9 Replies Latest reply on Oct 7, 2015 12:56 AM by sampathk37726153
    Script for add images to indesign page by page.
    sampathk37726153
      Hello,
      I have 200 pages with border in indesign and 200 images having in local folder. every image name is S1, S2, S3...etc. Need script to add S1 to indesign page1 with centre in the border.
      Same for S2, S3..like that.
      Please suggest any script for that.
      Regards,
      Sampath.S
        • 1. Re: Script for add images to indesign page by page.
          Level 1
          Hi Sampath
          Pls use the below script
          main();
          function main(){
            var myFilteredFiles;
            //Make certain that user interaction (display of dialogs, etc.) is turned on.
            app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
            myExtensions = [".jpg", ".jpeg", ".eps", ".ps", ".pdf", ".tif", ".tiff", ".gif", ".psd", ".ai", ".png", ".rif", ".bmp"]
            //Display the folder browser.
            var myFolder = Folder.selectDialog("Select the folder containing the images", "");
            //Get the path to the folder containing the files you want to place.
            if(myFolder != null){
            if(File.fs == "Macintosh"){
            myFilteredFiles = myMacOSFileFilter(myFolder);
            else{
            myFilteredFiles = myWinOSFileFilter(myFolder);
            if(myFilteredFiles.length != 0){
            myDisplayDialog(myFilteredFiles, myFolder);
                                 //alert(myFolder.name);
                          var outmyf=Folder.selectDialog("Choose Out folder path");
                        //  var myPDFExportPreset = app.pdfExportPresets.item("prepress");
                      //    app.activeDocument.exportFile(ExportFormat.pdfType, File(outmyf+"/"+myFolder.name+".pdf"),false);
              alert("Done!");
          //Windows version of the file filter.
          function myWinOSFileFilter(myFolder){
            var myFiles = new Array;
            var myFilteredFiles = new Array;
            for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
            myExtension = myExtensions[myExtensionCounter];
                  myFiles = myFolder.getFiles("*"+ myExtension);
            if(myFiles.length != 0){
            for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
            myFilteredFiles.push(myFiles[myFileCounter]);
            return myFilteredFiles;
          function myMacOSFileFilter(myFolder){
            var myFilteredFiles = myFolder.getFiles(myFileFilter);
          //Mac OS version of file filter
          //Have to provide a separate version because not all Mac OS users use file extensions
          //and/or file extensions are sometimes hidden by the Finder.
          function myFileFilter(myFile){
            var myFileType = myFile.type;
              switch (myFileType){
            case "JPEG":
            case "EPSF":
            case "PICT":
            case "TIFF":
            case "8BPS":
            case "GIFf":
            case "PDF ":
            return true;
            break;
            default:
            for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
            var myExtension = myExtensions[myCounter];
            if(myFile.name.indexOf(myExtension)>-1){
            return true;
            break;
            return false;
          function myDisplayDialog(myFiles, myFolder){
            var myLabelWidth = 112;
            var myStyleNames = myGetParagraphStyleNames(app);
            var myLayerNames = ["Layer 1", "Labels"];
            var myDialog = app.dialogs.add({name:"Image Catalog"});
            with(myDialog.dialogColumns.add()){
            with(dialogRows.add()){
            staticTexts.add({staticLabel:"Information:"});
            with(borderPanels.add()){
            with(dialogColumns.add()){
            staticTexts.add({staticLabel:"Source Folder:", minWidth:myLabelWidth});
            staticTexts.add({staticLabel:myFolder.path + "/" + myFolder.name});
            staticTexts.add({staticLabel:"Number of Images:", minWidth:myLabelWidth});
            staticTexts.add({staticLabel:myFiles.length + ""});
            staticTexts.add({staticLabel:"Options:"});
            staticTexts.add({staticLabel:"Number of Rows:", minWidth:myLabelWidth});
            var myNumberOfRowsField = integerEditboxes.add({editValue:1});
            staticTexts.add({staticLabel:"Number of Columns:", minWidth:myLabelWidth});
            var myNumberOfColumnsField = integerEditboxes.add({editValue:1});
            staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
            var myHorizontalOffsetField = measurementEditboxes.add({editValue:12, editUnits:MeasurementUnits.points});
            staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
            var myVerticalOffsetField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
            with (dialogRows.add()){
            staticTexts.add({staticLabel:"Fitting:", minWidth:myLabelWidth});
            var myFitProportionalCheckbox = checkboxControls.add({staticLabel:"Proportional", checkedState:true});
            var myFitCenterContentCheckbox = checkboxControls.add({staticLabel:"Center Content", checkedState:true});
            var myFitFrameToContentCheckbox = checkboxControls.add({staticLabel:"Frame to Content", checkedState:true});
            var myRemoveEmptyFramesCheckbox = checkboxControls.add({staticLabel:"Remove Empty Frames:", checkedState:true});
            staticTexts.add({staticLabel:""});
            var myLabelsGroup = enablingGroups.add({staticLabel:"Labels", checkedState:true});
            with (myLabelsGroup){
            //Label type
            staticTexts.add({staticLabel:"Label Type:", minWidth:myLabelWidth});
            var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author"], selectedIndex:0});
            //Text frame height
            staticTexts.add({staticLabel:"Label Height:", minWidth:myLabelWidth});
            var myLabelHeightField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
            //Text frame offset
            staticTexts.add({staticLabel:"Label Offset:", minWidth:myLabelWidth});
            var myLabelOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
            //Style to apply
            staticTexts.add({staticLabel:"Label Style:", minWidth:myLabelWidth});
            var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
            //Layer
            staticTexts.add({staticLabel:"Layer:", minWidth:myLabelWidth});
            var myLayerDropdown = dropdowns.add({stringList:myLayerNames, selectedIndex:0});
                  var myResult = myDialog.show();
                  if(myResult == true){
            var myNumberOfRows = myNumberOfRowsField.editValue;
            var myNumberOfColumns = myNumberOfColumnsField.editValue;
            var myRemoveEmptyFrames = myRemoveEmptyFramesCheckbox.checkedState;
            var myFitProportional = myFitProportionalCheckbox.checkedState;
            var myFitCenterContent = myFitCenterContentCheckbox.checkedState;
            var myFitFrameToContent = myFitFrameToContentCheckbox.checkedState;
            var myHorizontalOffset = myHorizontalOffsetField.editValue;
            var myVerticalOffset = myVerticalOffsetField.editValue;
            var myMakeLabels = myLabelsGroup.checkedState;
            var myLabelType = myLabelTypeDropdown.selectedIndex;
            var myLabelHeight = myLabelHeightField.editValue;
            var myLabelOffset = myLabelOffsetField.editValue;
            var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
            var myLayerName = myLayerNames[myLayerDropdown.selectedIndex];
            myDialog.destroy();
            myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName);
            else{
            myDialog.destroy();
          function myGetParagraphStyleNames(myDocument){
            var myStyleNames = new Array;
            var myAddLabelStyle = true;
            for(var myCounter = 0; myCounter < myDocument.paragraphStyles.length; myCounter++){
            myStyleNames.push(myDocument.paragraphStyles.item(myCounter).name);
            if (myDocument.paragraphStyles.item(myCounter).name == "Labels"){
            myAddLabelStyle = false;
            if(myAddLabelStyle == true){
            myStyleNames.push("Labels");
            return myStyleNames;
          function myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName){
            var myPage, myFile, myCounter, myX1, myY1, myX2, myY2, myRectangle, myLabelStyle, myLabelLayer;
            var myParagraphStyle, myError;
            var myFramesPerPage = myNumberOfRows * myNumberOfColumns;
            var myDocument = app.documents.add();
            myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
            myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
            var myDocumentPreferences = myDocument.documentPreferences;
            var myNumberOfFrames = myFiles.length;
            var myNumberOfPages = Math.round(myNumberOfFrames / myFramesPerPage);
            if ((myNumberOfPages * myFramesPerPage) < myNumberOfFrames){
            myNumberOfPages++;
            //If myMakeLabels is true, then add the label style and layer if they do not already exist.
            if(myMakeLabels == true){
            try{
            myLabelLayer = myDocument.layers.item(myLayerName);
            //if the layer does not exist, trying to get the layer name will cause an error.
            myLabelLayer.name;
            catch (myError){
            myLabelLayer = myDocument.layers.add({name:myLayerName});
            //If the paragraph style does not exist, create it.
            try{
            myParagraphStyle = myDocument.paragraphStyles.item(myLabelStyle);
            myParagraphStyle.name;
            catch(myError){
            myDocument.paragraphStyles.add({name:myLabelStyle});
            myDocumentPreferences.pagesPerDocument = myNumberOfPages;
            myDocumentPreferences.facingPages = false;
            var myPage = myDocument.pages.item(0);
            var myMarginPreferences = myPage.marginPreferences;
            var myLeftMargin = myMarginPreferences.left;
            var myTopMargin = myMarginPreferences.top;
            var myRightMargin = myMarginPreferences.right;
            var myBottomMargin = myMarginPreferences.bottom;
            var myLiveWidth = (myDocumentPreferences.pageWidth - (myLeftMargin + myRightMargin)) + myHorizontalOffset
            var myLiveHeight = myDocumentPreferences.pageHeight - (myTopMargin + myBottomMargin)
            var myColumnWidth = myLiveWidth / myNumberOfColumns
            var myFrameWidth = myColumnWidth - myHorizontalOffset
            var myRowHeight = (myLiveHeight / myNumberOfRows)
            var myFrameHeight = myRowHeight - myVerticalOffset
            var myPages = myDocument.pages;
            // Construct the frames in reverse order. Don't laugh--this will
            // save us time later (when we place the graphics).
            for (myCounter = myDocument.pages.length-1; myCounter >= 0; myCounter--){
            myPage = myPages.item(myCounter);
            for (var myRowCounter = myNumberOfRows; myRowCounter >= 1; myRowCounter--){
            myY1 = myTopMargin + (myRowHeight * (myRowCounter-1));
            myY2 = myY1 + myFrameHeight;
            for (var myColumnCounter = myNumberOfColumns; myColumnCounter >= 1; myColumnCounter--){
            myX1 = myLeftMargin + (myColumnWidth * (myColumnCounter-1));
            myX2 = myX1 + myFrameWidth;
            myRectangle = myPage.rectangles.add(myDocument.layers.item(-1), undefined, undefined, {geometricBounds:[myY1, myX1, myY2, myX2], strokeWeight:0, strokeColor:myDocument.swatches.item("None")});
            // Because we constructed the frames in reverse order, rectangle 1
            // is the first rectangle on page 1, so we can simply iterate through
            // the rectangles, placing a file in each one in turn. myFiles = myFolder.Files;
            for (myCounter = 0; myCounter < myNumberOfFrames; myCounter++){
            myFile = myFiles[myCounter];
            myRectangle = myDocument.rectangles.item(myCounter);
            myRectangle.place(File(myFile));
            myRectangle.label = myFile.fsName.toString();
            //Apply fitting options as specified.
            if(myFitProportional){
            myRectangle.fit(FitOptions.proportionally);
            if(myFitCenterContent){
            myRectangle.fit(FitOptions.centerContent);
            if(myFitFrameToContent){
            myRectangle.fit(FitOptions.frameToContent);
            //Add the label, if necessary.
            myAddLabel(myRectangle, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, myLayerName);
            if (myRemoveEmptyFrames == 1){
            for (var myCounter = myDocument.rectangles.length-1; myCounter >= 0;myCounter--){
            if (myDocument.rectangles.item(myCounter).contentType == ContentType.unassigned){
            myDocument.rectangles.item(myCounter).remove();
            else{
            //As soon as you encounter a rectangle with content, exit the loop.
            break;
          //Function that adds the label.
          function myAddLabel(myFrame, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, myLayerName){
            var myDocument = app.documents.item(0);
            var myLabel;
            var myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
            var myLabelLayer = myDocument.layers.item(myLayerName);
            var myLink =myFrame.graphics.item(0).itemLink;
            //Label type defines the text that goes in the label.
            switch(myLabelType){
            //File name
            case 0:
            myLabel = myLink.name;
            break;
            //File path
            case 1:
            myLabel = myLink.filePath;
            break;
            //XMP description
            case 2:
            try{
            myLabel = myLink.linkXmp.description;
            if(myLabel.replace(/^\s*$/gi, "")==""){
            throw myError;
            catch(myError){
            myLabel = "No description available.";
            break;
            //XMP author
            case 3:
            try{
            myLabel = myLink.linkXmp.author
            throw myError;
            catch(myError){
            myLabel = "No author available.";
            break;
            var myX1 = myFrame.geometricBounds[1];
            var myY1 = myFrame.geometricBounds[2] + myLabelOffset;
            var myX2 = myFrame.geometricBounds[3];
            var myY2 = myY1 + myLabelHeight;
            var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
            myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
            myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
          • 2. Re: Script for add images to indesign page by page.
            sampathk37726153 Level 1
            Hello karthik,
            Thanks for your reply. could you explain how this script use as my requirement in In design.
            please confirm the following process to add the script.
            Copy script  -  Paste in Notepad  - save as "Script.jsx"  -   script menu in Indesign - select "user"  - select reveal in explorer  - select "Script.jsx".
            when using this process, One dialogue box open and fourth line is indicated in orange colour.
            Please how to use this script as my requirement.
            Regards,
            Sampath.S
            • 3. Re: Script for add images to indesign page by page.
              Level 1
              copy the jsx file in the path below
              C:\Program Files\Adobe\Adobe InDesign CS6\Scripts\Scripts Panel
              then run the script
              • 4. Re: Script for add images to indesign page by page.
                Hello Karthik,
                I have only CS4, Is this working in CS4?
                Regards,
                Sampath.S
                • 5. Re: Script for add images to indesign page by page.
                  Hello,
                  I am using your given code for our requirement, but, EPS file not orderly placed in indesign,
                  My requirement is S1 placed in page1, S2 placed in page 2.........
                  And onemore requirement is Master page is only single page. When using this code, front and back master page created autometically.
                  please consider my requirement and give suggestion.
                  Regards,
                  Sampath.S
                  • 6. Re: Script for add images to indesign page by page.
                    Level 1
                    var doc = app.activeDocument;
                    var w =doc.documentPreferences.pageWidth;
                    var h = doc.documentPreferences.pageHeight;
                    doc.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
                    var _folder = Folder.selectDialog("Select a folder");
                    var _files = _folder.getFiles();
                    var count=   _files.length;
                    for(var i =0;i<_files.length;i++)
                            if((_files[i] instanceof File)  )
                                for(j=0; j<doc.pages.length-1;j++)
                                    var image = doc.pages.item(j).place(_files[i]);
                                    //var gb = image[0].parent.geometricBounds;
                                    i = i+1;
                                    //var imageheight = gb[2] - gb[0];
                                    //var imagewidth = gb[3] - gb[1];
                                   // image[0].parent.geometricBounds = [(h-imageheight)/2,(w-imagewidth)/2,(h-imageheight)/2+imageheight,(w-imagewidth)/2+imagew idth];
                                    image[0].parent.fit(FitOptions.CONTENT_TO_FRAME)
                                //    doc.pages.add(LocationOptions.AT_END);
                    doc.pages.item(-1).remove();
                    • 7. Re: Script for add images to indesign page by page.
                      Hello,
                      Thanks for this coding, could you confirm this coding only enough for my requirement.
                      Regards,
                      Sampath.S
                      • 8. Re: Script for add images to indesign page by page.
                        Level 1
                        Hi
                        Where did you put up
                        On Wed, Oct 7, 2015 at 12:10 PM, sampathk37726153 <forums_noreply@adobe.com>
