0 Replies Latest reply on Jul 9, 2015 2:21 AM by giacomo.c
    Valorize actionScript Array with data coming from java backend server (BlazeDS)
    giacomo.c
      Hi all guys and thank you in advance.
      I'm a junior developer working for a little company and I have right here a java - flex (BlazeDS) project. My issue is to understand how a determined variable takes value when its respective java remoteObject is called. Below a little bit of code to make you understand:
      Home.as (Imported in Home.mxml)
      [Bindable] private var _listSearch:ArrayCollection = new ArrayCollection;
      private var _sql:String;
      private var _dm:DataManager;
      private function load_OnClick(event:Event):void {
           var _dm = new DataManager;
           _sql = "SELECT * from....";
           _dm.getData(_listSearch, _sql);   // In the Home.mxml I have a DataGrid with data provider _listSearch
      DataManager.as
      class DataManager {
           private var _service:RemoteObject;
           private var loCs:ChannelSet = new ChannelSet();
      public function DataManager() {
           _servizio = new RemoteObject("dataManager");
           loCs.addChannel(new AMFChannel("canale", "http://localhost:8080/MyProject/messagebroker/amf"));
           _servizio.channelSet = loCs;
               if(!_servizio.hasEventListener(ResultEvent.RESULT)) {
               _servizio.addEventListener(ResultEvent.RESULT, resultHandler);
            if(!_servizio.hasEventListener(FaultEvent.FAULT)) {
                _servizio.addEventListener(FaultEvent.FAULT, faultHandler);
      private function resultHandler(event:ResultEvent):void {
      var _result:ArrayCollection = new ArrayCollection;
      _result = event.result as ArrayCollection;
      public function getData(paResultVar:ArrayCollection, paSql:String):void {
      var _res:ArrayCollection = new ArrayCollection;
      _servizio.getData.send(_res, paSql); // Suppose I have a java class named DataManager with getData method who just do the query and return the                                      // result
      Than my doubt is that I have many method similar to getData who calls respective methods in DataManager.as who make the send() call to DataManager.java. But I have to find the result of all these call in resultEvent method! A button click can generate ten method calls wich have to valorize ten array... How can I know when resultEvent contains data of array number two, or three, or four...
      Please Help me guys and sorry for my english.
