26 Replies Latest reply on May 15, 2018 8:23 AM by itsBenMason
    Render swatch Legend Script
    Natesroom1 Level 1
      I was wondering if someone could help me edit this Script Written by John Wundes. Its almost perfect for what i need, but my problem is the text box inside of the swatch when it is rendered is to small. Ideally i'd like it to be 90% the size of the actual swatch. I've copied and pasted it here if someone could help i'd greatly appreciate it. I tried asking John on his Blog a few times but i haven't gotten any response. Also i'd like to delete the CMYK values that it returns with just the PMS name only.
      Render Swatch Legend v1.1 -- CS, CS2, CS3, CS4, CS5
      //  This script will generate a legend of rectangles for every swatch in the main swatches palette.
      //  You can configure spacing and value display by configuring the variables at the top
      //  of the script.
      //   update: v1.1 now tests color brightness and renders a white label if the color is dark.
      // JS code (c) copyright: John Wundes ( john@wundes.com ) www.wundes.com
      // copyright full text here:  http://www.wundes.com/js4ai/copyright.txt
          doc = activeDocument,
          swatches = doc.swatches,
          cols = 10,
          displayAs = "CMYKColor",  //or "RGBColor"
          rectRef=null,
          textRectRef=null,
          textRef=null,
          rgbColor=null,
          w=150;
          h=150,
          h_pad = 100,
          v_pad = 100,
          t_h_pad = 100,
          t_v_pad = 100,
          x=null,
          y=null,
          black = new GrayColor(),
          white = new GrayColor()
          black.gray = 100;
          white.gray = 0;
      activeDocument.layers[0].locked= false;
      var newGroup = doc.groupItems.add();
      newGroup.name = "NewGroup";
      newGroup.move( doc, ElementPlacement.PLACEATBEGINNING );
      for(var c=2,len=swatches.length;c<len;c++)
              var swatchGroup = doc.groupItems.add();
              swatchGroup.name = swatches[c].name;
              x= (w+h_pad)*(c% cols);
              y=(h+v_pad)*(Math.floor((c+.01)/cols))*-1 ;
              rectRef = doc.pathItems.rectangle(y,x, w,h);
              rgbColor = swatches[c].color;
              rectRef.fillColor = rgbColor;
              textRectRef =  doc.pathItems.rectangle(y- t_v_pad,x+ t_h_pad, w-(2*t_h_pad),h-(2*t_v_pad));
              textRef = doc.textFrames.areaText(textRectRef);
              textRef.contents = swatches[c].name+ "\r" + getColorValues(swatches[c].color) ;
              textRef.textRange.fillColor = is_dark(swatches[c].color)? white : black;
              rectRef.move( swatchGroup, ElementPlacement.PLACEATBEGINNING );
              textRef.move( swatchGroup, ElementPlacement.PLACEATBEGINNING );
              swatchGroup.move( newGroup, ElementPlacement.PLACEATEND );
      function getColorValues(color)
              if(color.typename)
                  switch(color.typename)
                      case "CMYKColor":
                          if(displayAs == "CMYKColor"){
                              return ([Math.floor(color.cyan),Math.floor(color.magenta),Math.floor(color.yellow),Math.floor(co lor.black)]);}
                          else
                              color.typename="RGBColor";
                              return  [Math.floor(color.red),Math.floor(color.green),Math.floor(color.blue)] ;
                      case "RGBColor":
                              return rgb2cmyk(Math.floor(color.red),Math.floor(color.green),Math.floor(color.blue));
                         }else
                      case "GrayColor":
                              return rgb2cmyk(Math.floor(color.gray),Math.floor(color.gray),Math.floor(color.gray));
                          }else{
                              return [Math.floor(color.gray),Math.floor(color.gray),Math.floor(color.gray)];
                      case "SpotColor":
                          return getColorValues(color.spot.color);
          return "Non Standard Color Type";
      function rgb2cmyk (r,g,b) {
      var computedC = 0;
      var computedM = 0;
      var computedY = 0;
      var computedK = 0;
      //remove spaces from input RGB values, convert to int
      var r = parseInt( (''+r).replace(/\s/g,''),10 );
      var g = parseInt( (''+g).replace(/\s/g,''),10 );
      var b = parseInt( (''+b).replace(/\s/g,''),10 );
      if ( r==null || g==null || b==null ||
           isNaN(r) || isNaN(g)|| isNaN(b) )
         alert ('Please enter numeric RGB values!');
         return;
      if (r<0 || g<0 || b<0 || r>255 || g>255 || b>255) {
         alert ('RGB values must be in the range 0 to 255.');
         return;
      // BLACK
      if (r==0 && g==0 && b==0) {
        computedK = 1;
        return [0,0,0,1];
      computedC = 1 - (r/255);
      computedM = 1 - (g/255);
      computedY = 1 - (b/255);
      var minCMY = Math.min(computedC,
                    Math.min(computedM,computedY));
      computedC = (computedC - minCMY) / (1 - minCMY) ;
      computedM = (computedM - minCMY) / (1 - minCMY) ;
      computedY = (computedY - minCMY) / (1 - minCMY) ;
      computedK = minCMY;
      return [Math.floor(computedC*100),Math.floor(computedM*100),Math.floor(computedY*100),Math.floor (computedK*100)];
      function is_dark(color){
             if(color.typename)
                      case "CMYKColor":
                          return (color.black>50 || (color.cyan>50 &&  color.magenta>50)) ? true : false;
                      case "RGBColor":
                          return (color.red<100  && color.green<100 ) ? true : false;
                      case "GrayColor":
                          return color.gray > 50 ? true : false;
                      case "SpotColor":
                          return is_dark(color.spot.color);
                      return false;
        • 1. Re: Render swatch Legend Script
          W_J_T Level 4
          Natesroom1 wrote:
          1. text is to small
          2. delete the CMYK values that it returns with just the PMS name only
          Just a quick glance at the code, try the following:
          1.) For the Size, after this line:
          Add the following line, change the numeric value to whatever size suits you:
          textRef.textRange.characterAttributes.size = 20;
          2.) Regarding removing the CMYK values for for PMS colors, change this line:
          textRef.contents = swatches[c].name+ "\r" + getColorValues(swatches[c].color);
          To this:
          textRef.contents = swatches[c].name;
          ... again just a quick glance, but maybe it will help your efforts.
          • 2. Re: Render swatch Legend Script
            Natesroom1 Level 1
            That worked perfectly. The only problem is the script makes an area text box that is very small inside the swatch so even when i change the value of the text from 20 to 30 it gets cut off (you know how area text boxes work with the red +)
            How can i change the size of the area text box that is created to around 90 or 85% of the swatch?
            • 3. Re: Render swatch Legend Script
              Larry G. Schneider Adobe Community Professional & MVP
              Try changing the value of the declared variables t_h_pad and t_v_pad to a larger number like 135 instead of 100.
              • 4. Re: Render swatch Legend Script
                Natesroom1 Level 1
                Perfect... i thought i had tried that already. Thank you both of you...I'm pretty sure you've helped me over the years.. I still haven't learned how to script but anytime I've need help i know you two and a couple others have answered with great patience!
                One last question, can i Specify a specific Font/Typestyle instead of the default myriad... if not this is 99% better then what i was doing before by hand.
                • 5. Re: Render swatch Legend Script
                  You can probably insert something like
                  textRef.textRange.characterAttributes.textFont = (whatever)
                  • 6. Re: Render swatch Legend Script
                    Natesroom1 Level 1
                    This works beautifully One more thing how do i turn off hyphenation?
                    I tried textRef.textRange.characterAttributes.hyphenation = false;
                    but that doesnt work - ithink its because i need to to apply it to the text box, but i'm not sure the right coding maybe
                    textRef.paragraphs.HYPHENATION = FALSE
                    EDIT nope that's not right tried that
                    • 7. Re: Render swatch Legend Script
                      Try this
                      textRef.paragraphAttributes.hypenation = false
                      • 8. Re: Render swatch Legend Script
                        holic2014
                        I want to ask one of the problems. I want to modify the appearance of cells under 5 column.
                        var docRef=app.activeDocument;
                        var SwatchBoxSize=Window.prompt("Enter the desired text size in points:", 20);
                        var swatchBoxSize=parseFloat(SwatchBoxSize);
                        var swatchBoxTop=swatchBoxSize;
                        var swatchXAnchor=42;
                        var swatchYAnchor=42;
                        for(var c=2,i=docRef.swatches.length;c<i;c++){
                                  var swatchRef=docRef.swatches[c];
                                  var swatchRefName=docRef.swatches[c].name;
                                  var swatchGroup=docRef.groupItems.add();
                                  var swatchBox=swatchGroup.pathItems.rectangle(swatchYAnchor, swatchXAnchor, swatchBoxSize, swatchBoxSize);
                                  swatchBox.fillColor=swatchRef.color;
                                  swatchBox.stroked=true;
                                  swatchBox.strokeWidth=.5
                                    var swatchLabelX= swatchBox.left+swatchBox.width+6;
                                    var swatchLabelY = swatchBox.top-10;
                                    var swatchLabel = swatchGroup.textFrames.pointText([swatchLabelX,swatchLabelY]);
                                  swatchLabel.contents = swatchRefName;
                                  swatchLabel.textRange.characterAttributes.size=swatchBoxSize/3;
                                  swatchLabel.textRange.characterAttributes.leading=swatchBoxSize/ 3;
                                  swatchLabel.textRange.characterAttributes.fillColor=docRef.swatches["C=0 M=0 Y=0 K=100" ].color;
                                  swatchBoxTop+=(swatchBoxSize*1.25);
                                  swatchXAnchor+=(100);
                          }//end for
                        and the result is
                        and I want it to be so
                        Can you help me ?. thanks
                        • 9. Re: Render swatch Legend Script
                          Qwertyfly... Level 4
                          just a mater of re-setting the position after every fifth item
                          var count = 0;
                                    count++;
                                    if(count > 4){
                                        count = 0;
                                        swatchXAnchor=42;
                                        swatchYAnchor-=(35);
                                    }else{
                          • 10. Re: Render swatch Legend Script
                            holic2014 Level 1
                            thanks you so much.
                            • 11. Re: Render swatch Legend Script
                              no problem
                              • 12. Re: Render swatch Legend Script
                                RodrigoPM
                                Hi. Could anyone help me edit this script, so i can put all my text below (outside) the box, like in the image?
                                Thank you
                                • 13. Re: Render swatch Legend Script
                                  W_J_T Level 4
                                  RodrigoPM wrote: Could anyone help me edit this script, so i can put all my text below (outside) the box, like in the image?
                                  A few basic modifications should do it:
                                  // Change this to the desired gap between the boxes where the text will go between:
                                  v_pad = 50, // change size as desired to work with the characterAttributes.size number below and the [position] number(s) below
                                  // Find this and comment out
                                  //textRectRef =  doc.pathItems.rectangle(y- t_v_pad,x+ t_h_pad, w-(2*t_h_pad),h-(2*t_v_pad)); // Comment out
                                  // Add this
                                  textRef.textRange.characterAttributes.size = 8 // change size as desired to work with the v_pad number above and the [position] number(s) below
                                  //textRef.textRange.fillColor = is_dark(swatches[c].color)? white : black; // Comment out
                                  textRef.textRange.fillColor = black; // changed to just use black assuming it will be on white artboard, otherwise use above
                                  // Add the following:
                                  textRef.position = [rectRef.left + 15, (rectRef.top - rectRef.height - 15)]; // This is now the positioning
                                  // adjust the 15 as needed in reference to the v_pad number you use above and the characterAttributes.size from above
                                  Which would result in the following:
                                  • 14. Re: Render swatch Legend Script
                                    RodrigoPM Level 1
                                    Thank you very much W_J_T. It worked
                                    • 15. Re: Render swatch Legend Script
                                      brandbrite
                                      Awesome script and great tweaks.
                                      I have a large palette of colors and they will all need the CMYK, RGB and HEX values for web purpose.
                                      I would want to add the HEX values as well, is there any way that can be done?
                                      Many thanks
                                      • 16. Re: Render swatch Legend Script
                                        add this function to the script at the top:
                                        function rgbToHex(r, g, b) {
                                            return "#" + ((1 << 24) + (r << 16) + (g << 8) + b).toString(16).slice(1);
                                        then when you assign the .contents to your text frame add the hex value.
                                        ie.
                                        swatchText.contents = swatches[c].name + "\r" + rgbToHex(swatches[c].color.red,swatches[c].color.green,swatches[c].color.blue);
                                        this will only work for RGB colors.
                                        not sure how you are displaying CMYK and RGB at the moment but if your getting both up you should be able to feed this function the RGB values.
                                        It is probably worth noting that Hex colour is just RGB.
                                        if red value == 0 then its hex value will be 00
                                        if green value == 16 its hex value is 10
                                        if blue value == 255 its hex value is FF
                                        giving us #0010FF
                                        • 17. Re: Render swatch Legend Script
                                          brandbrite Level 1
                                          Thank you Qwertyfly,
                                          I added the function and changed the textRef.contents as you mentioned...unfortunately what i get is this:
                                          http://prntscr.com/8w6k63
                                          Any help would be appreciated.
                                          • 18. Re: Render swatch Legend Script
                                            it's saying that the result is not a number.
                                            post the code and I'll see what's wrong.
                                            or check that the values fed to rgbToHex are numbers
                                            • 19. Re: Render swatch Legend Script
                                              robertob24917979
                                              I have been trying to figure out this script for months now. I've worked with the original script posted as well as the script posted by holic2014 and the edited one from Qwertyfly.
                                              All I need is pictured below. An ellipse W:0.3956in. x H:0.2019in. with the text at Arial regular 14.54pts to the right.
                                              I would like it to have just the Pantone color number and positioned at X:9.6538in. & Y:4.889in. The artboard size is  11.162in. x 6in.
                                              If anyone can help me out that would be awesome.
                                              Thank You in advance!!!
                                              • 20. Re: Render swatch Legend Script
                                                premierk42521177
                                                Going back to these first edits to the Render swatch legend script, is it possible to keep the CMYK values such as 9,33,99,0 but hide the the CMYK letters and = sign (C=9 M=33 Y=99 K=0)  See image attached of the result I want from the script:
                                                This thread is awesome! Thanks in advanc.
                                                • 21. Re: Render swatch Legend Script
                                                  itsBenMason Level 2
                                                  Using regex you an extract all numbers in the string then join the array using ", " like so:
                                                  var original = "(C=9 M=33 Y=99 K=0)";
                                                  var matcher = /[-]{0,1}[\d.]*[\d]+/g;
                                                  var result = original.match(matcher);
                                                  alert(result.join(", "));
                                                  Result being:
                                                  9, 33, 99, 0
                                                  The divider can any anything you want, if you'd prefer no space just remove the space in ", " making it "," or if you want something like a dash just change it to " - " and so on
                                                  • 22. Re: Render swatch Legend Script
                                                    jamess9525309
                                                    I'm trying to use this code to create a spot color colorbar across the page.  How can I add a step and repeat to this code?
                                                    • 23. Re: Render swatch Legend Script
                                                      jessmesserschmidt Level 1
                                                      Can anyone help me with the code to remove the 'Registration Black' & 'None' swatches?
                                                      • 24. Re: Render swatch Legend Script
                                                        Silly-V Adobe Community Professional
                                                        You can't remove those, unless you want Illustrator to crash immediately. They are apparently required.
                                                        • 25. Re: Render swatch Legend Script
                                                          i just want to remove them from showing up when the swatch palette is created using RenderSwatchLegend. I don't want to delete them from the swatch panel...
                                                          • 26. Re: Render swatch Legend Script
                                                            itsBenMason Level 2
                                                            Would just be a case of a name check
                                                            there is a line:
                                                            under that add something like this and wrap the rest of the code that is executed in an if statement:
                                                            if(swatchRefName !== "Registration Black" && swatchRefName !== "None") {
        //The rest of the code to follow
                                                            Or if you want something you can easily amend in the future for new colours you want to ignore:
                                                            if(shouldDisplay(swatchRefName)) {
                                                            function shouldDisplay(name) {
                                                              var ignore = [
        "registration black",
        "none"
                                                              for (var i = 0; i < ignore.length; i++) {
        if (name == ignore[i]) {
        return false;
                                                              return true;
                                                            you'd just keep adding to the ignore array
