5 Replies Latest reply on Jul 20, 2015 10:25 AM by elDudereno
    Resize top level groups
    elDudereno Level 3
      Running a for loop on all groups in a document. If group parent is a layer and layer is free then clipping mask and resize. Resize function fails as "Error 21 undefined is not an object" on the THIRD group in this example.
      Test_001.eps - Google Drive
      #target Illustrator
      var idoc = app.activeDocument;
      var gi = idoc.groupItems;
      function meetTheParents(PageItem){
           if (PageItem.parent.typename = "Layer"){
                return "Layer";
      function isLayerFree(layer){
           if (layer.locked == false && layer.visible == true){
                var gpa = layer.parent;
                isLayerFree(gpa);
                return true
                } else {
           return false
      for (j = gi.length -1; j >= 0; j--) {
           var iGroup = gi[j];
           if (iGroup.hidden==false && iGroup.locked==false) {
                if (meetTheParents(iGroup) == "Layer"){
                     if (isLayerFree(iGroup.parent)){
                          iGroup.selected = true;
                          app.executeMenuCommand ('makeMask');
                          app.executeMenuCommand ('deselectall');
                          iGroup.resize(50,50,true,true,true,true,50,Transformation=Transformation.CENTER);
                          // alert(iGroup.typename);
      It fails AFTER it does the clipping mask so the for loop is functioning properly. It resizes properly the first TWO times so the resize function is written correctly. If I comment out the resize command and uncomment the alert of iGroup's type name it completes successfully so the identity of the group in question is not an issue.
        • 1. Re: Resize top level groups
          elDudereno Level 3
          Interesting note: I was testing each of the elements of the resize function.
          pageItem.resize (scaleX, scaleY, changePositions, changeFillPatterns, changeFillGradients, changeStrokePattern, changeLineWidths, scaleAbout)
          I haven't messed with the scaleX, scaleY but I tested each of the following elements. In my original script they were all true, so I changed them to false one at a time.
          iGroup.resize(50,50,false,true,true,true,50,Transformation=Transformation.CENTER);// did not resize stopped clipping after third group
          iGroup.resize(50,50,true,false,true,true,50,Transformation=Transformation.CENTER);// resize first two clipped third and failed
          iGroup.resize(50,50,true,true,false,true,50,Transformation=Transformation.CENTER);// ditto
          iGroup.resize(50,50,true,true,true,false,50,Transformation=Transformation.CENTER);// ditto
          iGroup.resize(50,50,true,true,true,true,true,Transformation=Transformation.CENTER);// Changed 50 to 'true'. result ditto
          iGroup.resize(50,50,true,true,true,true,true,Transformation=Transformation.TOPLEFT); // kept the changeStrokePattern as 'true' and changed the transformation point and got this result:
          Before:
          After:
          The first group appears to have followed the instructions from the script, changing from top left, but the second group changed from the center.
          I checked and I get the same result if I revert to 50 for changeStrokePattern.
          iGroup.resize(50,50,true,true,true,true,50,Transformation=Transformation.TOPLEFT);
          Same result if I comment out the clipping mask function, except it's not clipped obviously.
          Are things changing INSIDE of the resize function as it runs? If so why?
          • 2. Re: Resize top level groups
            o-marat Level 3
            There you do not have an error in the function meetTheParents()?
            Must be PageItem.parent.typename == "Layer"?
            • 3. Re: Resize top level groups
              elDudereno Level 3
              Good catch, thank you, but it doesn't change the result. After correcting that oversight the result is the same.
              • 4. Re: Resize top level groups
                o-marat Level 3
                And this is working?
                (function () {
                  var groups = activeDocument.groupItems,
                      iGroup,
                      j;
                  for ( j = 0; j < groups.length; j++ ) {
                    iGroup = groups[ j ];
                    if ( iGroup.hidden == false && iGroup.locked == false ) {
                      if ( meetTheParents ( iGroup ) == "Layer" ) {
                        if ( isLayerFree ( iGroup.parent ) ) {
                          app.executeMenuCommand ( 'makeMask' );
                          app.executeMenuCommand ( 'deselectall' );
                          iGroup.resize ( 50, 50, true, true, true, true, 50, Transformation.CENTER );
                  function meetTheParents ( PageItem ) {
                    if ( PageItem.parent.typename = "Layer" ) {
                      return "Layer";
                  function isLayerFree ( layer ) {
                    if ( layer.locked == false && layer.visible == true ) {
                      isLayerFree ( gpa );
                      return true;
                    } else {
                      return false;
                • 5. Re: Resize top level groups
                  elDudereno Level 3
                  So the error was:
                  The "Transformation=" was unnecessary and screwing things up after a few iterations.
                  The correct syntax is: iGroup.resize( 50, 50, true, true, true, true, 50, Transformation.CENTER);
