3 Replies Latest reply on Jul 28, 2015 2:29 PM by Dave LaRonde
    Importing ProRes files on Mac
    denism96121983 Level 1
      Hey folks!
      I just encountered the problem - I can not import files recorded in ProRes format on Mac...
      I have installed iOS 10.8.5 and AE CS5.5.
      ProRes files parameters are as follow:
      General
      Format                           : MPEG-4
      Format profile                 : QuickTime
      Codec ID                        : qt
      Overall bit rate mode       : Variable
      Overall bit rate                : 811 Mbps
      Writing library                : Apple QuickTime
      Video
      Format                         : ProRes
      Format version              : Version 0
      Format profile                : 422 HQ
      Codec ID                      : apch
      Duration                       : 8s 208ms
      Bit rate mode                : Variable
      Bit rate                        : 820 Mbps
      Width                          : 3 840 pixels
      Height                         : 2 160 pixels
      Display aspect ratio      : 16:9
      Frame rate mode          : Constant
      Frame rate                    : 29.970 fps
      Color space                  : YUV
      Chroma subsampling     : 4:2:2
      Scan type                     : Progressive
      Bits/(Pixel*Frame)         : 3.298
      Stream size                  : 802 MiB (99%)
      Writing library               : atms
      Language                      : English
      Color primaries                : BT.709
      Transfer characteristics       : BT.709
      Matrix coefficients            : BT.709
      Audio
      Format                      : PCM
      Format settings, Endianness    : Little
      Format settings, Sign        : Unsigned
      Codec ID                          : in24
      Duration                           : 8s 342ms
      Bit rate mode                    : Constant
      Bit rate                             : 4 608 Kbps
      Channel(s)                        : 4 channels
      Sampling rate                    : 48.0 KHz
      Bit depth                          : 24 bits
      Stream size                      : 1.15 MiB (0%)
      Language                         : English
      Other
      Type                               : Time code
      Format                           : QuickTime TC
      Duration                          : 8s 342ms
      Time code of first frame    : 11:29:03;24
      Time code, striped           : Yes
      Language                       : English
      Can you, please, help with this?
      Thank you in advance!
