2 Replies Latest reply on Jul 15, 2015 10:33 PM by matias.kiviniemi
    Moving groups inside other groups
    matias.kiviniemi Level 3
      Seems really basic, but keep having problems moving a group inside another group (tested CC 2014 and 2015). So following code throws an illegal argument error at the .move-line (I've also tried other variants like .PLACEATBEGINNING and .INSIDE):
      var doc = app.documents.add( 256, 256, 72, "foo")
      var group1 = doc.layerSets.add()
      var group2 = doc.layerSets.add()
      group1.move(group2, ElementPlacement.PLACEATEND)
      doc.close(SaveOptions.DONOTSAVECHANGES)
      But this way works OK
      var layer1 = group1.artLayers.add()
      var layer2 = group2.artLayers.add()
      group1.move(layer2 , ElementPlacement.PLACEAFTER)
      Any cracked what limitations are in play here? You can do latter, but then you might need to create & remove tmp layers to use as target.
        • 1. Re: Moving groups inside other groups
          Philip Cord Level 4
          Yes it has been a problem, but you can use AM.
          var doc = app.documents.add( 256, 256, 72, "foo");
          doc.layerSets.add();
          var group1 = getLayerID();
          var group2 = getLayerID();
          moveLayerToLayerSet( group2, group1);
          function moveLayerToLayerSet( fromID, toID ){
          var desc5 = new ActionDescriptor();
          var ref4 = new ActionReference();
          ref4.putIdentifier( charIDToTypeID('Lyr '), Number(fromID) );
          desc5.putReference( charIDToTypeID('null'), ref4 );
          var ref5 = new ActionReference();
          ref5.putIndex( charIDToTypeID('Lyr '), getLayerIndexByID(toID) );
          desc5.putReference( charIDToTypeID('T   '), ref5 );
          desc5.putBoolean( charIDToTypeID('Adjs'), false );
          desc5.putInteger( charIDToTypeID('Vrsn'), 5 );
          try{
          executeAction( charIDToTypeID('move'), desc5, DialogModes.NO );
          }catch(e){alert(e);}
          function getLayerID(){
          var ref = new ActionReference();
          ref.putEnumerated( charIDToTypeID('Lyr '),charIDToTypeID('Ordn'),charIDToTypeID('Trgt') );
          var desc = executeActionGet(ref);
          return desc.getInteger(stringIDToTypeID( 'layerID' ));
          function getLayerIndexByID(ID){
          ref.putIdentifier( charIDToTypeID('Lyr '), ID );
          try{
          activeDocument.backgroundLayer;
          return executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1;
          }catch(e){
          return executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ));
          • 2. Re: Moving groups inside other groups
            Thanks. Amazingly I've managed to (unintentionally) avoid this issue so far by always moving layers to document root. But now with Artboards can't be avoided
