9 Replies Latest reply on Feb 3, 2017 2:34 PM by DevilsChariot
    app.open() is not a function
    chrisr61512424
      Hey
      Win7/PS2014x64
      At one point recently these scripts worked.  Ive changed other things in the file (there are no clashes for the name "app") but not these functions.
      When I did a test the first time this happend, it would work if there were no other functions in the file.
      Now when I try to access the app.someMethod() it says that it is not a function.
      My script loads into extendscript with no errors.  I have photoshop selected as the target in extendscript.
      This happens on at least app.open()  and  app.stringIDtoTypeID()  and app.documents
      When it stops on app.open() in the debugger, there is no app object in the data browser, only 2 vars of mine and "this" (which has an app property that is the name of my CEP panel)
      if i stop execution of the script, the app object appears in the data browser
      what do I do make sure app is available? a loop that just keeps checking to see if its available?
      is this a bug?
      thanks
      chris rogers
        • 1. Re: app.open() is not a function
          Why not show the script and describe the document state when you used the script and identify  the someMethod() step that may or may not be valid for the current document state. Show the actual error you receive. And a screen capture showing the Photoshop windows showing Photoshop pallets like the layer and history so we get some idea what your writing about.  Put someContent() into what you write.
          • 2. Re: app.open() is not a function
            pixxxel schubser MVP & Adobe Community Professional
            +1
            chrisr61512424,
            did you try the function standalone?
            Are you really sure, that PS the target is?
            • 3. Re: app.open() is not a function
              chrisr61512424 Level 1
              Im paid to write code so I cant give you the code I am being paid to write.
              No documents
              I clearly state that app.open() (see title of post) isnt working along app.documents and app.stringIDtoTypeID
              with that may or may not be valid for the current document state.
              Again, no documents are open.
              The actual error I receive is the same one I listed in the title of this post:
              No documents open.
              Haha, that's a clever one.
              The problem and the steps to re-create the bug and the application state are all very clearly defined in the original post.
              the app object is not loaded when im tryig to call it, my apologies if this isnt crystal clear already.
              Hopefully a programmer will get back to me about this issue.
              • 4. Re: app.open() is not a function
                Well it does seem to be a name clash with CEP.
                when my script stops in the debugger the variable app is the name of the CEP panel and not a reference to application.
                Application() is a function that returns undefined
                Ill try try posting in a CEP specific forum, thanks for your help
                Chris
                • 5. Re: app.open() is not a function
                  Im paid to write code so I cant give you the code I am being paid to write …
                  … Hopefully a programmer will get back to me about this issue.
                  If you have had paid for the script: Please ask the script author!
                  • 6. Re: app.open() is not a function
                    It was a name clash.
                    The workaround is to declare this outside of a function in the begining of jsx file
                    var theApp = app
                    and use theApp to reference the photoshop app and not the CEP app
                    • 7. Re: app.open() is not a function
                      My apologies if I wasnt completely clear that I am the author that is being paid.
                      • 8. Re: app.open() is not a function
                        Yes.
                        Mostly my english is enough, but not in this case. Now I understand that you are the programmer.
                        • 9. Re: app.open() is not a function
                          DevilsChariot Level 1
                          Just looking into this issue today, so incase someone else needs an answer that works as of January 2017 try this:
                          open(new FIle("path/to/your/file/placed/here"));
                          ie:
                          open(new File("/Users/crs/Desktop/dvd_standard_litho/shine.psd" ));
