12 Replies Latest reply on Jul 14, 2015 10:02 AM by pixxxel schubser
    Selecting objects by colour and moving to another layer
    Sketch_Ak Level 1
      Hi there,
      I've managed to google together a script based off others that work in illustrator CS 5.5 but not in the latest version?
      Objectives of this script
      Step 1: Add Layer and call it "Register"
      Step 2: Select all objects based on colour called "Register" and move to layer called "Register"
      Step 3: Rename "Layer 1" to "Thru-cut"
      Step 4: Save and then close document.
      Could someone here have a look at the below script and let me know where its gone wrong? Below is also a screenshot of the script error in the latest version of illustrator.
      Thank you.
      var myLayer = myDoc.layers.add();
      myLayer.name = "Register";
      function getObjectsByColor ( colorName )
      var doc, items, i = 0, n = 0, item, color, selectionArray = [];
      if ( app.documents.length == 0 ){
          alert("No documents open");
          return;
      doc = app.activeDocument;
      try
          color = doc.swatches.getByName ( colorName );
      catch(e)
          alert( "No such color !");
          return;
      color = color.color ;
      items = doc.pageItems;
      n = items.length;
      if ( items.length == 0 )
          alert( "No items found");
          return;
      for ( i = 0; i < n ; i++ )
          item = items[i];
          if ( item.fillColor.typename == color.typename
          && item.fillColor.cyan == color.cyan
          && item.fillColor.magenta == color.magenta
          && item.fillColor.yellow == color.yellow
          && item.fillColor.black == color.black )
              selectionArray [ selectionArray.length ] = item;
              item = items[i];
      item.move( myLayer, ElementPlacement.PLACEATBEGINNING );
      if ( selectionArray.length == 0 )
          alert( "Nothing found" );
          return;
      app.selection = selectionArray;
      getObjectsByColor ("Register");
      function renameText() {
          if (app.documents.length == 0) return;
          var docRef = app.activeDocument;
          recurseLayers(docRef.layers);
          renameText();
      function recurseLayers(objArray) {
          for (var i = 0; i < objArray.length; i++) {
          objArray[i].name = objArray[i].name.replace(/\s*Layer 1\s*\d*/, 'Thru-cut');
          if (objArray[i].layers.length > 0) recurseLayers(objArray[i].layers);
      // save as
      var originalInteractionLevel = userInteractionLevel;
      userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
      saveFileToPDF ();
      function saveFileToPDF () {
          var doc = app.activeDocument;
          if ( app.documents.length > 0 ) {
              saveOpts = new PDFSaveOptions();
              saveOpts.compatibility = PDFCompatibility.ACROBAT5;
              saveOpts.generateThumbnails = true;
              saveOpts.preserveEditability = true;
              doc.save(saveOpts );
      userInteractionLevel = originalInteractionLevel;
      myDoc.close();
