1 Reply Latest reply on Jul 23, 2015 12:04 PM by RoelvdM
    Check OpenGL support: failed LR CC2015.1 on OSX 10.10
    RoelvdM
      Dear all,
      I am suffering a fail on the OpenGL support on my medio 2012 macbook pro. As the GPU hardware acceleration was working for a few weeks, i am sure this could be solved.
      I checked the apple update and everything is up to date. The lightroom system info shows up the following information:
      Lightroom-versie: CC 2015.1 [ 1025654 ]
      Licentie: Creative Cloud
      Besturingssysteem: Mac OS 10
      Versie: 10.10 [4]
      Toepassingsarchitectuur: x64
      Aantal logische processors: 4
      Processorsnelheid: 2,5 GHz
      Ingebouwd geheugen: 16.384,0 MB
      Beschikbaar fysiek geheugen voor Lightroom: 16.384,0 MB
      Fysiek geheugen gebruikt door Lightroom: 403,6 MB (2,4%)
      Virtueel geheugen gebruikt door Lightroom: 1.250,6 MB
      Cachegeheugengrootte: 46,4 MB
      Maximumaantal door Camera Raw gebruikte threads: 2
      Camera Raw SIMD-optimalisatie: SSE2,AVX
      Schermen: 1) 1280x800
      GPU-info:
      Check OpenGL support: Failed
      Vendor: Intel Inc.
      Version: 4.1 INTEL-10.6.31
      Renderer: Intel HD Graphics 4000 OpenGL Engine
      LanguageVersion: 4.10
      Toepassingsmap: /Applications/Adobe Lightroom
      Bibliotheekpad: /Users/Roel/Pictures/Foto's Roel/Foto's Roel-2.lrcat
      Map Instellingen: /Users/Roel/Library/Application Support/Adobe/Lightroom
      Geïnstalleerde plug-ins:
      1) Aperture-/iPhoto-importeerprogramma-plug-in
      2) Behance
      3) Canon-plug-in voor tethering
      4) Facebook
      5) Flickr
      6) HDR Efex Pro 2
      7) Leica Tether-plug-in
      8) Tetheringplug-in voor Nikon
      Config.lua-vlaggen: None
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Ingebouwde uitgang
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CoreImage: true
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 2048
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: Intel HD Graphics 4000 OpenGL Engine
      GL_SHADING_LANGUAGE_VERSION: 1.20
      GL_STENCIL_BITS: 8
      GL_VENDOR: Intel Inc.
      GL_VERSION: 2.1 INTEL-10.6.31
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
      As you can see above, my system meets the minimum requirements for the GPU acceleration. When I was using the development module of lightroom, everything was a lot faster than it is now.
      Does anyone know how to solve this?
      Thanks a lot for your kind help.
