2 Replies Latest reply on Jul 17, 2015 1:44 PM by redinkphotography
    Image not appearing in Develop Module
    redinkphotography Level 1
      I've seen a number of threads on this, but unfortunately the suggested solutions don't work.
      When I access the image in the Develop module it will initially display, but any adjustments I may make to the image are not displayed (they do in the Navigator preview in the upper left hand corner) and usually the image then disappears. After that, when I select the same image it leaves a blank screen where the image should display.
      When the issue first arose I checked and GPU acceleration could not be turned on because of an error. I went and updated my driver, but unfortunately I have an AMD Radeon 7670 graphics card and as I found out the hard way Lightroom CC is incompatible with that graphics card and the latest driver so when I accessed the Develop module lightroom instantly crashed, regardless of whether or not Graphics Acceleration was turned on.
      I was able to rollback to the older driver version,, so Lightroom will run without crashing, but the original problem still remains, I cannot use the Develop module.
      Any suggestions? At this point I'm tempted to roll back to the previous version of Lightroom but I'm hoping to avoid that as I ingested, tagged, and rated close to 2500 images and would really prefer not to lose that work.
      Lightroom version: CC 2015.1 [ 1025654 ]
      License: Creative Cloud
      Operating system: Windows 8.1 Home Premium Edition
      Version: 6.3 [9600]
      Application architecture: x64
      System architecture: x64
      Logical processor count: 8
      Processor speed: 3.3 GHz
      Built-in memory: 16322.1 MB
      Real memory available to Lightroom: 16322.1 MB
      Real memory used by Lightroom: 948.9 MB (5.8%)
      Virtual memory used by Lightroom: 928.0 MB
      Memory cache size: 59.2 MB
      Maximum thread count used by Camera Raw: 4
      Camera Raw SIMD optimization: SSE2,AVX
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 2560x1440
      Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: Yes, Keyboard: No
      Graphics Processor Info:
      Check OpenGL support: Failed
      Vendor: ATI Technologies Inc.
      Version: 3.3.12422 Core Profile Context
      Renderer: AMD Radeon HD 7670
      LanguageVersion: 4.30
      GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS (actual = 32, minimum = 48)
      Application folder: C:\Program Files\Adobe\Adobe Lightroom
      Library Path: K:\FILES_0001\lightroom_catalogs\lightroom_catalogs_0002_150709\lrcat_all_0003_130613_lr5 \lrcat_all_0003_130613_lr5-2.lrcat
      Settings Folder: C:\Users\Sean\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      1) Behance
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      5) HDR Efex Pro 2
      6) jf PicasaWeb
      7) Leica Tether Plugin
      8) LRT Export
      9) Nikon Tether Plugin
      10) Perfect B&&W 9
      11) Perfect Effects 9
      12) Perfect Enhance 9
      13) Perfect Photo Suite 9
      14) Perfect Portrait 9
      15) Perfect Resize 9
      16) PhotoShelter
      Config.lua flags: None
      Adapter #1: Vendor : 1002
        Device : 675b
        Subsystem : 6888103c
        Revision : 0
        Video Memory : 1003
      Adapter #2: Vendor : 1414
        Device : 8c
        Subsystem : 0
        Revision : 0
        Video Memory : 0
      AudioDeviceIOBlockSize: 1024
      AudioDeviceName: AMD  DP  Output (AMD High Definition Audio Device)
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      Direct2DEnabled: false
      GPUDevice: not available
      OGLEnabled: true
