1 Reply Latest reply on Jul 9, 2015 4:06 PM by A.T. Romano
    4K and elements 13
      Recently purchased a Panasonic DMC-FZ1000 which has 4K mp4 video capability, looking for a way to import into Elements 13 at 1080 50P AVCHD, shooting 4K as I can pull 8mb stills from the video..
        • 1. Re: 4K and elements 13
          A.T. Romano Level 7
          I do not understand the core of your question.
          If you have 4K video (3840 x 2160 @ 50 progressive frames per second AVCHD.mp4), you (manually) or the project (automatically) set the project preset to
          QFHD 16 x 9
          Is the video not importing when you bring it into the project using the project's Expert workspace Add Media/Files and Folders/Project Assets? Your priority in this project preset setting is the frame size unless you are going to need to do frame by frame by frame editing.
          When you go to export the Timeline and if want to be as close as possible for import to export, then
          XAVC-S with Presets = MP4 H.264 3840 x 2160 p25
          Then under the Advanced Button of the preset, customize (for PAL frame rate 50 progressive frames per second and as required bitrate).
          Please review and consider, and supply clarification and more details.
          Thank you.
