2 Replies Latest reply on Jul 13, 2015 8:37 AM by andreasr45946726
    select symbol on artboard and copy symbol name to art board name
    andreasr45946726
      I am generating icons in AI CS6
      I have AI files with 100 artboards
      Some art boards are still empty, while in progress.
      On most artboard I have the raw paths and on a separate layer called Symbols with one Symbol only.
      The symbol layer could be the only visible layer.
      100 symbols in the document.
      Now I want to copy those names to the art board names for export and to a text box on the art board for printing an overview.
      I found a script to rename a layer to its content - but it does not recognize symbols
      I found a script to rename an artboard to a layer
      I found a script to place a text box with the art board name on the art board.
      I cannot combine them, please help!
      I can do applescript and Filemaker scripting, but I am new to Javascript.
      Rename Layer to content - does not recognize Symbols!
      function LayerNameMatch() {
          if (app.documents.length == 0) {
              alert("No Open / Active Document Found");
          } else {
              var doc, i, l, ab, sel, n;
              doc = app.activeDocument;
              for (i = 0, l = doc.artboards.length; i < l; i++) {
                  ab = doc.artboards[i];
                  doc.artboards.setActiveArtboardIndex(i);
                  doc.selectObjectsOnActiveArtboard();
                  sel = doc.selection[0];
                  sel.parent.name = sel.name;
                  doc.selection = false;
      LayerNameMatch();
      Rename artboard to layer name:
      } else {
          var doc = app.activeDocument;
          if (doc.artboards.length == doc.layers.length && doc.layers.length == doc.artboards.length) {
              for (var i = 0, l = doc.artboards.length; i < l; i++) {
                  var ab = doc.artboards[i];
                  ab.name = doc.layers[i].name;
              alert("Finished:\nRenaming of Artboards to match Layer names is complete");
          } else {
              alert("Opps: This wont work!\n The number of Layers and Artboards do not match");
      Make a Textbox with art board name
         //This script takes a document's artboard names and prints them into each artboard.
          // Tell the script to only work on the open, focused document
          var myDocument = app.activeDocument;
                                              var idoc = app.activeDocument;
                                              var ilayer = idoc.layers.add();
                                              ilayer.name = "0 SeitenName";
          // STEP ONE: Create the labels for each artboard
          // grab ahold of the artboards
          for (var i = 0; i < app.activeDocument.artboards.length; i++)
                    var artboard = app.activeDocument.artboards[i];
                    // For each artboard, add a new text frame
                    var myLabel = myDocument.textFrames.add();
                    // fill it with the artboard name
                    myLabel.contents = artboard.name;
                    // this line controls the font size
                    myLabel.textRange.characterAttributes.size = 12;
                    // this line positions the text relative to each artboard
                    myLabel.position = [artboard.artboardRect[0], artboard.artboardRect[1]];
