1) Grab the Uninstaller here:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
Run that first.
You also might want to make sure some of the known flash dependent apps are killed:
taskkill.exe /im plugin-container.exe /f
taskkill.exe /im firefox.exe /f
taskkill.exe /im iexplore.exe /f
taskkill.exe /im flash* /f
taskkill.exe /im battle* /f
taskkill.exe /im Steam* /f
:: added July 7 2015 the weather channel app
taskkill.exe /im TWC.Win7.exe /f
This is part of adobe's clean install process for win7
Next in the cmd window do the following on WIN7 ONLY DO NOT DO THIS ON WIN8, 8.X or higher:
ATTRIB -H -S -R C:\Windows\System32\Macromed\Flash /s /d
ATTRIB -H -S -R C:\Windows\SysWOW64\Macromed\Flash /s /d
rmdir "C:\Windows\System32\Macromed\Flash" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Adobe\Flash Player" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Macromedia\Flash Player" /s /q
IF exist C:\Windows\SysWOW64 rmdir "C:\Windows\SysWOW64\Macromed\Flash" /s /q
There is a lot here, and I have a BAT to to all of this myself from the uninstall through the reinstall and cleanup
Hope some of this helps out
I had the same issues. Some of the old version do not get properly uninstalled. I used the scripts below and it worked for our issues. You will need to download MsiZap.exe and uninstall_flash_player.exe.
Hope it helps.
SCRIPT 1
REM REMOVE OLD INSTALLER FILES
REM @ echo off
REM Log location and name. Do not use trailing slashes (\)
set version=18.0.0.209
set LOGPATH=%SystemDrive%\Logs
set LOGFILE=%computername%-FlashFix.log
REM Create the log directory if it doesn't exist
if not exist %LOGPATH% mkdir %LOGPATH%
REM start /wait \\PATH TO FILE\uninstall_flash_player.exe -uninstall
REM For ActiveX:
\\PATH TO FILE\MsiZap.Exe tw {047904BA-C065-40D5-969A-C7D91CA93D62}
\\PATH TO FILE\MsiZap.Exe tw {904CD3A3-7A9D-4932-8316-95A7A6D2FB4A}
\\PATH TO FILE\MsiZap.Exe tw {BC8AC77D-6A6F-491F-BEED-2958F09C6CAE}
\\PATH TO FILE\MsiZap.Exe tw {3CA17ADC-2146-49C2-A375-972BB57CF7F6}
\\PATH TO FILE\MsiZap.Exe tw {7C548501-3501-468A-A443-CC42F5B3626B}
\\PATH TO FILE\MsiZap.Exe tw {B21D5938-6B90-408B-B827-92F6E0E11B48}
\\PATH TO FILE\MsiZap.Exe tw {70F97130-DBF6-4885-854C-CC7A80FC65E1}
\\PATH TO FILE\MsiZap.Exe tw {2BE0DC49-FA94-4853-A62A-F1E02ECAA67E}
\\PATH TO FILE\MsiZap.Exe tw {465571A6-29A2-4D39-B77D-3A1F6C964B65}
\\PATH TO FILE\MsiZap.Exe tw {76121056-042F-4999-AB4E-7DEA83A0B3C9}
REM For Plugin:
\\PATH TO FILE\MsiZap.Exe tw {6CBBF19C-2B69-4143-81C4-D5B56D32088C}
\\PATH TO FILE\MsiZap.Exe tw {AF82C1A9-56DC-4CCD-A36C-CAE56D541DFA}
\\PATH TO FILE\MsiZap.Exe tw {10F0B906-1989-4F20-A93C-4C0F94C8DF9E}
\\PATH TO FILE\MsiZap.Exe tw {F1410A0A-8205-4D45-BF2B-9C7ACB2F4B24}
\\PATH TO FILE\MsiZap.Exe tw {61F2FFE4-56BA-4F5E-91FB-BD34F92E44CE}
\\PATH TO FILE\MsiZap.Exe tw {DC0C27E6-745B-4D0E-A2F7-47676BFAE25D}
\\PATH TO FILE\MsiZap.Exe tw {D901557E-8AF2-4F66-BE3C-B8C816397BD5}
\\PATH TO FILE\MsiZap.Exe tw {A37E9FA0-00FE-479D-9F62-E6E3DBA51D29}
\\PATH TO FILE\MsiZap.Exe tw {4D9C85A6-ABD3-497C-8612-A7F940FB6E63}
start /wait \\PATH TO FILE\Flash_install.bat
:END
Exit
SCRIPT 2
SET YOUR VERSION TO THE FOLDER IN SOFTWARE SHARE
set LOGFILE=%computername%-FlashInstall-%version%.log
IF EXIST %LOGPATH%\%LOGFILE% goto end
echo Flash Version:%version% >> %LOGPATH%\%LOGFILE%
msiexec /i "\\PATH TO FILE\%version%\install_flash_player_18_active_x.msi" /qn TRANSFORMS="\\PATH TO FILE\%version%\install_flash_player_18_active_x.mst"
echo Active X %errorlevel% >> %LOGPATH%\%LOGFILE%
msiexec /i "\\PATH TO FILE\%version%\install_flash_player_18_plugin.msi" /qn TRANSFORMS="\\PATH TO FILE\%version%\install_flash_player_18_plugin.mst" >>%LOGPATH%\%LOGFILE%
echo Plugin ERROR LEVEL %errorlevel% >> %LOGPATH%\%LOGFILE%
:end
exit
