16 Replies Latest reply on Aug 14, 2015 3:18 AM by StefanKeller42
    Using getDevelopSettings()
    rr28452526
      Hello!
      My name is Roman. I try to make a simple LR plug-in with following functions:
      1. Plug-in must send commands via PC's COM port,
      2. Plug-in must provide the list of presets to apply it to all photos in catalog,
      3. Plug-in must provide the batch crop function.
      Now I'm working with presets and something works fine (with kind help of johnrellis). For example, following code really changes all selected photos:
      LrTasks.startAsyncTask(function()
        catalog:withWriteAccessDo("PresetTry", function()
          local cat_photos = catalog.targetPhotos
          for i, photo in ipairs(cat_photos) do
            local preset = LrApplication.addDevelopPresetForPlugin( _PLUGIN, "TestPreset", { Shadows2012 = .4,  Exposure2012 = .3 })
            photo:applyDevelopPreset(preset, _PLUGIN)
          end
        end)
      end)
      But there are some problems:
      1. When I try to get some information from loaded image some methods works, some don't.
      For example, photo:getFormattedMetadata("fileSize") and photo:getFormattedMetadata("fileType") works fine, but
      local settings = photo:getDevelopSettings()
      LrDialogs.message( string.format("%d", settings["Exposure2012"]) )
      returns 0. At the same time I see that Exposure is equal to 0.3 (after the previous code was executed) in the Develop tab.
      Maybe, the original image wasn't changed with photo:applyDevelopPreset(preset, _PLUGIN), so original Exposure wasn't changed.
      2. I created some presets with names, for example, FirstPreset, SecondPreset etc. How can I apply it to images in my plug-in? I searched through the forum, but found nothing about it.
      3. I use the following code to get all photos in catalog:
           _some_code_here_
      end
      It works fine when I select all photos in catalog manually (when they all highlighted), but it doesn't when only one photo is selected - then I handle this and only this photo. What could be the problem?
      Thank you in advance.
      Best regards
      Roman
        • 1. Re: Using getDevelopSettings()
          johnrellis Most Valuable Participant
          I'll provide feedback on your points 1-3 above later today, but I just noticed your requirement 3, "Plug-in must provide the batch crop function.".  Unfortunately, develop presets can't apply crop settings: Lightroom SDK: Please assure *all* develop settings and metadata are available in Lr4. So at least with the documented SDK API, there is no way a plugin can apply cropping.
          However, you might investigate photo:applyDevelopSettings(), an undocumented method that was introduced in LR 6/CC 2015. It may be able to apply crop settings.  Alternatively, you might be able to use the LrDevelopController. See this thread for more information: Lightroom 6 SDK Changes.
          • 2. Re: Using getDevelopSettings()
            Do the following completely outside of the call to catalog:withWriteAccessDo():
            LrTasks.sleep (30); ...photo:getDevelopSettings ()...
            I know years ago there were reports that changing the develop settings didn't immediately "take", though I've never seen that.  Exiting withWriteAccessDo() and then waiting for 30 seconds could test that.
            Also, you might looking into using Debug.pause() in the debugger toolkit as an easier way of setting "breakpoints" and examining data values.
            • 3. Re: Using getDevelopSettings()
              If you want to retrieve a plugin's preset by its name, you'll have to iterate through the results of LrApplication.getDevelopPresetsForPlugin() looking for a preset where preset:getName() is the one you want.
              • 4. Re: Using getDevelopSettings()
                    _some_code_here_
                end
                I'm not sure exactly what you're observing here.  You're saying that when there is exactly one photo selected, catalog.targetPhotos is an array containing just one photo?  That is as it should be.  catalog.targetPhotos returns the same value as catalog:getTargetPhotos(), which the SDK defines as:
                Retrieves the photo objects for the photos that would be affected by any photo-processing command. If there is a selection, this is the list of selected photos. Otherwise, it is the entire list of photos in the filmstrip.
                What is the behavior that you want?
                • 5. Re: Using getDevelopSettings()
                  rr28452526 Level 1
                  , hello and thank you very much for your help.
                  As I understand, presets for current plug-in lives here:
                  ...\Lightroom\Plugin Develop Presets\_name_of_plug-in_\
                  I put some my presets to this folder. I successfully read all of their names with
                  local presets = LrApplication.getDevelopPresetsForPlugin(_PLUGIN)
                  for i, preset in ipairs(presets) do
                       LrDialogs.message( preset:getName() )
                  end
                  but I failed to apply them like this:
                       if preset:getName() == "TestPreset2" then
                            LrDialogs.message( "GOTCHA" )
                       end
                  end
                  i got GOTCHA message and that's all.
                  TestPreset2 in Develop tab changes photo, so I can see the difference.
                  • 6. Re: Using getDevelopSettings()
                         end
                    end
                    Is this executed inside a catalog:withWriteAccessDo()?
                    • 7. Re: Using getDevelopSettings()
                      rr28452526 Level 1
                      Yes, the full code is
                                  for j, preset in ipairs(presets) do
                                      end
                                  end
                              end
                          end)
                      end)
                      • 8. Re: Using getDevelopSettings()
                        rr28452526 Level 1
                        For the test purposes I used Export function in the Lightroom and added 10 photos to my workspace. I thought, this is my catalog, so I'll get all 10 with catalog.targetPhotos even if only 1 of them currently selected.
                        • 9. Re: Using getDevelopSettings()
                          I don't see anything obviously wrong, unfortunately.
                          • 10. Re: Using getDevelopSettings()
                            See catalog:getTargetPhoto(), :getTargetPhotos(), and :getMultipleSelectedOrAllPhotos().
                            • 11. Re: Using getDevelopSettings()
                              rr28452526 Level 1
                              I found that if I call preset that I created from plug-in with LrApplication.addDevelopPresetForPlugin() all works fine, but if I call preset that I created in Develop tab nothing happens.
                              Well, let's check the difference.
                              The preset created from plugin had following contents:
                              s = {
                                  id = "8D6A011D-C83E-4D08-9F92-09DD5536F4C6",
                                  internalName = "TestPreset",
                                  title = "TestPreset",
                                  type = "Develop",
                                  value = {
                                      Contrast2012 = -70,
                                      Exposure2012 = 0.3,
                                  version = 0,
                              The preset created from Develop tab:
                              s = {
                                  id = "3A8783C7-200D-473D-9C47-15709CCCF6F8",
                                  internalName = "MyNewPreset",
                                  title = "MyNewPreset",
                                  type = "Develop",
                                  value = {
                                      settings = {
                                          AutoLateralCA = 0,
                                          Blacks2012 = 0,
                              _much_bla_bla_bla_
                                          SplitToningShadowSaturation = 0,
                                          ToneCurveName2012 = "Linear",
                                          ToneCurvePV2012 = {
                                              0,
                                              0,
                                              255,
                                              255,
                                          ToneCurvePV2012Blue = {
                                              0,
                                              0,
                                              255,
                                              255,
                                          ToneCurvePV2012Green = {
                                              0,
                                              0,
                                              255,
                                              255,
                                          ToneCurvePV2012Red = {
                                              0,
                                              0,
                                              255,
                                              255,
                                          Vibrance = 0,
                                          VignetteAmount = 0,
                                          VignetteMidpoint = 50,
                                          WhiteBalance = "Custom",
                                          Whites2012 = 0,
                                          orientation = "AB",
                                      uuid = "F366933A-00B4-409A-A287-5B2C29AEE1E6",
                                  version = 0,
                              Well, there is some 'settings' section.
                              I deleted
                              'settings = {'
                              and corresponding
                              (just before 'uuid = "F366933A-00B4-409A-A287-5B2C29AEE1E6",')
                              and now preset works fine!
                              , thank you very much!
                              • 12. Re: Using getDevelopSettings()
                                rr28452526 Level 1
                                I'll try to find out tomorrow. Thank you again!
                                • 13. Re: Using getDevelopSettings()
                                  Yes, presets created by LrApplication.addDevelopPresetForPlugin() have a different representation than presets created from the Develop module.  You can't move a preset's .lrtemplate file from the folder "Plugin Develop Presets" to the folder "Develop Presets" or vice versa.
                                  • 14. Re: Using getDevelopSettings()
                                    rr28452526 Level 1
                                    Well, point 2 (using the presets) is now completely done. I take all plugins from
                                    _system_disk_:\Users\_username_\AppData\Roaming\Adobe\Lightroom\Plugin Develop Presets\_plugin_name_\
                                    let the user choose one to use, and undo changes if the result is not good.
                                    Maybe it is better to use other path, but I didn't find the way to change catalog.
                                    As I understand, point 3 (batch crop) is not available with SDK 5, which I use.
                                    So now I focus at point 1 (COM port communication).
                                    What did I do?
                                    local ComPortName = "COM3"
                                    serialin=io.open(ComPortName,"w")
                                    if serialin ~= nil then
                                         LrDialogs.message( string.format("%s opened successfully", ComPortName) )
                                         serialin:write("A")
                                         serialin:close()
                                    end
                                    This code allows to send 'A' to COM3 if COM3 is available and the platform is Win.
                                    But what to do if I don't know what port is available? How to get the list of available COM ports?
                                    Maybe I can call some .exe file, that can return this list - and I can get it from plug-in?
                                    • 15. Re: Using getDevelopSettings()
                                      Maybe this will help: Windows command to quickly list the available COM ports on a system? | Off Topic | unofficial empeg BBS.  You can run a command line using LrTasks.execute().  You can capture the output by having the command line redirect to a temp file and then reading that temp file from within the plugin.
                                      • 16. Re: Using getDevelopSettings()
                                        StefanKeller42 Level 1
                                        great idea, with the param names taken from an sidecar xmp you can set the crop with an plugin using LrDevelopController.setValue( param, value )
                                        numbers are relative, so you have to look at the aspect ratio for different files
                                        e.g.:
                                        CropTop="0"
                                        CropLeft="0.204416"
                                        CropBottom="1"
                                        CropRight="0.795584"
                                        CropAngle="6.75401"
                                        CropConstrainToWarp="1"
                                        and no, a preset does not accept this params :-(
