1 Reply Latest reply on Jul 12, 2015 4:59 AM by Dave Merchant
    Adding metadata to thousands of photos?
    southwestform Level 1
      1. Is there an advantage to adding copyright info to photos in the camera vs. doing it in LR?
      2. How do you add copyright info to thousands of photos at the same time?
        • 1. Re: Adding metadata to thousands of photos?
          Dave Merchant MVP & Adobe Community Professional
          The basic metadata is stored in exactly the same place, so in that sense it doesn't matter - and people should do both.
          The only advantage in setting the in-camera menu is that the images on the card are tagged, so if for some reason you just send the card to a client (or someone borrows it...) you don't have orphan works floating about.
          There are many advantages to applying metadata afterwards, such as:
          • The in-camera menus are often limited, so they may not support non-English characters or longer strings.
          • You can assign copyright properly per-image (e.g. if you transfer copyright as part of a contract, or have some images owned by you personally and some by your company).
          • You can set the extended IPTC metadata defining the owner and licensees properly - names, addresses, phone numbers, links to EULAs, release numbers, etc. This is vital information for legally protecting your images in countries where the 'orphan works rule' applies, as if all you include is your name it's easy for an end user to claim they can't find you.
          In LR (and all other Adobe applications) setting metadata in bulk is easy - just build a metadata template and apply it to all your selected images. In LR you can do this during import, from the Library module, or during export. The only caveat is that metadata templates have no internal logic, so for example you can't make them look up the copyright year from the capture time.
