2 Replies Latest reply on Jul 22, 2015 11:29 AM by sinious
    Rotating a Blurred MovieClip
    bashi-bazouk Level 1
      Hi, I have a nested movieClip that is blurred on one axis (Y)
      When rotating this parent clip, the blur remains as a pure Y direction
      Is it possible to enable the blur direction to rotate along with the parent clip ?
        • 1. Re: Rotating a Blurred MovieClip
          Nipun Asthana Adobe Employee
          You may convert your inner Symbol to a Bitmap after applying filter to it, in case there's no animation within your Symbol. After this, rotating the parent Movieclip will also rotate the axis of the applied filter.
          • 2. Re: Rotating a Blurred MovieClip
            sinious Most Valuable Participant
            This was actually a problem previously. You can see in this old thread something similar to what you're talking about. What Flash version/OS are you using? It may be as simple as updating Flash.
            When you apply that filter, it's going to rotate, as expected, with the parent. To keep it continuously in a certain rotation you'll need to determine the parents rotation and re-apply the filter taking that into consideration. If it's a complex clip then you probably will suffer FPS-wise from doing that frame to frame but it really entirely depends. To my knowledge, there is no automated way to tell a Flash MovieClip to adjust filter settings based on the parents orientation. Think of the inverse. If you rotated a parent and all your filters ignored the rotation, that would be very unexpected.
