I attempted to download the Unbuntu version of flash through my software center but my software center says it doesn't exsists it was working fine till yesterday now I can't watch twitch streams. Youtube still works fine.
I mean to say I tried to download through the site which promted me to use my software center.
Hi ghostofkrows,
What version of Ubuntu and is this 32- or 64-bit?
We hand-off the bits to Canonical and they are the ones that make them available on the Ubuntu software center. When going to get.adobe.com/fashplayer and selecting 'APT for Ubuntu' you will be prompted to use the Software Center. When you select Software Center the update should be available. If not, you may need to update the repositories on your system. Although, I didn't do that and the update displayed in the Software Center as being available.
Select 'More info' and scroll down to see the version:
I have verified (with Ubuntu 14.04.1) that the bits are available on both 32- and 64-bit Ubuntu
Maria
I am running the 64-bit version. I am new to Linux and I have no Idea what you mean by update the repositories on your system. I have downloaded the latest version and all the updates it has told me to in the last few days.
Hi ghostofkrows,
What browser are you using?
What happens when you go to the Software Center (not Software Updater) and search for Flash?
This is from Ubuntu 14.04.1. If your version is different, it'll look slightly different.
Maria
this is where I go to download the update to Flashplayer I choose the option that is shown in this picture because it makes the most logical sense.
After choosing to use my software center (the only option available) this is the screen I get.
see if I search Adobe I can make the plugin appear too but it does absolutely nothing just brings up a bunch of comment from people having the same problem.
Hi ghostofkrows,
I'm not sure why it's not working when you go to get.adobe.comf/flashplayer. 'APT for Ubuntu 10.04+' is the correct option to select. I am not able to reproduce this behaviour. When I use that workflow, Adobe Flash Plugin is found in the Software Center. What version of Ubuntu are you using?
Your second screen shot indicates Flash Player is already installed, since the only option is 'Remove' (right-hand column). If Flash Player was not installed, the option would be 'Install' as in my screenshot in post #2.
In Firefox, go to about:plugins and see if Flash Player is listed. If so, what version is listed? 11.2.202.481 is the latest version, released earlier this week:
If you don't have 11.2.202.481 installed, do the following:
Maria
following your example I am supposedly up to date any thoughts?
Ok I have good news! I think.... Either way I was able to solve the problem I was experiencing. I followed the how to guide on twitch to resolve my grey screen of death problem. The solution was to turn off all my plug ins in my browser and turn them back on one at a time. Following this step I got it to work. I will provide with a screen shot to see if there is any reason why Flash would not work with these plug ins. secondly I tried what you suggested in the last response and it did nothing. As to say I downloaded the plug in but when I tried to "download" it for the chromium browser I got the could not find page again that I previously screen shotted. Anyway I can see the content so I am happy it is halfway working and for me that is good enough for now. Here is the screen shot of my plug ins I am pretty sure the are not malicious and I have not downloaded any plug ins myself these came with the browser.
Never mind that cleared up the problem but when I went to a different stream I experienced the same problem. I am going to repeat the steps you mentioned above after I delete Firefox I will attempt to reload Firefox and flash player and see if that solves it. I guess this means the problem is on my end though so I am zeroing in on a solution any help you provide would be useful.
still no fix still won't work right a gleam of hope but it is not meant to be. I migh zero my hard drive and reinstall ubuntu but I had hoped it would not come to this and still I don't think it will solve my problem.
