1 Reply Latest reply on Dec 17, 2006 3:07 PM by Bob_Robertson
    platformer
    sk8morestudyless
      i need help with this platformer im making
      its a game like mario but with a stick man
      i have platforms that go above the stage so when the "player" goes above a sertain _y value the ground and platforms scroll downwards
      but!!
      i cant get it to scroll downwards below a sertain y value
      it scrolls just fine but it goes way farther than i want it to
      any help
      heres the code
      oh and tips would be appriciated on my codeing considering ive been useing flash for about 2 months and i wrote this by myself
      onClipEvent(load){
      speed=20
      onClipEvent (enterFrame) {
      if (Key.isDown(Key.RIGHT)) {
      _x+=speed
      gotoAndStop(2);
      _xscale=+100
      else if (Key.isDown(Key.LEFT)) {
      _x-=speed
      gotoAndStop(2);
      _xscale=-100
      else{
      gotoAndStop(1)
      onClipEvent(enterFrame){
      _y+=10
      if(_y<=59){
      _root.ground._y+=10
      this is where i need help
      see i got the scrolling one way but i
      need help with the downward scrolling
      if(_root.wallr.hitTest(_x,_y,true)){
      _root.ground._x-=20
      _root.bg._x-=5
      _x-=20
      if(_root.walll.hitTest(_x,_y,true)){
      _root.ground._x+=20
      _root.bg._x+=0
      _x+=20
      if(_root.ground.endwr.hitTest(_x,_y,true)){
      _x-=20
      gotoAndStop(1)
      jumping=true
      if(_root.ground.endwl.hitTest(_x,_y,true)){
      _x+=20
      gotoAndStop(1)
      jumping=true
      if(this.hitTest(_root.ground.goal)&&Key.isDown(Key.SHIFT)){
      _root.gotoAndStop(2)
      if(_root.ground.hitTest(_x,_y,true)){
      _y-=10
      jumping=false
      touchg=true
      jh=0
      if(Key.isDown(Key.SPACE)&&!jumping){
      jh=40
      jumping=true
      if(jumping==true){
      jh-=2
      if(jh<=-15){
      jh=-15
      _y-=jh
      gotoAndPlay(3)
        • 1. Re: platformer
          Bob_Robertson
          Well, general principles:
          comment everything. (<code>//<comment, or /*<comment>*/<code> .
          declare and initialize variables before using them. (var foo=bar) . I learned this the hard way.
          it generally makes your code more readable if you break up your function and variable names (fn_name(), or fnName())
          also, indenting your code makes it much more readable, and is even done automatically for you in the later versions
          There should be a list of ActionScript 'Best Practices' floating around the Adobe site somewhere...
          As to your problem, I don't see any code which actually deals with scrolling downward to debug. The logic should be similar, though:
          if(character is below certain height [above certain _y value]){
          scroll bg upward (decrease its _y value);
          scroll ground upward (decrease its _y value);
          if(test_for_landing()){
          landing_action();
          Just to make things conceptually easier, you might want to separate the jumping action into two separate events: the jump, which propels the character upward, and the fall, which accelerates the character downward. This, in turn, leads you into the idea of states, which are a topic for another day, but very worthy of your attention.
