8 Replies Latest reply on Jul 8, 2015 1:31 PM by core34 Branched to a new discussion.
    Flash Player 18.0.0.203 download issue
    core34
      The msi on Adobe Flash Player Distribution | Adobe is still version 18.0.0.194. When will this be fixed?
        • 1. Re: Flash Player 18.0.0.203 download issue
          maria__ Adobe Employee
          Hi core34,
          Please clear your browser cache and try again.
          Thank you.
          Maria
          • 2. Re: Flash Player 18.0.0.203 download issue
            core34 Level 1
            I flushed the IE cache and deleted all IE settings. Re-downloaded it and got a 1722 error when attempting to install. The exe works fine but I need the msi.
            • 3. Re: Flash Player 18.0.0.203 download issue
              core34 Level 1
              Seems to only be the ActiveX download. The Plugin msi installs the correct version.
              • 4. Re: Flash Player 18.0.0.203 download issue
                MNovitsch
                That is what i am seeing as well.
                • 5. Re: Flash Player 18.0.0.203 download issue
                  @core34,
                  Please provide the following log files using the instructions posted here The specified item was not found..
                  • FlashInstall.log file saved at C:\Windows\System32\Macromed\Flash.  If this is a 64-bit OS there's another FlashInstall.log file saved at C:\Windows\SysWow64\Macromed\Flash.  We require both from a 64-bit OS.
                  • The verbose MSI install log file from a machine this is happening on.
                  @MNovitsch
                  You're issue appears to be different from the OP, so I branched you're previous comment into a new thread, SCUP Download: "The operation has timed out." error downloading MSI installer.  Based on the information provided, the OP is able to download but the installation is failing, while the information you provided stated "Download file: https://fpdownload.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_play er_18_active_x.msi failed with message "The operation has timed out."".
                  Please reply to the other thread so that all posts pertaining to your issue are in one place.
                  Thank you.
                  Maria
                  • 6. Re: Flash Player 18.0.0.203 download issue
                    core34 Level 1
                    The cloud says it's currently unavailable.
                    • 7. Re: Flash Player 18.0.0.203 download issue
                      core34 Level 1
                      2015-7-8+18-8-41.673 [error] 1226 1062
                      =O====== M/18.0.0.194 2015-07-08+18-08-35.828 ========
                      0000 [I] 00000010 "C:\Users\OrrCM\AppData\Local\Temp\InstallAX_18_0_0_194.exe" -install -msi
                      0001 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0002 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0003 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                      0004 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                      0005 [I] 00000013
                      0006 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe
                      0007 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.dll
                      0008 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                      0009 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                      0010 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                      0011 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                      0012 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                      0013 [W] 00001106
                      0014 [W] 00001106
                      0015 [W] 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      0016 [I] 00000012
                      =X====== M/18.0.0.194 2015-07-08+18-08-44.510 ========
                      =O====== M/18.0.0.194 2015-07-08+18-22-46.265 ========
                      0000 [I] 00000010 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe -uninstall activex -msi
                      0001 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                      0002 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_194.ocx 5
                      0003 [I] 00000018
                      0004 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_194.ocx 5
                      0005 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe 5
                      0006 [I] 00000018
                      0007 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe 5
                      0008 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.dll 5
                      0009 [I] 00000018
                      0010 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.dll 5
                      0011 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0012 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                      0013 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0014 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                      0015 [W] 00001021
                      0016 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0017 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0018 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0019 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0021 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0022 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_194.ocx 5
                      0023 [I] 00000018
                      0024 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_194.ocx 5
                      0025 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.dll 5
                      0026 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.dll 5
                      0027 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe 5
                      0028 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe 5
                      0029 [I] 00000012
                      =X====== M/18.0.0.194 2015-07-08+18-22-46.508 ========
                      =O====== M/18.0.0.203 2015-07-08+18-23-15.344 ========
                      0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe" -refreshIEElevationPolicies
                      =X====== M/18.0.0.203 2015-07-08+18-23-15.353 ========
                      =O====== M/18.0.0.203 2015-07-08+18-23-05.465 ========
                      0000 [I] 00000010 "C:\Users\OrrCM\Downloads\install_flash_player_18_active_x.exe"
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0004 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0005 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0006 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0007 [I] 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
                      0008 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                      0009 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_194.ocx 5
                      0010 [I] 00000018
                      0011 [W] 00001015 C:\Windows\system32\Macromed\Flash\Flash32_18_0_0_194.ocx 5
                      0012 [I] 00000013
                      0013 [I] 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe
                      0014 [I] 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll
                      0015 [I] 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
                      0016 [I] 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
                      0017 [W] 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
                      0018 [W] 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
                      0019 [I] 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                      0020 [W] 00001106
                      0021 [W] 00001106
                      0022 [W] 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                      =X====== M/18.0.0.203 2015-07-08+18-23-22.161 ========
                      =O====== M/18.0.0.203 2015-07-08+19-16-41.341 ========
                      0000 [I] 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe" -maintain activex
                      0001 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0003 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0004 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0006 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0007 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0008 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0009 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0010 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe 5
                      0011 [I] 00000018
                      0012 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe 5
                      0013 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll 5
                      0014 [I] 00000018
                      0015 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll 5
                      0016 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
                      0017 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
                      0018 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
                      0019 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
                      0020 [W] 00001021
                      0021 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0022 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0023 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0024 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0025 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
                      0026 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
                      0027 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll 5
                      0028 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll 5
                      0029 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe 5
                      0030 [W] 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe 5
                      0031 [I] 00000012
                      =X====== M/18.0.0.203 2015-07-08+19-16-55.580 ========
                      =O====== M/18.0.0.194 2015-07-08+19-17-36.050 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+19-17-39.035 ========
                      =O====== M/18.0.0.194 2015-07-08+19-18-16.828 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+19-18-19.374 ========
                      =O====== M/18.0.0.194 2015-07-08+19-20-31.779 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+19-20-34.843 ========
                      =O====== M/18.0.0.194 2015-07-08+19-23-18.607 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+19-23-20.774 ========
                      =O====== M/18.0.0.194 2015-07-08+19-26-55.664 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+19-26-57.909 ========
                      =O====== M/18.0.0.194 2015-07-08+19-30-36.361 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+19-30-38.605 ========
                      =O====== M/18.0.0.194 2015-07-08+20-06-21.799 ========
                      0003 [E] 00001013
                      =X====== M/18.0.0.194 2015-07-08+20-06-24.149 ========
