3 Replies Latest reply on Jul 21, 2015 8:31 AM by Test Screen Name
    Need help with export to PDF and transparency issues
    susanb23057128
      Thanks to this community, my InDesign files are almost warning free , but I still have the following warnings in Preflight:
      The PDF document uses features that require at least Acrobat 5.0 (PDF 1.4) [someone suggested that I do that - is that ok?]
      Transparency used (transparency group)
      Transparency used (soft mask in image)
      Font is embedded (completely or as a subset)
      I am exporting to PDF.
      I have merged my layers.
      What else do I need to do?
      Here is a summary of my settings:
      Description
          [Based on '[High Quality Print]'] Use these settings to create Adobe PDF documents for quality printing on desktop printers and proofers.  Created PDF documents can be opened with Acrobat and Adobe Reader 5.0 and later.
      PDF Preset: CreatespacePreset
      Compatibility: Acrobat 5 (PDF 1.4)
      Standards Compliance: None
      General
          Pages: All
          Spreads: Off
          View: Default
          Layout: Default
          Full Screen: Off
          Generate Thumbnails: Off
          Optimize PDF: On
          Create Acrobat Layers: N/A
          Export Layers: Visible and Printable Layers
          Include Bookmarks: Off
          Include Hyperlinks: Off
          Export Nonprinting Objects: Off
          Export Visible Guides and Baseline Grids: Off
          Create Tagged PDF: On
          Interactive Elements: Do Not Include
      Compression
          Color Images
              No Sampling Change
              for images above: 450 ppi
              Compression: Automatic
              Tile Size: N/A
              Quality: Maximum
          Grayscale Images
              Bicubic Downsample at: 300 ppi
              Tile Size: N/A
              Quality: Maximum
          Monochrome Images
              Bicubic Downsample at: 1200 ppi
              for images above: 1800 ppi
              Compression: CCITT Group 4
          Compress Text and Line Art: On
          Crop Image Data to Frames: On
      Marks and Bleeds
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Color Bars: Off
          Page Information: Off
          Page Mark Type: Default
          Weight: 0.25 pt
          Offset: 0.0833 in
          Use Document Bleed Settings: On
          Bleed Top: 0 in
          Bleed Bottom: 0 in
          Bleed Inside: 0 in
          Bleed Outside: 0 in
          Include Slug Area: Off
      Output
          Color Conversion: No Color Conversion
          Destination: N/A
          Profile Inclusion Policy: Include All Profiles
          Simulate Overprint: N/A
          Output Intent Profile Name: N/A
          Output Condition: N/A
          Output Condition Identifier: N/A
          Registry Name: N/A
      Advanced
          Subset Fonts Below: 0%
          Omit PDF: Off
          Omit EPS: Off
          Omit Bitmap Images: Off
          Transparency Flattener Preset: N/A
          Ignore Spread Overrides: N/A
      Security
          N/A
      Warnings
      Susan
