2 Replies Latest reply on Jul 17, 2015 7:52 AM by c.pfaffenbichler
    Set animation frame duration with scripting
    Ghoulfool Level 1
      From within PS, I want to be able to create animation frames from layers and then set the frame duration (frame delay)
      This is what I have so far:
      var frametime = 1.0 // 1 sec /frame
      // create animation frames
      createAnimationFromLayers();
      // set frame timing
      setFrameDuration(frameTime);
      function createAnimationFromLayers()
        var id9070 = stringIDToTypeID( "animationFramesFromLayers" );
        var desc1033 = new ActionDescriptor();
        executeAction( id9070, desc1033, DialogModes.NO );
      function selectAllFrames()
        var id3 = stringIDToTypeID( "animationSelectAll" );
        var desc2 = new ActionDescriptor();
        executeAction( id3, desc2, DialogModes.NO );
      function setFrameDuration(num)
        selectAllFrames()
        var id4 = charIDToTypeID( "setd" );
        var desc3 = new ActionDescriptor();
        var id5 = charIDToTypeID( "null" );
        var ref1 = new ActionReference();
        var id6 = stringIDToTypeID( "animationFrameClass" );
        var id7 = charIDToTypeID( "Ordn" );
        var id8 = charIDToTypeID( "Trgt" );
        ref1.putEnumerated( id6, id7, id8 );
        desc3.putReference( id5, ref1 );
        var id9 = charIDToTypeID( "T   " );
        var desc4 = new ActionDescriptor();
        var id10 = stringIDToTypeID( "animationFrameDelay" );
        desc4.putDouble( id10, num ); //num (duration in seconds)
        var id11 = stringIDToTypeID( "animationFrameClass" );
        desc3.putObject( id9, id11, desc4 );
        executeAction( id4, desc3, DialogModes.NO );
      What I want to know is this
      - How can you open the animation window in scripting ( as it script will fail with it closed) - might have to add a try/catch for it otherwise
      - Is it possible to loop over the animation frames like this: (I don't know the syntax I'm guessing)
      for (var i = 0; i < numOFrames; i++)
          app.activeDocument.animation.frames = 1.0;
        • 1. Re: Set animation frame duration with scripting
          c.pfaffenbichler Level 9
          Is the important thing not that "Create Frame Animation" has been performed rather than for the Timeline Panel to be open?
          • 2. Re: Set animation frame duration with scripting
              1 for (var i = 0; i < numOFrames; i++)
              2 {
              3     app.activeDocument.animation.frames = 1.0;
              4 }
            What do you want to accomplish by this?
            Select or determine a frame – then what?
            This would select the second frame and set it to 0,1s :
            var idslct = charIDToTypeID( "slct" );
                var idnull = charIDToTypeID( "null" );
                    var idanimationFrameClass = stringIDToTypeID( "animationFrameClass" );
                    ref1.putIndex( idanimationFrameClass, 2 );
                desc2.putReference( idnull, ref1 );
            executeAction( idslct, desc2, DialogModes.NO );
            var idsetd = charIDToTypeID( "setd" );
                    var ref2 = new ActionReference();
                    var idOrdn = charIDToTypeID( "Ordn" );
                    var idTrgt = charIDToTypeID( "Trgt" );
                    ref2.putEnumerated( idanimationFrameClass, idOrdn, idTrgt );
                desc3.putReference( idnull, ref2 );
                var idT = charIDToTypeID( "T   " );
                    var idanimationFrameDelay = stringIDToTypeID( "animationFrameDelay" );
                    desc4.putDouble( idanimationFrameDelay, 0.100000 );
                desc3.putObject( idT, idanimationFrameClass, desc4 );
            executeAction( idsetd, desc3, DialogModes.NO );
            Does this have any relevance for your undertaking?
            adobe script for rotation and position
