 = new ActionDescriptor();
                var idnull = charIDToTypeID( "null" );
                    var ref3 = new ActionReference();
                    var idBrsh = charIDToTypeID( "Brsh" );
                    var idOrdn = charIDToTypeID( "Ordn" );
                    var idTrgt = charIDToTypeID( "Trgt" );
                    ref3.putEnumerated( idBrsh, idOrdn, idTrgt );
                desc5.putReference( idnull, ref3 );
              var idsampledBrush = stringIDToTypeID( "sampledBrush" );
              desc5.putObject( charIDToTypeID( "T  " ), idsampledBrush, desc1 );
              executeAction( charIDToTypeID( "setd" ), desc5, DialogModes.NO );
            setBrushFeatures(undefined, undefined, 45, undefined, undefined, undefined, )
            • 3. Re: Brush Roundness + Angle
              polpla Level 1
              Thanks, c.pfaffenbichler!!
              I got it to work with the code you suggested from Mike Hale. One little detail, in line 52 there is a missing space in the "T  " command, should be "T   ".
              I cleaned up the code an label it for others who might be interested:
              function setBrushFeatures(Diameter, Hardness, Angle, Roundness, Spacing, Flipy, Flipx) {
                // get app object
                var appAR = new ActionReference();
                appAR.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                var app = executeActionGet(appAR);
                // get brush settings
                var brush = app.getObjectValue(stringIDToTypeID('currentToolOptions'))
                // set defaults if undefined (copies current brush values)
                if( brush.hasKey(stringIDToTypeID('sampledData'))){
                  var SampleIntr = brush.getBoolean(charIDToTypeID('Intr'));
                  var SampleData = brush.getString(stringIDToTypeID('sampledData'));
                  var Name = brush.getString(stringIDToTypeID('name'))
                }else if (Hardness == undefined) Hardness = brush.getDouble(stringIDToTypeID('hardness'));
                if (Diameter == undefined)       Diameter = brush.getDouble(stringIDToTypeID('diameter'));
                if (Angle == undefined )         Angle = brush.getDouble(stringIDToTypeID('angle'));
                if (Roundness  == undefined)     Roundness = brush.getDouble(stringIDToTypeID('roundness'));
                if (Spacing == undefined)        Spacing = brush.getDouble(stringIDToTypeID('spacing'));
                if (Flipy == undefined)          Flipy = brush.getBoolean(stringIDToTypeID('flipY'));
                if (Flipx == undefined)          Flipx = brush.getBoolean(stringIDToTypeID('flipX'));
                // action with the new parameters
                var paramsAD = new ActionDescriptor();
                paramsAD.putDouble(stringIDToTypeID('diameter'), Diameter);
                if(Hardness != undefined) paramsAD.putDouble(stringIDToTypeID('hardness'), Hardness);
                paramsAD.putDouble(stringIDToTypeID('angle'), Angle);
                paramsAD.putDouble(stringIDToTypeID('roundness'), Roundness);
                paramsAD.putDouble(stringIDToTypeID('spacing'), Spacing);
                paramsAD.putBoolean(stringIDToTypeID('flipY'), Flipy);
                paramsAD.putBoolean(stringIDToTypeID('flipX'), Flipx);
                  paramsAD.putString(stringIDToTypeID('sampledData'), SampleData);
                  paramsAD.putString(stringIDToTypeID('name'), Name);
                  paramsAD.putBoolean(charIDToTypeID('Intr'), SampleIntr);
                // action to modify brush
                var brushAD = new ActionDescriptor();
                var brushAR = new ActionReference();
                brushAR.putEnumerated( charIDToTypeID( "Brsh" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                brushAD.putReference( charIDToTypeID( "null" ), brushAR );
                // execute action to modify brush with the new parameters
                brushAD.putObject( charIDToTypeID( "T  " ), stringIDToTypeID( "sampledBrush" ), paramsAD );
                executeAction( charIDToTypeID( "setd" ), brushAD, DialogModes.NO );
              Thanks so much again!
              Pol
              • 4. Re: Brush Roundness + Angle
                Sorry, I have had problems like this before but had forgotten to check if the code had pasted intact.
