2 Replies Latest reply on Jul 23, 2015 8:54 PM by sreekarthik.k@gmail.com
    XML attribute change
    Level 1
      I need to replace the xml attribute value "M05_LEMO9433_06_SE_CH05" to M05_LEMO5401_06_SE_CH05
      In document having more than thousand entries
      I have used the below code but it is not working
      function AddReturns(){
          this.name = "AddReturns";
          this.xpath = "//p//span//a";
          this.apply = function(myElement, myRuleProcessor){
              with(myElement)
        try{
                    //      if (myElement.xmlAttributes.item("href").value.match ("LEMO9433 "))
                                  var fig = myElement.xmlAttributes.itemByName("href").value;
                                  var    figv =  fig.replace ("9433", "O5401")
                                  myElement.xmlAttributes.itemByName("href").value=figv;
        //myElement.xmlAttributes.item("id").name = "olinkend";
        }catch(e){}
              return true;
        • 1. Re: XML attribute change
          Loic.Aigon Adobe Community Professional
          Try this :
          var main  = function() {
            var root,
            xes,
            n,
            ov = "M05_LEMO9433_06_SE_CH05",
            nv = "M05_LEMO5401_06_SE_CH05";
            if ( !app.documents.length ) return;
            root = app.activeDocument.xmlElements[0];
            xes = root.evaluateXPathExpression ("//*[@*='"+ov+"']" );
            n = xes.length;
            while ( n-- ) {
            changeAttributeValue ( xes[n], ov, nv );
          var changeAttributeValue  = function ( xe, oldValue, newValue ) {
            var xas = xe.xmlAttributes,
            xa,
            n = xas.length;
            while ( n-- ) {
            xa = xas[n];
            xa.value == oldValue && xa.value = newValue;
          main();
          • 2. Re: XML attribute change
            Level 1
            Thanks loicaigon
            I have tried like this
            main();
            alert("Comepleted", "Attribute Replacer");
            exit();
            function main()
              var aDoc = app.activeDocument;
              var processes = new Array(
              new findKeyTerm
              with(aDoc)
              var element = xmlElements.item(0);
              __processRuleSet(element, processes);
            function findKeyTerm()
              this.name = "findKeyTerm";
              this.xpath = "//a[@href]";
              this.apply = function(caught, runningProcess)
              //with(caught)
              var tmp = (caught.xmlAttributes.item("href").value);
              tmp = tmp.replace("LEMO9433", "LEMO5401");
              caught.xmlAttributes.item("href").value = tmp;
              $.writeln(caught.xmlAttributes.item("href").value);
