4 Replies Latest reply on Jul 20, 2015 5:49 AM by Johnwhite
    How to open instanceof folder
    Johnwhite Level 1
      Hi experts
      I want to open the indd files which in the instance of folder.
      How can I make it works.
      my script as below, could some tell me what's wrong with the script.
      Regard
      John
      #target indesign
             app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
             var folder = Folder.selectDialog ("Select the root folder");
             var myfiles = [];
             getsubfolderfiles(folder);
             for(var i =0;i<myfiles.length;i++)
                     var docs = app.open(myfiles[i]);
                                          for (i = docs.length-1; i >= 0; i--) {
                                              var myTables = docs[i].stories.everyItem().tables.everyItem().getElements()
                                                  for ( t = 0; t < myTables.length; t++ ){
                                                          myTables[t].cells.everyItem().texts.everyItem().fillColor = "Black";
                                                          myTables[t].cells.everyItem().fillColor = "None";
                                                          myTables[t].cells.everyItem().leftEdgeStrokeColor = "None";
                                                          myTables[t].cells.everyItem().rightEdgeStrokeColor = "None";
                                                          myTables[t].cells.everyItem().topEdgeStrokeColor = "None";
                                                          myTables[t].cells.everyItem().bottomEdgeStrokeColor = "None";
                          function getsubfolderfiles(folder)
                                        var filelist = folder.getFiles();
                                        for(var i =0;i<filelist.length;i++)
                                            if(filelist[i] instanceof Folder)
                                                getsubfolderfiles (filelist[i]);
                                            else if(filelist[i] instanceof File)
                                                if(filelist[i].name.indexOf(".indd") > -1){
                                                    myfiles.push(filelist[i]);
                                   var docs = app.documents;
                                       for (var i = docs.length-1; i >= 0; i--) {
                                           if(docs[i].saved == false){
                                                 docs[i].close(SaveOptions.NO);
                                           else if(docs[i].close(SaveOptions.YES));
                                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                                alert("Finish.")
        • 1. Re: How to open instanceof folder
          Peter Kahrel Adobe Community Professional & MVP
          In what way does your script not work?
          • 2. Re: How to open instanceof folder
            Johnwhite Level 1
            Hi Pkahrel
            I want make it open all the root folder’s indd file, then change cell properties.
            or no open files but change the root folder’s indd file’s cell properties.
            but script as above, do nothing.
            Regard
            John
            • 3. Re: How to open instanceof folder
              Ronald63 Level 4
              Your problem is here
                    for(var i =0;i<myfiles.length;i++){
                              // code
              Try this ...
              //#target indesign
              var myfiles = [];
                  var doc = app.open(myfiles[i]);
                      var myTables = doc.stories.everyItem().tables.everyItem().getElements()
                  doc.close(SaveOptions.YES);
              alert("Finish.")
              function getsubfolderfiles(folder){
                  for(var i =0;i<filelist.length;i++){
                      if(filelist[i] instanceof Folder){
                      }else if(filelist[i] instanceof File){
              • 4. Re: How to open instanceof folder
                Johnwhite Level 1
                thank you Ronald
                thank you so much
                regard
                John
