• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
How to encode mp4 files to work with livepkgr
New Here ,
Jul 13, 2015 Jul 13, 2015
Hy guys,
I have 2 servers, Server 1 with FMS 4.5 and Server 2 with AMS 5 both on Ubuntu 14.04. On Server 1 a build a custom application, Server 2 uses just livepkgr for serving clients.
My appliction on Server 1 receive 3 streams from FMLE. In this application i have a "chain" of streams that carry out each stream independent. At the end of streams chain i republish each stream to Server 2 livepkgr application.
So, this is working great with live streams, i can serve RTMP, HTTP, HLS, HDS.
In Server 1 in the chain of streams i get a stream and play an mp4 file. The livepkgr application on Server 2 works well with this "switch" on RTMP, but the application don't record the stream, so on mobile i don`t see the switch... i see something green till the file ends and the stream that switched on file goes back on live.
I tried to encode a file with Adobe Media Encoder with H264 on profile Main and Level 3.2, and it works great on mobile too.
I tried to encode the same file with ffmpeg, handbreak... and doesent work on mobile.
So, i need a solution to re-encode files on linux and the output files to be good to work with AMS livepkgr application.
Thaks.
Views
893
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Aug 02, 2015 Aug 02, 2015
How exactly do you do relay, republish to the second server's livepkgr?
Votes
Translate
Translate
Report
Report
New Here ,
Aug 03, 2015 Aug 03, 2015
Well, that is a easy job, took me some time to do it. I found the solution here on forum.
Assume that you have a multi-bitrate stream, so you have 3 streams with 3 distinct names. Create a function on the server-side and send send every one of the streams to that function.
theStream1 = Stream.get(stream1);
  application.nc1 = new NetConnection();
  application.nc1.connect( "rtmp://example.com/livepkgr" );
  application.ns1 = new NetStream(application.nc1);
  application.ns1.onStatus = function(info){
  if (info.code == "NetStream.Publish.Start"){
  var repObj = new Object();
  repObj.local = "stream1";
  repObj.remoteStream = "republishStream1";
  repObj.remoteEvent = "republishEvent";
  application.ns1.setBufferTime(5);
  application.ns1.attach(theStream1);
  application.ns1.publish("republishStream1?adbe-live-event=republishEvent&adbe-record-mode=record", "live" );
  application.nc1.onBWDone = function(){
Votes
Translate
Translate
Report
Report
Explorer ,
Is that server-side app running on host server or on the edge (server 2)? Is this scheme resilient, eg will the app reconnect on network or encoder issues?
I am doing relay of rtmp streams (MBR encoded by fmle baseline/H264/aac) for livepkgr like this:
ffmpeg -v warning -re -i "rtmp://host/live/stream1 live=1" -c copy -flags +global_header -copyts -f flv rtmp://edge/livepkgr/stream1&adbe-live-event=liveevent
ffmpeg -v warning -re -i "rtmp://host/live/stream2 live=1" -c copy -flags +global_header -copyts -f flv rtmp://edge/livepkgr/stream2&adbe-live-event=liveevent
livepkgr does generally the job but the streams are broken.
ffprobe -v verbose -i http://edge/live.m3u8
drops out a lot of errors:
[NULL @ 0000000002d658e0] non-existing PPS 0 referenced
[hls,applehttp @ 0000000000326f00] Invalid stream index 2
My guess is that livepkgr need some "adobe"-way to connect/disconnect, that is compatibility problem.
Fortunately, ffmpeg does HLS so I run it like:
ffmpeg -v warning -re -i "rtmp://edge/live/stream1 live=1" -c copy -bsf:v h264_mp4toannexb -hls_time 8 -hls_flags delete_segments -hls_wrap 9 -f hls stream1.m3u8
ffmpeg -v warning -re -i "rtmp://edge/live/stream2 live=1" -c copy -bsf:v h264_mp4toannexb -hls_time 8 -hls_flags delete_segments -hls_wrap 9 -f hls stream2.m3u8
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
I don't use origin/edge scheme, i have 2 independent servers. For the moment the app from the first server doesent re-connect after a network failure, but i think this can be done easy with a listener.
I also tried to use ffmpeg to push streams but i ended using FMLE. It's better and it's safer
Votes
Translate
Translate
Report
Report
