3 Replies Latest reply on Jul 21, 2015 2:19 AM by Laubender
    How to remove empty image boxes?
    Sivanadri Sirisha Level 1
      I am using dynamic images in InDesign file. I need to remove empty image box when there is no image. Anyone have idea?
      Sirisha
        • 1. Re: How to remove empty image boxes?
          Hi Sivandri Sirisha,
          can you tell us a bit more about your workflow?
          How do you determine, if a graphic frame is not needed anymore?
          Are there distinct differences between a not needed graphic frame other than not containing an image?
          Maybe an applied object style? Maybe a distinct fill color or stroke width? Something that is unique to your graphic frames holding images?
          Uwe
          • 2. Re: How to remove empty image boxes?
            Hi Laubender,
            I have used 20 image boxes in design file which are dynamic using XMPIE uPlan. I am using two different Object Styles for the image boxes alternatively. The image box should remove/hide when there is no image in the image box.
            S. Sirisha
            • 3. Re: How to remove empty image boxes?
              Do you know why XMPIE uPlan is creating empty graphic frames?
              I'm not familiar with that tool. Maybe you can find a way to prevent this.
              I see a chance, that a script can do what you want iterating the allPageItems array and checking all graphic frames if the said Object Styles are applied and will not contain any images.
              I don't know your layout, so I cannot tell, if there any side effects removing those frames. There might be some, if you have to write back data to the tool.
              Uwe
