0 Replies Latest reply on Jul 14, 2015 5:10 AM by Corrie1000
    Back and next buttons to labels in timeline
    Corrie1000 Level 1
      I want to create simple back and next buttons that jump to points along the timeline. I found some code that creates this using the time position e.g. 1000 millisecs, 2000 millisecs but I need it to go to a specified label.
      I don't want it to loop i.e. say my labels are 1,2,3,4,5 I don't want it to go back to '1' after '5'
      Here is the code for timeline position, can anyone show me how to change this to go to labels instead:
      //for the back button:
      var pos = sym.getPosition() // this is a numeric variable that gets the current time in the animation its in miliseconds so at one second this will have a value of 1000 at two seconds 2000 and so on
      if (pos <= '1'){
                sym.play('5'); // this if statement is checking to see what slide the animation is on, if it is in the first slide, it will play the begining of the last slide
      else if (pos <= '2'){
                sym.play('1'); // if it is in the second slide, it will play the beginning of the first slide
      else if (pos <= '3'){
                sym.play('2');  // if it is in the third slide, it will play the beginning of the second slide
      else if (pos <= '4'){
                sym.play('3');  // if it is in the fourth slide, it will play the beginning of the third slide
      else {
                sym.play('1');
      // for the forward button its the same concept only reversed
