5 Replies Latest reply on Jul 20, 2015 7:58 AM by Peter Spier
    Licensing for this product (InDesign ) has stopped working.
    RDL33
      I am suppose to contact Adobe customer support but Adobe is not making that easy.  I have reinstalled InDesign CS3 but the program automatically shows the same message box.
      OS X  10.6.8 Snow Leopard
        • 2. Re: Licensing for this product (InDesign ) has stopped working.
          RDL33 Level 1
          Thank you it appears to be going in the right direction but ...
          The LicenseRecovery111(1).dmg arrived but 2clicking did not start anything though a Search showed that LicenseRecoveryLauncher.app was written to the disk.  2clicking LicenseRecoveryLauncher.app puts the computer in Terminal mode
          python: can't open file '/LicenseRecovery 11.6.1 1/LicenseRecovery/LicenseRecover.py': [Errno 2] No such file or directory
          which does not follow LicenseRecoveryLauncher.app instruction set.
          On Mac: Doubleclick the LicenseRecoveryLauncher.app and enter your Mac OS X password when prompted.
          • 3. Re: Licensing for this product (InDesign ) has stopped working.
            I'm afraid I can't offer anything more. You could try running it from a Safe Mode startup.
            • 4. Re: Licensing for this product (InDesign ) has stopped working.
              RDL33 Level 1
              Well it went further after doing a restart.  It actually claims that the problem was fixed but it is not.  Neither Photoshop nor InDesign will open.
              Trusted Storage Recovery Script v1.0.9
              Please choose a language:
                  e: English
                  j: Japanese (日本語)
              >: e
              DISCLAIMER:
              WARNING: Run at your own risk and make sure that ALL Adobe
              products are closed and not running before you proceed further.
              This tool has been developed to upgrade the licensing service
              and repair a license file for Adobe Acrobat 8 and 9, and
              Creative Suite 3 and 4 products.
              Do you wish to cancel at this time so you can close any
              open applications? [y/n]: n
              ** If you are ready to run the repair, then press
              the "enter/return" key now.
              ** If you have already run the repair once, but it didn't work,
              then reboot and run the repair again (files may have been locked).
              ** If you have run the repair after rebooting and it still didn't
              work, then reboot and when you get to this screen, enter 0.
              (If the steps above did not work, and licensing continues to fail,
              then please contact customer support.)
              Note: This may take a few moments.
              Processing ...
              No matching processes were found
              Shutting down licensing service ..
              Installing anchor service from ./mac_install_lima/FNPLicensingService/FNPLicensingService to /Library/Application Support/FLEXnet Publisher/Service/11.5.0
              Installing anchor service from ./mac_install_lucknow/FNPLicensingService/FNPLicensingService to /Library/Application Support/FLEXnet Publisher/Service/11.03.005
              Installing anchor service from ./mac_install_11.6.1/FNPLicensingService/FNPLicensingService to /Library/Application Support/FLEXnet Publisher/Service/11.6.1
              Checking system for trusted storage area...
              Configuring for Mac OS X, Trusted Storage path /Library/Preferences/FLEXnet Publisher...
              /Library/Preferences/FLEXnet Publisher already exists...
              Setting permissions on /Library/Preferences/FLEXnet Publisher...
              Permissions set...
              Configuration completed successfully.
              * Trusted Storage files were backed up successfully!
              * Trusted storage was successfuly recovered!
              * License files copied to "/Users/rlemaire/AdobeLicensingFilesBackup"
              The upgrade and repair are complete. Please attempt to
              run your Adobe product again. If the problem persists,
              you can run this tool again selecting the delete
              license option (pressing '0' when prompted),
              or call Adobe customer support.
              Completed, press "enter/return" to exit:
              • 5. Re: Licensing for this product (InDesign ) has stopped working.
                As I said, that's all I've got for you.
