2 Replies Latest reply on Jul 21, 2015 4:32 PM by johnrellis
    lua Lightroom 6 script lrcatalog calls failing "assertion failed"
    Iain Malcolm Level 1
      I'm trying to get the info about current folders etc in a lua script but it just fails "assertion failed" This happens for getFolders() and getActiveSourceas(). type() works OK and returns LrCatalog.
      Even with a sleep call added it fails - although Lightroom has been running for several minutes.
      local LrFunctionContext = import 'LrFunctionContext'
      local LrApplication = import 'LrApplication'
      local LrTasks = import 'LrTasks'
      local LrBinding = import 'LrBinding'
      local LrDialogs = import 'LrDialogs'
      local LrLogger = import 'LrLogger'
      local LrView = import 'LrView'
      -- Create the logger and enable the log print function.
      local myLogger = LrLogger( 'libraryLogger' )
      myLogger:enable( "logfile" ) -- Pass either a string or a table of actions.
      -- Write trace information to the logger.
      local function outputToLog( message )
        myLogger:trace( message )
      end
      local function showCustomDialog()
        outputToLog("two")
      -- LrTasks.sleep(3)
        LrFunctionContext.callWithContext( "showCustomDialog", function( context )
        outputToLog("three")
        local actCat = LrApplication.activeCatalog()
        outputToLog(actCat.type())
        local trying = actCat.getFolders()
      -- local photosets = actCat.getActiveSources()
        local f = LrView.osFactory()
           -- Create a bindable table.  Whenever a field in this table changes
           -- then notifications will be sent.
        local props = LrBinding.makePropertyTable( context )
        props.isChecked = false
        props.checkboxstate = "bimble"
        outputToLog("four")
           -- Create the contents for the dialog.
            local c = f:row {
           -- Bind the table to the view.  This enables controls to be bound
           -- to the named field of the 'props' table.
        bind_to_object = props,
           -- Add a checkbox and an edit_field.
        f:checkbox {
           title = "Enable",
           value = LrView.bind( "isChecked" ),
        f:edit_field {
        value = "Some Text",
        enabled = LrView.bind( "isChecked" )
        f:static_text{
        title = LrView.bind( "checkboxstate" )
        f:checkbox {
        title = "Other Enable",
        value = LrView.bind( "checkboxstate" ),
        checked_value = "yes",
        unchecked_value = "no"
            LrDialogs.presentModalDialog {
           title = "Custom Dialog",
           contents = c
        end) -- end main function
      end
      -- Now display the dialogs.
      LrTasks.startAsyncTask(function()
          showCustomDialog()
      end)
