4 Replies Latest reply on Jul 31, 2015 7:32 AM by MikeGondek
    any body knows how to add dimension to a square, circle, (geometric drawings) would you please let me know how. thanks (just in case someone answer). scripts. thanks
    miguel2566
      any body knows how to add dimension to a square, circle, (geometric drawings) would you please let me know how. thanks (just in case someone answer).Screen Shot 2015-07-09 at 9.43.39 AM.png
        • 1. Re: any body knows how to add dimension to a square, circle, (geometric drawings) would you please let me know how. thanks (just in case someone answer). scripts. thanks
          Silly-V Adobe Community Professional
          This was my very first experiment with a palette in Illustrator, which has to use BridgeTalk object.
          I figure, if it was ever going to see the light of day, it'll probably be on this thread.
          //============================= SPEC WRITER By Vasily ==========================//
          function main(){
          //---------------------------------------------------- Basic Functions
              function asSourceString(func){
                  return func.toSource().toString().replace("(function "+func.name+"(){","").replace(/}\)$/,"");
              function sendBTmsg(func, updateObj, resultFunc, resultFuncArgs){
                  if(updateObj==undefined){updateObj={self: 'nothing'}};
                  var updateObjName=updateObj.self;
                  if(updateObjName!=undefined){
                      var bt=new BridgeTalk;
                      bt.target='illustrator';
                      var btMsg=asSourceString(func);
                      for(all in updateObj){
                          if(all!='self'){
                              var rx=new RegExp(updateObjName+'\\.'+all,'g');
                              btMsg=btMsg.replace(rx,updateObj[all]);
                      bt.body=btMsg;
                      //$.write(btMsg);
                      bt.onResult=function(result){
                          if(resultFunc!=undefined){
                              resultFunc(result.body, resultFuncArgs);
                      bt.send();
                  } else {
                      $.writeln("Error, function 'sendBTmsg(func, updateOb)': the update object should have a 'self' property, indentifying its' name.");
              function CMYKtoRGB(c,m,y,k){
                  return [(1-(c/100))*(1-(k/100)),(1-(m/100))*(1-(k/100)),(1-(y/100))*(1-(k/100))];
              function drawFromObjString(objString, canvasArea){
                  var obj=eval(objString);
                  var canvas=canvasArea.graphics;
                  var counter=obj.total;
                  while(counter>=0){
                      for(all in obj){
                          if(all.match(/\d{1,2}$/g) && all.match(/\d{1,2}$/g)==counter){
                              var thisShp=obj[all];
                              var vectorPts=thisShp.pathPoints;
                              canvas.newPath(); canvas.moveTo(thisShp.pathPoints[0][0],thisShp.pathPoints[0][1]);
                              for(var j=0; j<vectorPts.length; j++){
                                  var thisAnchor=vectorPts[j];
                                  var x=thisAnchor[0], y=thisAnchor[1];
                                  canvas.lineTo(x,y);
                              canvas.closePath();
                              if(thisShp.fillColor!=null){
                                  var clr=thisShp.fillColor; //RGB only
                                  var myBrush=canvas.newBrush(canvas.BrushType.SOLID_COLOR,clr);
                                  canvas.fillPath(myBrush);
                              if(thisShp.strokeColor!=null){
                                  var clr=thisShp.strokeColor; //RGB only
                                  var myPen=canvas.newPen(canvas.PenType.SOLID_COLOR,[clr[0],clr[1],clr[2],1], thisShp.strokeWidth);
                                  canvas.strokePath(myPen);
                      counter-=1;
          //------------------------------------------------------------ Specific Functions
              function boo(){
                  alert("Howdy!!!");
              function doNothing(){
                  var nothing=function(){
                      return;
              function returnRefresh(){
                  outcome={
                      width: width,
                      height: height,
                      unitsName: unitsName,
                  }.toSource()
              function processRefresh(objString, args){
                  var uiStuff=args[0];
                  uiStuff.wE.text=obj.width+" "+obj.unitsName;
                  uiStuff.hE.text=obj.height+" "+obj.unitsName;
              //putSpecs() continued from paletteToAI() using 'item', 'left', 'top', 'right', 'bottom', 'width, 'height', 'unitsName', 'proportionFactor'
              function putSpecs(){
                  var specsLayer=null;
                  for(var i=0; i<doc.layers.length; i++){
                      var thisLayer=doc.layers[i];
                      if(thisLayer.name=="Specs_Layer"){
                          specsLayer=thisLayer;
                          thisLayer.locked=false;
                          thisLayer.visible=true;
                          break;
                  if(specsLayer==null){
                      specsLayer=doc.layers.add();
                      specsLayer.name="Specs_Layer";
                  function specLine(pt_1, pt_2, parent, orientation, color, textContents, specOffset, arrowType, proportionFactor){
                      var end_1=parent.pathItems.add();
                      var end_2=parent.pathItems.add();
                      var path=parent.pathItems.add();
                      var text=parent.textFrames.add(); text.contents=textContents;
                      var hd=10*proportionFactor;
                      var vd_1=4*proportionFactor;
                      var vd_2=6*proportionFactor;
                      if(orientation=='horizontal'){
                          if(arrowType==1){
                              end_1.setEntirePath([[pt_1[0]+hd,pt_1[1]],[pt_1[0]+hd,pt_1[1]+vd_1],[pt_1[0],pt_1[1]],[pt_1[0]+hd,pt_1[1]-vd_1],[pt_1[0]+hd,pt_1[1]]]);
                              end_2.setEntirePath([[pt_2[0]-hd,pt_2[1]],[pt_2[0]-hd,pt_2[1]+vd_1],[pt_2[0],pt_2[1]],[pt_2[0]-hd,pt_2[1]-vd_1],[pt_2[0]-hd,pt_2[1]]]);
                          } else {
                              end_1.setEntirePath([[pt_1[0],pt_1[1]],[pt_1[0],pt_1[1]+vd_2],[pt_1[0],pt_1[1]],[pt_1[0],pt_1[1]-vd_2],[pt_1[0],pt_1[1]]]);
                              end_2.setEntirePath([[pt_2[0],pt_2[1]],[pt_2[0],pt_2[1]+vd_2],[pt_2[0],pt_2[1]],[pt_2[0],pt_2[1]-vd_2],[pt_2[0],pt_2[1]]]);
                          path.setEntirePath([pt_1,pt_2]);
                          text.left=((pt_2[0]-pt_1[0])/2)+pt_1[0]-(text.width/2); text.top=pt_1[1]-(specOffset/2);
                      } else if(orientation=='vertical'){
                          if(arrowType==1){
                              end_1.setEntirePath([[pt_1[0],pt_1[1]-hd],[pt_1[0]-vd_1,pt_1[1]-hd],[pt_1[0],pt_1[1]],[pt_1[0]+vd_1,pt_1[1]-hd],[pt_1[0],pt_1[1]-hd]]);
                              end_2.setEntirePath([[pt_2[0],pt_2[1]+hd],[pt_2[0]-vd_1,pt_2[1]+hd],[pt_2[0],pt_2[1]],[pt_2[0]+vd_1,pt_2[1]+hd],[pt_2[0],pt_2[1]+hd]]);
                          } else {
                              end_1.setEntirePath([[pt_1[0],pt_1[1]],[pt_1[0]-vd_2,pt_1[1]],[pt_1[0],pt_1[1]],[pt_1[0]+vd_2,pt_1[1]],[pt_1[0],pt_1[1]]]);
                              end_2.setEntirePath([[pt_2[0],pt_2[1]],[pt_2[0]-vd_2,pt_2[1]],[pt_2[0],pt_2[1]],[pt_2[0]+vd_2,pt_2[1]],[pt_2[0],pt_2[1]]]);
                          text.left=pt_1[0]+(specOffset/2); text.top=((pt_2[1]-pt_1[1])/2)+pt_1[1]+(text.height/2);
                      end_1.stroked=true; end_1.strokeWidth=1; end_1.strokeColor=color; end_2.stroked=true; end_2.strokeColor=color; end_2.strokeWidth=1;
                      end_1.filled=true; end_1.fillColor=color; end_2.filled=true; end_2.fillColor=color;
                      path.stroked=true; path.filled=false; path.strokeColor=color;  path.strokeWidth=1;
                      text.textRange.characterAttributes.fillColor=color;
                  var markerColor;
                  if(INFO.colortype=='CMYKColor'){
                      markerColor=new CMYKColor();
                      markerColor.cyan=INFO.clr_1; markerColor.magenta=INFO.clr_2; markerColor.yellow=INFO.clr_3; markerColor.black=INFO.clr_4;
                  } else if(INFO.colortype=='RGBColor'){
                      markerColor=new RGBColor();
                      markerColor.red=INFO.clr_1; markerColor.green=INFO.clr_2; markerColor.blue=INFO.clr_3;
                  }  else if(INFO.colortype=='GrayColor'){
                      markerColor=new GrayColor();
                      markerColor.gray=INFO.clr_1;
                  var specGrp=doc.groupItems.add(specsLayer, ElementPlacement.PLACEATBEGINNING);
                  var time=new Date();
                  var hours=time.getHours();
                  var minutes=time.getMinutes();
                  var seconds=time.getSeconds();
                  if(seconds<10){seconds='0'+seconds;}
                  if(minutes<10){minutes='0'+minutes;}
                  var ampm=function(){
                      if(hours>12){
                          hours-=12;
                          return 'pm';
                      } else {
                          return 'am';
                  var specOffset=10, aT=INFO.arrowType;
                  specGrp.name=item.name+"_Specs_"+(hours)+":"+minutes+":"+seconds+ampm;
                  var wSpec=specGrp.groupItems.add(); wSpec.name="Width Spec";
                  specLine([left,bottom-specOffset],[right,bottom-specOffset], wSpec, 'horizontal', markerColor, "W: "+width+' '+unitsName,specOffset,aT,proportionFactor);
                  var hSpec=specGrp.groupItems.add(); hSpec.name="Height Spec";
                  specLine([right+specOffset,top],[right+specOffset,bottom], hSpec, 'vertical', markerColor, "H: "+height+' '+unitsName,specOffset,aT,proportionFactor);
                  outcome={
                      width: width,
                      height: height,
                  }.toSource()
              function getDefaultFill(){
                  outcome=null;
                  if(app.documents.length>0){
                      var doc=app.activeDocument;
                      try{
                          var df=doc.defaultFillColor, colorArray=[];
                          var type=df.typename;
                          if(type=="GrayColor"){
                              colorArray=[df.gray];
                          } else if(type=="RGBColor"){
                              colorArray=[df.red,df.green,df.blue];
                          } else if(type=="CMYKColor"){
                              colorArray=[df.cyan,df.magenta,df.yellow,df.black];
                          } else if(type=="GradientColor"){
                              alert("Sorry, no gradient colors allowed.");
                              type=null, colorArray=null;
                          } else if(type=="SpotColor"){
                              colorArray=df.spot.name;
                          } else if(type=="PatternColor"){
                              alert("Sorry, no Pattern colors allowed.");
                      } catch(e){
                          alert("Sorry, couldn't set spec color to current FillColor due to: "+e); type=null, colorArray=null;
                      outcome={
                          type: type,
                          colorArray: colorArray
                      }.toSource();
                  } else {
                      alert("There isnt an open document!");
              function processDefaultFill(objString, args){
                  var cE=args[0], info=args[1];
                  if(obj.type=="RGBColor"){
                      var clr=[
                          Math.round((obj.colorArray[0]/255)*100)/100,
                          Math.round((obj.colorArray[1]/255)*100)/100,
                          Math.round((obj.colorArray[2]/255)*100)/100
                      cE.pen=cE.penParent.newPen(cE.penParent.PenType.SOLID_COLOR,[clr[0],clr[1],clr[2],1],3);
                      cE.canvasG.hide(); cE.canvasG.show();
                      info.colortype='"'+obj.type+'"';
                      info.clr_1=obj.colorArray[0]; info.clr_2=obj.colorArray[1]; info.clr_3=obj.colorArray[2];
                  } else if(obj.type=="CMYKColor"){
                      var clr=CMYKtoRGB(obj.colorArray[0], obj.colorArray[1], obj.colorArray[2], obj.colorArray[3]);
                      info.clr_1=obj.colorArray[0]; info.clr_2=obj.colorArray[1]; info.clr_3=obj.colorArray[2]; info.clr_4=obj.colorArray[3];
                  } else if(obj.type=="GrayColor"){
                      var grayValue=1-(Math.round(((obj.colorArray[0]/100)*255)*100)/100)/255;
                      var clr=[grayValue, grayValue, grayValue];
              function drawArrows(canvas, myPen){
                  var ofstL=10, ofstR=80, top_1=15, top_2=43;
                  canvas.newPath(); canvas.moveTo(ofstL,top_1); canvas.lineTo(ofstR,top_1); canvas.closePath(); canvas.strokePath(myPen);
                  canvas.newPath(); canvas.moveTo(ofstL,top_1); canvas.lineTo(ofstL,top_1+3); canvas.lineTo(ofstL-3,top_1); canvas.lineTo(ofstL,top_1-3);
                  canvas.newPath(); canvas.moveTo(ofstR,top_1); canvas.lineTo(ofstR,top_1+3); canvas.lineTo(ofstR+3,top_1); canvas.lineTo(ofstR,top_1-3);
                  canvas.newPath(); canvas.moveTo(ofstL-2,top_2); canvas.lineTo(ofstR+2,top_2); canvas.closePath(); canvas.strokePath(myPen);
                  canvas.newPath(); canvas.moveTo(ofstL-2,top_2-5); canvas.lineTo(ofstL-2,top_2+5); canvas.closePath(); canvas.strokePath(myPen);
                  canvas.newPath(); canvas.moveTo(ofstR+2,top_2-5); canvas.lineTo(ofstR+2,top_2+5); canvas.closePath(); canvas.strokePath(myPen);
              // Main messenger function
              function paletteToAI(){
                  outcome=null;
                      var sel=doc.selection;
                      if(sel.length>0){
                          var top,left,bottom,right;
                          if(sel.length>1){
                              alert("selection items : "+sel.length);
                          } else {
                              var item=sel[0];
                              left=item.visibleBounds[0];
                              top=item.visibleBounds[1];
                              right=item.visibleBounds[2];
                              bottom=item.visibleBounds[3];
                              var cv=1*INFO.unitsRatio;
                              var decimals=Math.pow(10,INFO.decimals);
                              var pointWidth=-1*(left-right);
                              var pointHeight=top-bottom;
                              var width=Math.round(-1*(left-right)*cv*decimals)/decimals;
                              var height=Math.round((top-bottom)*cv*decimals)/decimals;
                              var unitsName=INFO.unitsName;
                              var proportionFactor=function(){
                                  var num=(pointWidth<pointHeight) ? pointWidth:pointHeight;
                                  if(num>72){
                                      return 1;
                                  } else {
                                      return (num>10) ? num/72:10/72;
                              INFO.procedure;
                      } else {
                          alert("Please select an Art Object...");
                          outcome=null;
                  } else {
                      outcome=null;
          //------------------------------------------------------------------------Staying Variables
              var os=function(){
                  if($.os.match('Windows')){
                      return 'Windows';
                  } else {
                      return 'Mac';
              var version=parseInt(app.version);
              var UNITS={
                  self: "UNITS",
                  _in: {ratio: 1/72, name: '"in"'},
                  _mm: {ratio: 0.352777778, name: '"mm"'},
                  _pt: {ratio: 1, name: '"pt"'}
              var INFO={
                  self: "INFO",
                  unitsRatio: UNITS._in.ratio,
                  unitsName: UNITS._in.name,
                  procedure: asSourceString(doNothing),
                  decimals: 3,
                  colortype: '"CMYKColor"',
                  clr_1: 0,
                  clr_2: 100,
                  clr_3: 100,
                  clr_4: 0,
                  arrowType: 1,
              var uiStuff={};
              var colorElements={};
          //------------------------------------------------------------------------Palette----------------------------------------------------------------//
              var controlPalette=function(){
                  var logo="({total: 33, shape_33:{pathPoints:[[175, 7], [100, 7], [100, 6], [98, 6], [93, 6], [91, 6], [91, 7], [84, 7], [84, 6], [82, 6], [77, 6], [75, 6], [75, 7], [34, 7], [31, 5], [29, 5], [24, 5], [22, 5], [20, 7], [17, 7], [5, 28], [5, 29], [20, 29], [22, 31], [24, 31], [29, 31], [31, 31], [34, 29], [36, 29], [36, 31], [38, 31], [38, 31], [40, 31], [40, 29], [49, 29], [49, 31], [51, 31], [59, 31], [61, 31], [61, 29], [62, 29], [64, 31], [66, 31], [70, 31], [72, 31], [74, 29], [79, 29], [79, 31], [81, 31], [86, 31], [87, 31], [88, 31], [89, 31], [94, 31], [97, 31], [97, 29], [101, 29], [101, 31], [103, 31], [104, 31], [106, 31], [106, 29], [108, 29], [108, 31], [111, 31], [111, 31], [113, 31], [113, 29], [114, 29], [114, 31], [116, 31], [117, 31], [119, 31], [119, 29], [124, 29], [124, 31], [126, 31], [127, 31], [129, 31], [129, 29], [133, 29], [133, 31], [135, 31], [143, 31], [145, 31], [145, 29], [146, 29], [146, 31], [148, 31], [149, 31], [151, 31], [151, 29], [154, 29], [154, 31], [156, 31], [156, 31], [158, 31], [158, 29], [163, 29]], fillColor:null, strokeColor:[0.69, 0.7, 0.59], strokeWidth: 3}, "+
                  "shape_32:{pathPoints:[[17, 7], [5, 28], [5, 29], [163, 29], [175, 7]], fillColor:[0, 0.84, 0.87], strokeColor:null},"+
                  "shape_31:{pathPoints:[[19, 28], [22, 31], [29, 31], [32, 28], [32, 19], [29, 16], [23, 16], [23, 9], [29, 9], [29, 11], [32, 11], [32, 8], [29, 5], [22, 5], [19, 8], [19, 17], [22, 20], [29, 20], [29, 27], [23, 27], [23, 25], [19, 25]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_30:{pathPoints:[[43, 10], [36, 10], [36, 31], [38, 31], [38, 22], [43, 22], [46, 20], [46, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_29:{pathPoints:[[45, 19], [38, 19], [38, 13], [45, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_28:{pathPoints:[[59, 13], [59, 10], [49, 10], [49, 31], [59, 31], [59, 28], [52, 28], [52, 22], [56, 22], [56, 19], [52, 19], [52, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_27:{pathPoints:[[72, 16], [72, 13], [70, 10], [64, 10], [62, 13], [62, 28], [64, 31], [70, 31], [72, 28], [72, 25], [69, 25], [69, 28], [65, 28], [65, 13], [69, 13], [69, 16]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_26:{pathPoints:[[77, 10], [80, 27], [79, 27], [79, 31], [86, 31], [86, 27], [84, 27], [87, 22], [89, 27], [87, 27], [87, 31], [94, 31], [94, 27], [93, 27], [96, 10], [98, 10], [98, 6], [91, 6], [91, 10], [93, 10], [90, 21], [89, 13], [87, 13], [83, 21], [80, 10], [82, 10], [82, 6], [75, 6], [75, 10]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_25:{pathPoints:[[111, 13], [109, 10], [101, 10], [101, 31], [104, 31], [104, 22], [108, 22], [108, 31], [111, 31], [111, 21], [111, 21], [111, 20]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_24:{pathPoints:[[111, 19], [104, 19], [104, 13], [111, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_23:{pathPoints:[[114, 10], [114, 31], [117, 31], [117, 10]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_22:{pathPoints:[[120, 10], [120, 13], [124, 13], [124, 31], [127, 31], [127, 13], [130, 13], [130, 10]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_21:{pathPoints:[[143, 13], [143, 10], [133, 10], [133, 31], [143, 31], [143, 28], [136, 28], [136, 22], [140, 22], [140, 19], [136, 19], [136, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_20:{pathPoints:[[156, 13], [154, 10], [146, 10], [146, 31], [149, 31], [149, 22], [154, 22], [154, 31], [156, 31], [156, 21], [156, 21], [156, 20]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_19:{pathPoints:[[156, 19], [149, 19], [149, 13], [156, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_18:{pathPoints:[[22, 28], [24, 31], [31, 31], [34, 28], [34, 19], [31, 16], [25, 16], [25, 9], [31, 9], [31, 11], [34, 11], [34, 8], [31, 5], [24, 5], [22, 8], [22, 17], [24, 20], [31, 20], [31, 27], [25, 27], [25, 25], [22, 25]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_17:{pathPoints:[[74, 16], [74, 13], [72, 10], [66, 10], [64, 13], [64, 28], [64, 29], [66, 31], [72, 31], [74, 29], [74, 28], [74, 25], [71, 25], [71, 28], [67, 28], [67, 13], [71, 13], [71, 16]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_16:{pathPoints:[[51, 10], [51, 31], [61, 31], [61, 28], [54, 28], [54, 22], [58, 22], [58, 19], [54, 19], [54, 13], [61, 13], [61, 10]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_15:{pathPoints:[[45, 10], [38, 10], [38, 31], [40, 31], [40, 22], [45, 22], [48, 20], [48, 13]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_14:{pathPoints:[[45, 19], [40, 19], [40, 13], [45, 13]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_13:{pathPoints:[[79, 10], [82, 27], [81, 27], [81, 31], [88, 31], [88, 27], [86, 27], [89, 22], [91, 27], [89, 27], [89, 31], [97, 31], [97, 27], [95, 27], [98, 10], [100, 10], [100, 6], [93, 6], [93, 10], [95, 10], [92, 21], [89, 13], [85, 21], [82, 10], [84, 10], [84, 6], [77, 6], [77, 10]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_12:{pathPoints:[[113, 13], [111, 10], [103, 10], [103, 31], [106, 31], [106, 22], [111, 22], [111, 31], [113, 31], [113, 21], [113, 21], [113, 20]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_11:{pathPoints:[[106, 19], [106, 13], [111, 13], [111, 19]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_10:{pathPoints:[[116, 10], [116, 31], [119, 31], [119, 10]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_9:{pathPoints:[[122, 10], [122, 13], [126, 13], [126, 31], [129, 31], [129, 13], [132, 13], [132, 10]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_8:{pathPoints:[[145, 13], [145, 10], [135, 10], [135, 31], [145, 31], [145, 28], [138, 28], [138, 22], [142, 22], [142, 19], [138, 19], [138, 13]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_7:{pathPoints:[[158, 13], [156, 10], [148, 10], [148, 31], [151, 31], [151, 22], [156, 22], [156, 31], [158, 31], [158, 21], [158, 21], [158, 20]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_6:{pathPoints:[[151, 19], [151, 13], [156, 13], [156, 19]], fillColor:[0.94, 0.35, 0.16], strokeColor:null}, "+
                  "shape_5:{pathPoints:[[45, 13], [45, 19], [43, 19], [43, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_4:{pathPoints:[[156, 13], [156, 19], [154, 19], [154, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_3:{pathPoints:[[111, 13], [111, 19], [108, 19], [108, 13]], fillColor:[0.62, 0.18, 0], strokeColor:null}, "+
                  "shape_2:{pathPoints:[[43, 19], [40, 19], [40, 13], [43, 13]], fillColor:[0, 0.84, 0.87], strokeColor:null}, "+
                  "shape_1:{pathPoints:[[108, 19], [106, 19], [106, 13], [108, 13]], fillColor:[0, 0.84, 0.87], strokeColor:null}, "+
                  "shape_0:{pathPoints:[[154, 19], [151, 19], [151, 13], [154, 13]], fillColor:[0, 0.84, 0.87], strokeColor:null}})";
                  var w= new Window('palette','Spec Writer™',undefined,{closeButton:true}); w.margins=[5,3,5,8]; w.spacing=2;
                  var logoG=w.add('group');
                      var logoP=logoG.add('panel',[0,0,184,40],'',{borderStyle: 'sunken'});
                      logoP.onDraw=function(){
                          drawFromObjString(logo, this);
                  var tabG=w.add('tabbedpanel');
                      var controlsG=tabG.add('tab',undefined,'Controls');
                          var unitsG=controlsG.add('group'); unitsG.orientation='row';
                              var unitsH=unitsG.add('statictext',undefined,'Units:');
                              var unitsDD=unitsG.add('dropdownlist',undefined,['in','mm','pt']); unitsDD.selection=unitsDD.items[0];
                          var decimalsG=controlsG.add('group');
                              var decimalsH=decimalsG.add('statictext',undefined,'Decimals:');
                              var decimalsDD=decimalsG.add('dropdownlist',undefined,[0,1,2,3,4]); decimalsDD.selection=decimalsDD.items[3];
                          var selObjG=controlsG.add('panel',undefined,'Target Object(s):'); selObjG.size=[150,140];
                              if(os=='Windows'){
                                  selObjG.size=[150,120];
                              if(os=='Mac' && version<17){
                                  selObjG.margins=[4,30,4,4];
                              } else {
                                  selObjG.margins=[4,20,4,4];
                              var wG=selObjG.add('group');
                                  var wH=wG.add('statictext',undefined,'Width');
                                  var wE=wG.add('edittext',undefined,'',{readonly:true}); wE.characters=10;
                              var hG=selObjG.add('group');
                                  var hH=hG.add('statictext',undefined,'Height');
                                  var hE=hG.add('edittext',undefined,'',{readonly:true}); hE.characters=10;
                              var refreshBtn=selObjG.add('button',undefined,'Capture Object');
                      var optsG=tabG.add('tab',undefined,'Options');
                          var specArrowP=optsG.add('panel',undefined,"Arrows:"); specArrowP.orientation='row'; specArrowP.size=[164,90];
                              var arrowSelect=specArrowP.add('group',[0,10,20,60]); arrowSelect.orientation='column';
                                  var type_1=arrowSelect.add('radiobutton',undefined); type_1.value=true;
                                  var type_2=arrowSelect.add('radiobutton',undefined);
                                  arrowSelect.addEventListener('mousedown',function(ev){
                                      if(ev.target==type_1){
                                          type_2.value=false; type_1.value=true; INFO.arrowType=1;
                                      } else if(ev.target==type_2){
                                          type_1.value=false; type_2.value=true; INFO.arrowType=2;
                              var specArrowG=specArrowP.add('group'); specArrowG.size=[90,60];
                              if(os=='Windows'){
                                  arrowSelect.margins=[2,3,2,2];
                                  var windowsGroupShowingCrap=specArrowG.add('statictext',undefined,'');
                              var arrowPic=specArrowG.graphics;
                              colorElements.pen=arrowPic.newPen(arrowPic.PenType.SOLID_COLOR,[1,0,0,1],3);
                              specArrowG.onDraw=function(){
                                  var myPen=colorElements.pen;
                                  drawArrows(arrowPic,myPen);
                          var colorChoicesP=optsG.add('panel',undefined,'Colors');
                          var colorChoicesG=colorChoicesP.add('group'); colorChoicesP.size=[164,100]; colorChoicesP.margins=[2,20,2,2];
                              if(os=='Windows'){colorChoicesP.size=[164,80];}
                              var red=colorChoicesG.add('panel'); var redG=red.add('group'); red.margins=[0,0,0,0]; redG.size=[16,10];
                              red.graphics.backgroundColor=red.graphics.newBrush(red.graphics.BrushType.SOLID_COLOR,[1,0,0]);
                              red.helpTip="CMYK Red: C: 0, M: 100, Y: 100, K: 0"; red.colortype='"CMYKColor"'; red.clr_1=0; red.clr_2=100; red.clr_3=100; red.clr_4=0;
                              var cyan=colorChoicesG.add('panel'); var cyanG=cyan.add('group'); cyan.margins=[0,0,0,0]; cyanG.size=[16,10];
                              cyan.graphics.backgroundColor=cyan.graphics.newBrush(cyan.graphics.BrushType.SOLID_COLOR,[0,0.8,1]);
                              cyan.helpTip="CMYK Cyan: C: 100, M: 0, Y: 0, K: 0"; cyan.colortype='"CMYKColor"'; cyan.clr_1=100; cyan.clr_2=0; cyan.clr_3=0; cyan.clr_4=0;
                              var black=colorChoicesG.add('panel'); var blackG=black.add('group'); black.margins=[0,0,0,0]; blackG.size=[16,10];
                              black.graphics.backgroundColor=black.graphics.newBrush(black.graphics.BrushType.SOLID_COLOR,[0,0,0]);
                              black.helpTip="CMYK Black: C: 0, M: 0, Y: 0, K: 100"; black.colortype='"CMYKColor"'; black.clr_1=0; black.clr_2=0; black.clr_3=0; black.clr_4=100;
                              var yellow=colorChoicesG.add('panel'); var yellowG=yellow.add('group'); yellow.margins=[0,0,0,0]; yellowG.size=[16,10];
                              yellow.graphics.backgroundColor=yellow.graphics.newBrush(yellow.graphics.BrushType.SOLID_COLOR,[1,1,0]);
                              yellow.helpTip="CMYK Yellow: C: 0, M: 0, Y: 100, K: 0"; yellow.colortype='"CMYKColor"'; yellow.clr_1=0; yellow.clr_2=0; yellow.clr_3=100; yellow.clr_4=0;
                          var defaultFill=colorChoicesP.add('button',undefined,"Current Fill Color");
                          var colorChoices=[red,cyan,yellow,black];
                          for(var i=0; i<colorChoices.length; i++){
                              var thisColor=colorChoices[i];
                              thisColor.addEventListener('mousedown',function(){
                                  var clr=this.graphics.backgroundColor.color;
                                  colorElements.pen=arrowPic.newPen(arrowPic.PenType.SOLID_COLOR,[clr[0],clr[1],clr[2],1],3);
                                  specArrowG.hide(); specArrowG.show();
                                  INFO.colortype=this.colortype;
                                  INFO.clr_1=this.clr_1; INFO.clr_2=this.clr_2; INFO.clr_3=this.clr_3; INFO.clr_4=this.clr_4;
                  var specsBtn=w.add('button',undefined,"Put Specs");
          //------------------------------------------ Event Handlers
                  uiStuff.wE=wE;
                  uiStuff.hE=hE;
                  colorElements.penParent=arrowPic;
                  colorElements.canvasG=specArrowG;
                  defaultFill.addEventListener('mousedown',function(){
                      sendBTmsg(getDefaultFill, undefined, processDefaultFill, [colorElements, INFO]);
                  unitsDD.addEventListener('change',function(){
                      if(this.selection==null){
                          this.selection=this.items[0];
                  decimalsDD.addEventListener('change',function(){
                  refreshBtn.addEventListener('mousedown',function(){ // REFRESH
                      INFO.unitsRatio=UNITS['_'+unitsDD.selection.text].ratio;
                      INFO.unitsName=UNITS['_'+unitsDD.selection.text].name;
                      INFO.procedure=asSourceString(returnRefresh);
                      INFO.decimals=decimalsDD.selection.text;
                      sendBTmsg(paletteToAI, INFO, processRefresh,[uiStuff]);
                  specsBtn.addEventListener('mousedown',function(){ // Real Specs
                      INFO.procedure=asSourceString(putSpecs);
                  var windowObj={
                      w: w,
                      show: function(){this.w.show();},
                  return windowObj;
              controlPalette.show();
          #target illustrator
          #targetengine main
          main();
          • 4. Re: any body knows how to add dimension to a square, circle, (geometric drawings) would you please let me know how. thanks (just in case someone answer). scripts. thanks
            MikeGondek Adobe Community Professional & MVP
            WOW THANKS!
            Was looking for something better than the old add dimensions script I had which required creating a swatch called cutter.
